12-15-2004, 02:53 PM
#1
Not so good mem controller on my FX-55?...
Can't get past 254Mhz HTT on my OCZ VX at 2-2-2-10. I've tried full range of vDimm 3.2-3.6v - Also tried vCore up to 1.80v... I have swapped my month 09 motherboard for a month 11 (with 0442A2 Korea stepping)and all bios versions, but it still hits a brick wall at 254mhz in memtest #5.... arrhhhhh....
I've tried each module on their own and still can't get past 254mhz on either, in fact one locks memtest up...
think i've got some dodgy vx - most people are hitting 260/270 which is what I'm after!...
i can't break the 2940mhz on this 55 either... ideally i would have liked to maybe hit 250 x 12 - but can't get past 2940 stable with any vCore.
The FX-55 I have is 0441EPMW - so it's a week 41...
I'm thinking of buying another fx-55 to see if i get a better one, i've seen people doing well with week 43's... can anyone help?...
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
12-15-2004, 03:13 PM
#2
What cooling are you using?
12-15-2004, 03:16 PM
#3
I'm running a Thermochill (same as black ice) 120.3 radiator with 3 vantec stealth fans running full speed... i'm using a dangerden 12v pump, seperate resevoir, dangerden tdx block and nv68 block.
my cpu temp never rises above 45 on full load (reported by mbm5)
i'm sure the cooling is more than enough for what i run.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-15-2004, 03:18 PM
#4
It deffinetly seems like your getting below average performance for teh cooling....
12-15-2004, 03:51 PM
#5
cinders, you are just the person I am looking for. I have exactly the same hardware as yours: Neo2 0411xxx with 0442 Korea chipset, FX-55 0441 and VX RAMs. I can run up to 259 but I need 3.6v for that and it's not very stable. Can you please run MemTest86+ 1.40 and check the reported bandwidth? Mine looks very low compared to conrad's result below with a 3500+. Many thanks in advance.
Here is mine at 255:
And, here's Conrad at 258:
12-15-2004, 03:52 PM
#6
I would bet the variation is with the MSI board.
B
12-15-2004, 04:04 PM
#7
Can you try a NC or Winnie in the same board?
12-15-2004, 04:26 PM
#8
Xtreme 3DMark Addict
why would it be an ondie controller limit? alot of VX ram maxes out at about 250fsb. get some tccd dude and theres a good chance youll get around 270fsb, maybe even 300 if your reeeeeeeeeeeal lucky
__________________
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
12-15-2004, 04:34 PM
#9
My CPU and board are proven to run beyond 270 for sure with TCCD. my question was really about the low bandwidth I'm getting. Here are some screenie for 280 and 300 with GSkill TCCDs.
12-16-2004, 12:27 AM
#10
I previously had some OCZ 4200EL in this setup and could run 300HTT in memtest with no errors... However it wouldn't boot in to windows. I could bench in windows around the 270 mark....
However running the new VX at 247 (2-2-2-10) with a multi of 12 gave me 2964 (my highest stable o/c yet...) and reduced my SuperPi time from 29s to 28s, so I was quite happy with that.
This brings up the question, whats better, VX 250Mhz at 2-2-2-10 or TCCD say at 270+ at 2.5-3-3-7...?
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-16-2004, 12:30 AM
#11
Sure.... I'll post it a bit later today!
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-16-2004, 02:36 AM
#12
Here's a screen shot for you.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-16-2004, 07:52 AM
#13
Thanks Cinders. It looks that you and I have similar number and that means both our FX-55s have much lower bandwidth compared to conrad's 3500+ winnie.
12-16-2004, 08:08 AM
#14
Yes, I see what you mean....... Then again I use sandra for measuring bandwidth - i'll see what mine says tonight... See what Sandra reports your bandwidth at?...
I think week 41 ain't very good, I'm going to wait a while then get myself a new 55 and see what that's like at overclocking...
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
12-16-2004, 11:01 AM
#15
Strictly Business
It really breaks my heart to see you guys complaining about the FX-55, as I am hoping the FX will be able to push my RAM to new heights. Have you guys taken a temperature reading of your CPU with a digital thermometer? Maybe heat is an issue on both the CPU and memory side.
I was able to do 258MHz 2-2-2-10 with two 92mm Sunon fans blowing on the memory modules and DDR Booster. I swapped those fans out for a 120mm Sanyo Denki and made a wind tunnel for the DIMM region and can now get 263MHz 2-2-2-10. My CPU is still 70C to 72C under load at 10x263MHz, so better cooling measures should improve performance even slightly.
By the way, my chip is a Newcastle.
__________________
Brayden rules!
OVERCLOCKING - The process of installing high hopes, dumb luck, and several paychecks into a rectangular
box which transmits a signal to a screen that displays your fate. The outcome is usually depressing.
12-16-2004, 02:55 PM
#16
@conrad: Sorry about the CPU, yes, it's NC.
For my case, CPU's cooling should not be an issue since it's on watercooling. But, I did not use any direct measurement using thermometer though. While for RAM, I only have 1x92mm fan blowing the RAM and it's mounted on Zalman bracket.
I hope others FX-55 owners can also see this thread and don't mind reporting back their MemTest bandwidth.
12-16-2004, 02:57 PM
#17
Will test later. The bandwidth is low but mine can do 30XX with normal watercooling and 29XX on air. It's not too bad, is it?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
