XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 12-20-2004, 05:17 AM   #1
cinders
cinders's Avatar
Setting up Voltage Lines on my OCZ520
I'm just wondering what I should set my lines to with my OCZ?...
Do I keep them spot-on, or give them more juice?...
At the moment I've used a multimeter to set them all spot-on, ie. 12.00v, 5.0v, 3.30v... but not sure if I should 'juice' them up a bit?...
Just wondering what you guys run?...
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
cinders is offline   Reply With Quote
Old 12-20-2004, 05:42 AM   #2
_Eduard_
_Eduard_'s Avatar
Send a message via MSN to _Eduard_
Make sure you set them correct under load, that is a bit higher when idle
__________________
C2D E6300 @ 3.5ghz | 2x1GB ADATA "Micron D9" @ 500 4-4-4-12 2.3v | Asus P5B-E Plus C2 | Sapphire X1900XT 512MB | Tuniq Tower 120
_Eduard_ is offline   Reply With Quote
Old 12-20-2004, 05:55 AM   #3
cinders
cinders's Avatar
Thought I should set them exact... I'll set them all during 3DMark2005, now I know that knocks the hell out of everything!...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
