11-24-2004, 09:06 AM
#1
PLEASE HELP I think I fried my mobo!!
I just installed a new motherboard 2 weeks ago and now I think it's bad. I bought a new 300GB IDE Seagate harddrive last night and installed it. I went into windows(I have windows installed on another drive) and was formatting the new drive and windows locked up. So I hit the reset button and now the mobo won't even post. I unplugged the new drive just in case and still nothing.
Thanks,
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
11-24-2004, 09:57 AM
#2
Live Long And Overclock
Wow, you fried your mobo without even OCing it...Nice
How much juice(watts) does a 300GB harddrive need ??!!
Perkam
__________________
Star Trek Online Open Beta
Name: Captain Maxentius
Rank: Lt.
Ship: USS Kira
Class: Miranda-Class
Preferred Class: Akira-Class
11-24-2004, 10:03 AM
#3
Perkam
Check my sig. That's what I was running.
__________________
Corsair 620HX PSU
Heatware
11-24-2004, 10:13 AM
#4
3.4E@4.164 1.475vcore Asus P4C800E-Deluxe Rev. 2.0 droop modded & sinked
Boy was I wrong !! So I guess it ultimately gave in, though with your 2 Powerstreams, its probably not the fault of your new hard drive. (you running servers or something??)
BTW, how much did all of that COST !!!
Perkam
__________________
Rank: Lt.
Ship: USS Kira
11-24-2004, 10:15 AM
#5
Perkam
Never really added the total cost up. I use it for my home theater that's why I have all the hard drive space for movies, music, etc.
Any suggestions
__________________
Corsair 620HX PSU
Heatware
11-24-2004, 10:47 AM
#6
So I guess you should test your PSUs to see if they're all working. You should pray its a PSU problem. From what I hear, OCZ RMA is the best.
Perkam
__________________
Rank: Lt.
Ship: USS Kira
11-24-2004, 10:48 AM
#7
Originally Posted by pc ice
i installed a new hdd lst week and as soon as i hit the power button..bam psu poped..dead to the world now all from 1 added hdd..
wierd stuff can happen.
Wow that's crazy, I checked that and both PSU's seem to be working.
I just can't imagine that I fried my mobo just from this, I mean I even put everything back to stock before I put it in.
__________________
Corsair 620HX PSU
Heatware
11-24-2004, 10:50 AM
#8
Perkam
OCZ RMA is the best. I had to RMA some ram, ram ran at rated speed just wouldn't overclock that well, and they are extremely fast and nice.
__________________
Corsair 620HX PSU
Heatware
11-24-2004, 10:58 AM
#9
ocz is excelent indeed..with top notch tech support.and they have already proven to stand by there product. here's for ocz
but you'r mobo problem was probly a freak thing..mabey the board was going to die any way's hdd probly had little to do with it..
can you rma the mobo.
No cause I droop modded it  That's why I am bummed out if it is the mobo. It's only 2 weeks old
__________________
Corsair 620HX PSU
Heatware
11-24-2004, 03:57 PM
#10
You were right about weird stuff happening!!! I tried a different mobo, memory, PSU, CPU and finally GPU and still nothing. Turns out somehow my DVI cable isn't working cause I plugged a VGA cable in and BOOOOYA!!
Spent 2 hours on something stupid  Oh well I would rather replace a DVI cable than a mobo or anything else
__________________
Corsair 620HX PSU
Heatware
11-25-2004, 03:41 AM
#11
I have a stack of dead motherboards beside my comp desk..
All intel..none amd :/
I've had an IC7, an IS7, Epox 4pca3+ rev2.0 All die in my current rig.. for no
apparent reason, it's possibly just the bios chip been faulty in each..
unsure.
Sucks though
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
