XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 12-06-2004, 04:57 PM   #1
sobol
sobol's Avatar
My cpu hit wall beyond 320 HTT
Hello
To be stable with 1T setting i must use 8x multiplier,
Useing 10x260 mhz with 2T aint problem, To get equal with 1T i would need 8x325 mhz but at 320( thats max stable with prime95) im hitting wall, my htt is 3x. Im sure its not problem with my memory coz:
- memtest is working at 325,
- prime95 fails at any of 3 torture tests after max 5 mins,
- my ram is doing 240 2-2-2 stable , and it tested.
What i tried for now was:
- 1.7v for chipset - no go,
- changeing htt to 2.5x - no go,
- rising lil vcore - no go
Any ideas what else i can try ?
__________________
INTEL Q6600 G0 3.6 - 1.3875V - TR120 BLACK + S-FLEX SFF21E
4x2048 XP2-8000 Mushkin Redline EM@500 5-5-5 2.1V
ASUS MAXIMUS II P45 FORMULA
ASUS RADEON 5850 1GB @ 5870 OC
SAMSUNG 2TB (2x1TB) SATA
CORSAIR HX 620W PSU
ANTEC P182/ DELL 22"/ WIN 7 64 ULTIMATE
sobol is online now   Reply With Quote
Old 12-06-2004, 11:13 PM   #2
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Max HTT for you CPU most likely.
NewCastle?
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is online now   Reply With Quote
Old 12-07-2004, 02:19 AM   #3
sobol
sobol's Avatar
Heh seems its not my max htt, Jonspd from ocforums told me to relax mem timings, was ridiciolus for me but it worked...
Relaxing timings gived me some stability. Setting:
Trp: 3
Trcd: 3
Tras: 8
Give me 30 mins of prime95 stability at 325 mhz and 236 mhz mem ( before playing with timings failed after 2 mins )
Strange coz the cpu can operate on this memory at lower htt,
example 245 mhz 2-2-2-6 without any problem. You have any idea why is that ?
And what you think about rising vdimm? This friday im doing psu voltmod and ill set 3.5 v for it, im wondering if that will alow me operate on 240 mhz 2-2-2 with high htt ?
__________________
CORSAIR HX 620W PSU
Old 12-07-2004, 07:50 AM   #4
Zeus
Xtreme kickass
Zeus's Avatar
Tight timings put more stress on the memorycontroller.
That's why you got higher with losse timings.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
