XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 11-15-2004, 12:24 PM   #1
Titan7171
300htt 1/1 on K8NS-Ultra 939
hey guys whats up just got some results on this I posted a question in another thread but I dont think anyone answered anyway I figured out this mobo if anyone is interested
so the problem was that what I thought was ras in the bios was not..... so I was changing the wrong setting and they were actually 3,4,2,8 instead of 3,4,4,8......it was trp that I was suppose to change but I was changing trrd instead since it was the next one down from cas that used a small denomination.......I know I know user error [sad] but Ive never ever used loose timings......and I mean ever I always used BH-5 or CH-5 with high voltage and tight timings.........anyway all cleared up.
mobo......... K8NS-ultra with f2 bios
memory..... Mushkin 2x256 level2 V2 2,2,2,5
cpu............ winchester 3200 939
memory is getting what I guess is 2.85 volts as the bios only shows +.1 +.2 so??
[image]http://sc.groups.msn.com/tn/67/71/CPUChillin/3/38e.jpg[/image]
[image]http://sc.groups.msn.com/tn/67/71/CPUChillin/3/38d.jpg[/image]
as you can see the cpu speed really makes a difference.......Ill be testing more today and tonight to see if I can lower the timings.......this memory feels real strong and to tell you the truth I think itll keep going but the mobo maxes out at 300 310 gives me a reboot right before windows and that was with a light cpu/memory overclock (5/6) so who knows?? right now Im running 260x10 becuse thats my cpu sweetspot so far as all I got on this mobo is 1.7v and it only showing as 1.64v so its undervolting
__________________
Phenom 965 BE@4.2ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus M3A79-T Deluxe
ht 2200mhz / nb 2800mhz
2x2gb Gskill ddr1066 5,5,5,15,24,2T
Sapphire 4850x2
Enermax Infinity 650 crossfire
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
23,942 06 Phenom 965@ 4.5ghz Sapphire 4850X2@700/1150
13,954 Vantage, Phenom 940 4.1ghz Sapphire 4850X2@700/1180
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Titan7171 is offline   Reply With Quote
Old 11-15-2004, 01:47 PM   #2
Titan7171
some informed me I used the wrong multi....sorry about that! I didnt know
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.61ghz water
Old 11-15-2004, 02:01 PM   #3
JWB
JWB's Avatar
Send a message via MSN to JWB
You should not have used a half multiplier. Try again with a full multi, like 8 and you ram will be running 1:1 then . Ram does not run 1:1 with half multies on A64/FX's.
James
__________________
In 1998 a senior Intel architect told us that even given the power of Moore's Law, its chips would be unable to deliver the power of the brain of a bumblebee by 2012.
JWB is offline   Reply With Quote
Old 11-15-2004, 02:37 PM   #4
Titan7171
James
I know someone let me know on another forum.........the thing is 300x8 on the cpu is so low so I used the 8.5 to get the cpu up some..........anyway Ill be doing it tonight........thanks for the info
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.61ghz water
Old 11-15-2004, 02:50 PM   #5
misteroadster
misteroadster's Avatar
your motherboard and BH5 support 350 FSB 3D stable
__________________
8Days/8Wr
*OverClocking-Masters.com 3D Team
Cooling Caskad'Chill : concept by mister, made by Skirms&Pgeo.
1700+ Cpu-Z SS 3227Mhz/SD 3700 Cpu-Z SS 3704Mhz/E6600 Cpu-Z SS 5104Mhz
E6600 Results : 10.09s Pi 1M / 714 CpuMark / 3DM2001 : 68061 7900GT air / 76280 7950 Gx2 stock cooling
misteroadster is offline   Reply With Quote
Old 11-15-2004, 03:02 PM   #6
Titan7171
a little more info would be greatly appreciated.........maybe a nudge to the right thread
__________________
Asus M3A79-T Deluxe
Sapphire 4850x2
4.61ghz water
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
