12-18-2004, 03:45 AM
#1
My first x800 - going to be any good for o/cing?..
Just got my new Saphire X800 PE this morning. I wanted to make sure the card is working properly and is decent at overclocking before installing my watercooling gpu block and ram heatsinks.
Anyway on the standard aircooling you get with the card I can manage 540 Core and 610 on memory, is this any good?...
Any ideas what I might be able to get on water?...
I haven't had any experience with this card so I'm just wondering what people have been clocking theirs to on air and water so i can get a rough idea about this card.
Thanks,
Cinders.
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
12-18-2004, 05:07 AM
#2
from looking at your sig, aint those speeds faster then your current GFX with its overclock?
__________________
12-18-2004, 07:04 AM
#3
Overclocking X.I.P. Otaku
That's a pretty good clock for the memory stock, some XT PE's can go higher with the core....
12-18-2004, 08:03 AM
#4
its similar with my card....(sapphire X800 XT PE)
I had the same speeds at mem but at core 570 with stock cooling.
Now....with vgpu,vmem and a waterblock 655/655
http://service.futuremark.com/compare?2k3=3478957
12-18-2004, 01:15 PM
#5
Yep faster the 6800, thats why I went for the 800XT...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-18-2004, 01:19 PM
#6
Originally Posted by shidokanjohn
That looks like an excellent o/c!... What cooling are you using, just watercooling?.. what blocks you got?...
I've just spent the past 8 hours re-building my machine, this time I've fitted a Enheim 1250 pump, maze4 chipset block, maze4 gpu block and some nice solid copper heatsinks on the ram...
I'm just running it in at the moment, will keep my o/c's on this new card posted...
Any mods to do on this card?... I had my 6800 running at 1.5 vCore by flashing the bios...
Thanks,
Cinders.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-18-2004, 11:25 PM
#7
Promie at cpu.For card ,innovatek radiator double ,eheim 1048 and block from eleven from Greece...
http://eleven.orion.gr/
1.75V at vga core
Enjoy your new card
12-19-2004, 12:51 AM
#8
Xtreme 3DMark Addict
except in doom3, an x800xt is generally reguarded to be better than a 6800gt/ultra because of higher fill rate. Not only that but nvidias drivers use more "tweaks" to boost performance. also nvidia has ps3 but this has not been a big factor for most since so few games use ps3 and also ps2 can do what ps3 can but with more passes. 540 core is just weak, that is less than 4% overclock. getting any x800xt over 600 on the ram is good since I see alot of guys unable to oc the ram save for 10, maybe 20MHz. ram matters more than core too since the cores 16 pipes, high core clocks arent too important if its bandwith limited. you might need vmods and watercooling to break 600MHz core, as for ram, vmods to it could send it to 630-650.
__________________
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
12-19-2004, 07:42 AM
#9
Well I'm happy! (for now)
I vMod'd the GPU to 1.75v and can now run 630/610 stable which is a over 100mhz increase which ain't bad!
I've got 90335 aquarmarks which I never thought I'd reach! I could only manage 80,000 with my 6800 Ultra o/c'd at 475/1220!
I also get 35,821 3dmark 2001, 14827 3dmark 2003 and 6,000 3dmark 2005 so it's not bad really... It's quite a bit quicker than my old 6800 ultra.
I think my system is as fast as I can o/c it on water now, everything is max'd up!
Cinders.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-19-2004, 09:10 AM
#10
I just bought a X800 vivo and flashed it to 16 pipes and can't get stable over 540 core myself. My old 12 pipe X800pro got to 560-570 without problems.
do you have links to the threads showing the volt mods , I tried search and found the pencil mod is that good enough or what would you recomend??
memory stable to 614 would like 600 core too
__________________
i7 920 @4.305 ghz (205*21 HT on) Prime stable@ 1.312v (Batch# 3844A717) your results may vary
i7 920 @4.410 ghz (210*21 HT on) 1hr Prime stable@ 1.39v (Batch# 3844A717) could push more but no reason too
Enzotech Heat Killer SCW-REV.A (very nice block 73c / 79c per above voltages)
GA-EX58-UD4P (Bios ????),, 6GB- OCZ3P1600LV6GK (7-7-7-20 @1640 mhz) 1:1
XFX-5870 with Swiftech nickel block
Water Cooling - TFC X-Changer 480 and 6-Scythe SFF21E fans @1000 rpm , Vario 655
Raid 0 velociraptors 600GB,, ZM1000-HP (powerfull and silent)
Mitsubishi 22" CRT (old school ,,no input lag , no slow response times , true color reproduction & blacker blacks) its deep but so what
12-19-2004, 10:43 AM
#11
I just did the pencil mod on the resistor for the vGPU - I'm thinking about doing the memory on this board as well, did you do yours?...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
