XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 01-14-2005, 03:31 PM   #1
ed.howell
Dumb question! What's a pencil mod??
Just as the title says.
I see threads on how to mod GPU's and some refer to a "pencil mod".
Thanks,
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
ed.howell is offline   Reply With Quote
Old 01-14-2005, 03:35 PM   #2
crotale
Xtreme Legend
crotale's Avatar
Send a message via MSN to crotale
Instead of adding actual resistors to the circuit the graphite in the pencils will cause a change in resistance, which will fool the voltage regulation, thus increasing voltages. If done correctly that is
__________________
"In mild doses, ethylene produces states of euphoria, associated with stimulus
to the pleasure centres of the human brain."
Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
crotale is offline   Reply With Quote
Old 01-14-2005, 03:48 PM   #3
f00t
Send a message via MSN to f00t
just be sure not to put too much graphite on or else you'll mess up your card. best is to check with a voltimeter after every stroke
f00t is offline   Reply With Quote
Old 01-14-2005, 03:51 PM   #4
ed.howell
Thanks for the quick responses guys
You don't happen to have any or know of any links of pics do you?
EDIT: Never mind I got it!! your basically drawing a line between points, correct.
I really feel dumb now.
Thanks,
Ed
__________________
Corsair 620HX PSU
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
