XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 01-02-2005, 05:53 PM   #1
luihed
Overkill
luihed's Avatar
Cant get past 218fsb with Neo2
I just upgraded to an MSI neo2 platinum and a 3000+ A64 939. No matter how much I played with the bios I cant seem to get past 218fsb..... My rams are HyperX 3200 ( BH-5). Is it a compatibility issue and is there a fix besides buying new rams? Thanks all....
BTW Ive been out of touch with the overclocking world for a while now so its prolly simple, Im just out of ideas....
__________________
E8400 DFI LP P35T2R Ballistix
8800GTS PCP&C 1.2kw Raptors
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
luihed is offline   Reply With Quote
Old 01-02-2005, 05:55 PM   #2
DevilsRejection
DevilsRejection's Avatar
Send a message via AIM to DevilsRejection
did you drop the HTT?
DevilsRejection is offline   Reply With Quote
Old 01-02-2005, 05:57 PM   #3
choseone214
Banned
ram i slot 1+2
set HT to 3x
cas=2
trp=2
ras-to-cas=2
tras=5
set agp to 67mhz
next flip the board over and do the 3.3v to cap mod
250-270mhz now easy.
see what the issue is is that if you set I think it is trp or ras-to-cas to 2 in bios even if you have 2.85v selected your only getting 2.7v or so to vdimm . so oyu can set at 2-3-3-5 and boot to windows and use a64 tweaker and reset back to 2-2-2-5 "PITA" or use booster or better yet cap mod as bh-5 can do 3.3v 24/7 in its sleep
choseone214 is offline   Reply With Quote
Old 01-02-2005, 06:06 PM   #4
luihed
Overkill
luihed's Avatar
Ive set the vdimm to 2.85v and set timings to 2-2-2-5 before and it didnt work..... do you think I need more voltage than that to do 220fsb? Im pretty sure my bh5 should do that easy with even 2.7v vdimm...... as for modding, Im not to sure if I wanna do any modding to this board as Im not gonna overclock it alot, its just going to be aircooled....... maaybe Ill try the A64 tweaker nd ram booster... thanks...
As for HTT yes Ive tried 3x and it was a no go.....
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 01-02-2005, 06:16 PM   #5
choseone214
Banned
MY BH-5 does 271mhz at 3.65v but can't do 220mhz either at 2.85v in bios thats why I said to try cap mod or booster if FSB is important
Old 01-02-2005, 06:21 PM   #6
brentsg
When I had OCZ 3700EB (2x512) I couldn't break 220 either regardless of Vdimm.
I got some OCZ 4200EL Platinum (TCCD) and I run 260 at 2.5-3-3-10 easily.
I didn't keep looking for the top end, but I think it was 270 at 2.5-3-3-10. I did 275 at 3-3-3-10 but did not try any higher.
This is with a stock Neo2, no mods.
B
brentsg is offline   Reply With Quote
Old 01-02-2005, 06:27 PM   #7
Theo404
Theo404's Avatar
I have hyperX 3200 bh5 2x 256.....did the 3.3v bus to vdimm mod a few days ago, does 230 2-2-2-5 standing on its head, so far Ive been able to superPi 1M at 250*11....pushing 31sec. Havnt tried out extensivly yet. specs in sig.
__________________
E2180
MSI P35 Neo2 FR
Geil Black Dragon 2x1GB
EVGA 7900GTX
Toughpower 750W
Viewsonic VP191b
Theo404 is offline   Reply With Quote
Old 01-02-2005, 08:08 PM   #8
luihed
Overkill
luihed's Avatar
Thanks for all the replies...... so I guess I need more vdimm... Ill go order a OCZ ram booster tommorrow, thats all I need right? anybody has a link to the cap mod?
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 01-02-2005, 08:28 PM   #9
choseone214
Banned
Here ya go mate
Old 01-02-2005, 08:34 PM   #10
Kanavit
Kanavit's Avatar
Send a message via AIM to Kanavit
my hyperX can do 225 easily, set cpu to 1.7v and 2.8vdimm. how can you tell if my chip is BH-5 physically. what should i be looking for?
__________________
--===== proud owner of new razor tarantula gaming keyboard =====--
Kanavit is offline   Reply With Quote
Old 01-02-2005, 08:38 PM   #11
Super strokey
Did you turn off aggressive mem interface in teh bios?
Super strokey is offline   Reply With Quote
Old 01-02-2005, 08:56 PM   #12
luihed
Overkill
luihed's Avatar
Thanks Chooseone..... anything else I need to know after taht mod? Does it just increase the vdimm a certain amount ie 2.85v in bios equals 3.3v actual or will it give me the 3.3v option in the bios?
Kanavit, the model # for the bh-5 hyperX is khx3200 and not khx3200A... sure way is to take the hs of the ram and looking at teh actual chip..... if you got your ram recently it wont be bh-5
Super Stokey I did disable that option....
What kind of speed am I looking at with this cpu on air? stepping is 0447 and cooling will be with Zalman 7000, with the nice Vancouver weather, inside case temp would be around 5c......would I get 2.5g?
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 01-02-2005, 08:57 PM   #13
DevilsRejection
where you get that 0447 from? is it 90nm aka whinchester?
Old 01-02-2005, 09:16 PM   #14
luihed
Overkill
luihed's Avatar
I got it from eglobalonline.com here in vancouver.... yes it is a winnie...
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 01-02-2005, 09:44 PM   #15
amilian
with that mod, your vdimm will be equal to your 3.3v rail. If you do the 3.3 psu rail mod you can take it even higher. It won't give you the option in bios, whatever vdimm you set in bios it will be the same as your 3.3v rail, since you are attaching a 3.3v wire directly to ram. Doesn't matter what you set in bios.
With 5c case temp you'll be rockin. I'm at 28c case temps at 2.5ghz with Zalman7000 and load doesn't break 53c, so you should be significantly lower assuming you have AS5 and Zalman seated well. And with that stepping you should easy hit 2.5 maybe 2.7 with those low temps. Good thing about recent steppings is the mem controller rocks allowing 1T high fsb and htt.
__________________
Neo2 Platinum | 3000+ @ 2400mhz (8x300 1:1) | 2x256 TCCD Patriot BXL @ 2.85v 2.5-3-3-7 | Zalman CNPS7000A-AlCu | TTGI 550 | 33sec 1M SuperPI
amilian is offline   Reply With Quote
Old 01-03-2005, 04:32 PM   #16
luihed
Overkill
luihed's Avatar
Thanks Amilian....
So if I do the cap mod, my max vdimm is whatever my 3.3r is..... if I wanna go higher will teh OCZ ram booster work without doing the vdimm mod? ... From the looks of it this cpu looks very promising, so far 2750mhz superpi stable.....
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
