XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 01-18-2005, 05:45 AM   #1
caligula
caligula's Avatar
Asus support or How Dumbo got a job - finally.
Just admire. I've just decided I won't ever buy Asus products again, with such a brilliant support which leaves you hanging.
Needless to say that further complains to the red commies at support@asus.com.cn are still unanswered, english isn't spoken in deep China.
Pure crap.
Dear Friend :
Thank you for contacting ASUS Customer Service.
My name is Leon and I would be assisting you today.
Then that depends on you configure of the system and other componient compatibility
Good luck.
If you have any suggestions or complaints about our technical support
service, please e-mail your feedback to support@asus.com.cn. We will then
arrange for a specialist to work on your issue. Your suggestions and
feedback are most appreciated and allow us to serve you better.
Web: http://www.asus.com.tw
Download: http://download.asus.com.tw
FTP: ftp://ftp.asus.com.tw
---------- Original Message ----------
Sent : 2005-1-11 8:42:25
To : "tsd@asus.com.tw"
Subject : Re:<TSD> Motherboard P4P800-E Deluxe
Dear Leon,
Ok, it is quad pumped so it is 800, I knew that, thank you.
The question is : if I increase the frequency, MAM (or PAT) is disabled in
1:1 memory divider. Can you keep it enabled on other frequencies bigger than 200x4?
"Leon Zhao" <tsd@asus.com.tw>
11.01.2005 04:09
To: (hidden)
cc:
Subject: Re:<TSD> Motherboard P4P800-E Deluxe
Dear Friend :
Well, the FSB is 4 times of the 200 and your FSB should be 800 now and it
is ok
So ,please do not wrong about that.
Download: http://download.asus .com.tw
Sent : 2005-1-11 6:14:25
Subject : <TSD> Motherboard P4P800-E Deluxe
Apply date : 1/11/2005 6:12:55 AM
[Contact Information]
*Name : (hidden)
*Email Address : (hidden)
Phone Number :
City :
[Product Information]
*Product Type : Motherboard
*Product Model : P4P800-E Deluxe
*Product S/N : (hidden)
*Date of Purchase : 2004/12/13
[Problem Description]
PAT (MAM enabled in BIOS) works only at 200 MHz FSB with 1:1 memory
divider, when increasing
the latter, PAT is being disabled. Is there any chance to get it enabled
at FSBs over 200MHz? Thank
you.
__________________
Web-browsing machine: Q6600@3.6GHz/1.4V | Andy Samurai/AC AF12025 | MSI P35 Neo2-FR | 4x1GB Hynix DDR667@500 MHz 12-4-4-4 | Sapphire HD3870 | Audigy2 ZS | DeLUX 600W PSU | Toshiba 37WL67ZG TrueHD 1080i
caligula is offline   Reply With Quote
Old 01-18-2005, 05:56 AM   #2
death metal
death metal's Avatar
just do the dual bios flash =)....
death metal is offline   Reply With Quote
Old 01-18-2005, 05:58 AM   #3
caligula
caligula's Avatar
Are you sure it works ? Do you have a description of this? Many users reported that P4P8X bootstrap does not work with this board.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
