XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 12-20-2004, 05:23 AM   #1
cinders
cinders's Avatar
Exclamation Cooling OCZ VX - Heatsinks for RAM?...
My VX gets extremely hot and so does my booster (@ 3.4v)...
I have a fan with a wind tunnel blowing cold air over the ram and booster.
I've modded the booster by moving the mosfets to the back and installing huge heatsinks to them which are doing the job nicely....
However the heatspeaders on the ram get extremely hot (i'm sure this is holding back my o/c on this stuff) so I'm looking at a better way to cool the ram....
I'm thinking of removing the heatspeaders as they don't seem to dissapate the heat to well and I was wondering if there are any heatsinks you can fit to the ram chips?...
Is there any watercooled blocks you can get for memory?...
Cinders.
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
cinders is offline   Reply With Quote
Old 12-20-2004, 05:33 AM   #2
RacerX
I can't speak for your OCZ VX but my PC3200EL Plat rev2 would get pretty hot with the heatspreaders only with 2.8v, though they don't really need that much to hit high HTT. I removed my spreaders and pushed 3v thru them and the chips only got slightly warm after a few hours of gaming.
There really isn't a postive reason why they use the spreaders except for hiding the chips they use. Just my personal opinion.
__________________
Asus P5W64WSPro/Xeon 3060 SS 9x467/TeamXtreem 667 2GB/Patriot PC28000XBL 1GB/Sapphire X1800XT/w PE bios/OCZ PowerStream 520w/150gb Raptor/CPU cooled by AquaXtreme MP-05 Pro Limited Edition, BI GTX 240/MCPSwiftech655/Masterkleer 7/16IN
RacerX is offline   Reply With Quote
Old 12-20-2004, 05:39 AM   #3
eva2000
Memory Addict
eva2000's Avatar
i just use 2x 60x25mm fans tied together and they sit on the memory heatspreaders.. keeps ram very cool according to thermal probes i.e. 33-38C at 3.6v vdimm while looping memtest86+ v1.40 for 12-22+ hrs
eva2000 is offline   Reply With Quote
Old 12-20-2004, 05:58 AM   #4
cinders
cinders's Avatar
I personally don't think the heatspreaders do much at all. They could at least have fins on them to help dissipate the heat....
I'm going to pull mine off tonight and see if that helps matters.
Some watercooled blocks would be nice...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 12-21-2004, 07:24 PM   #5
Yanus
i don´t think there are any water blocks for ram, but u could make one. Let me see if i can explain this correctly:
2 plates of copper
copper tube
2 connectors
The idea is to have each plate on one side of the stick, the tube is welded to the plates and goes around the stick. What i mean is the water enters in one side (enters on one tube on one of the plates) and comes out on the other tube (plate). This is my idea, i don´t think i was able to explain it very well, i did the best ai could. At least is an ideia.
Yanus is offline   Reply With Quote
Old 12-21-2004, 07:32 PM   #6
Playful_Buffalo
Playful_Buffalo's Avatar
you can buy watercooled blocks at www.xoxide.com
Playful_Buffalo is offline   Reply With Quote
Old 12-22-2004, 06:15 PM   #7
Yanus
Nice! thanks a bunch! It´s useful to me 2
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
