XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 12-08-2004, 07:42 AM   #1
cinders
cinders's Avatar
Stupid Q, but what is the best tRas setting for AMD64?...
Can anyone advise me what I should be aiming for? Is lower better?...
I'm running 2-2-2-10 at the moment - wasn't sure if I should try to go for 2-2-2-5, 2-2-2-7, 2-2-2-8. etc.
Whats best for the AMD64?...
Cinders.
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
cinders is offline   Reply With Quote
Old 12-08-2004, 07:43 AM   #2
Holst
Member
Holst's Avatar
I find that 2 is a bit quicker.. but it dosent seem to make much difference at all.
Holst is offline   Reply With Quote
Old 12-08-2004, 07:49 AM   #3
Gokou
Gokou's Avatar
Off Topic:
You got any pictures of ur rig mate?
Where does the rad fit in the stacker?
Gokou is offline   Reply With Quote
Old 12-08-2004, 07:49 AM   #4
AlterBridge86
AlterBridge86's Avatar
Send a message via AIM to AlterBridge86
i think what cinders is asking about can't get to 2, the lowest Tras goes to is 5...and 5 would definitely be the best...i've never actually done any recorded testing, but in my experiments with 2225 and 2228 it increased maybe by 100mb/s in sandra...nothing significant, but the lower the better...good luck!
__________________
Intel Q6600 @ 3.64ghz - 1.39v
DFI LanParty UT P35
300gb WD VelociRaptor - 10,000rpm
Creative SoundBlaster X-Fi "XtremeMusic"
HIS Radeon HD4850
OCZ ModXstream 780W PSU
AlterBridge86 is online now   Reply With Quote
Old 12-08-2004, 07:51 AM   #5
Holst
Member
Holst's Avatar
A64 tweaker lets me choose "2"
But it might be set to 5... 5 might be the lowest the memory controller can do... I think I read that somewhere.
Old 12-08-2004, 08:03 AM   #6
cinders
cinders's Avatar
I just wasn't sure about the tRas - someone told me a setting of 7 gave higher bandwith, all the guys with the same VX memory as me seem to be running there's a 2-2-2-10 which is what I went for. Maybe I should have started 2-2-2-5 or 2-2-2-7.... I'll have a play around tonight.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 12-08-2004, 08:05 AM   #7
cinders
cinders's Avatar
Originally Posted by Gokou
Off Topic:
Hello Mate,
Here's a link to it:
http://www.xtremesystems.org/forums/...ad.php?t=45323
It's had many changes since then! : )
Da Cinders.
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 12-08-2004, 08:08 AM   #8
mad mikee
I am Xtreme
Use memtest and fiddle.
Memtest and goldmemory give bandwidth for comparison purposes. TCCD for example likes 7 (gotta remember to try 6 like OPB does w/ trc of 7 ) but 10 is NOT gospel. Check to find the best w/ YOUR mem.
mad mikee is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
