XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Competitions
Reply
Old 02-08-2004, 10:01 PM   #1
luihed
Overkill
luihed's Avatar
Where can I find the vgpu mod?
Ived search everywhere and I cant find the vgpu mod for this thing.......
The only mod ive seen so far is the VDDQ mod by Holst, does that increase the vgpu?
Also where do you measure the vgpu from? Thanks....
__________________
E8400 DFI LP P35T2R Ballistix
8800GTS PCP&C 1.2kw Raptors
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
luihed is offline   Reply With Quote
Old 02-08-2004, 10:35 PM   #2
MrIcee
Xtreme Legend
MrIcee's Avatar
The GPU mod can be found in this thread On the second page you'll see menthol mooses mod which I adopted on my own card after doing it the way you'll see it on page 1 of the thread.
Randi
MrIcee is offline   Reply With Quote
Old 02-09-2004, 09:37 AM   #3
TheDogFather
TheDogFather's Avatar
Re: Where can I find the vgpu mod?
Are these the same mod, they seem to be to me.
I'm willing to try some stuff, but the only clear mod is the one reffered to as vddq, done by several people in that thread but clearest in Holsts pic on the first page.
TDF.
__________________
Infinity XP1700 247x9
2x256Mb PC3500 Mushkin Level II 11-2-2-2-2-13-15
Phase change in (slow) progress.
TheDogFather is offline   Reply With Quote
Old 02-09-2004, 11:03 AM   #4
Vlad Draculea
Banned
Vlad Draculea's Avatar
no help or aclarations about vmods needed.
Vlad Draculea is offline   Reply With Quote
Old 02-09-2004, 12:26 PM   #5
luihed
Overkill
luihed's Avatar
Thanks guys but im still confused here lol....... so vddq and vgpu mod is the same right? Ive done this mod and set the vr at 68ohms and it didnt help me get a higher overclock, also where do you measure the vgpu from?
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 02-09-2004, 01:30 PM   #6
TheDogFather
Thanks again Vlad, I did have them confused, the one you linked to is the one (vgpu) I'm about to do, but thought it was the vddq mod.
Its hard when your new to this, everyones using acronyms and terms I've never heard let alone understand.
luihed, it seems vgpu and vddq are two differant mods, the one Vlad linked to is vgpu, is this the one you have done ?
Not sure what the vddq one is, I'll read through that thread again.
TDF.
__________________
Old 02-09-2004, 06:52 PM   #7
luihed
Overkill
luihed's Avatar
Yes thats the mod that I did and I set the vr to 68ohms like he said..... but Ive looked everywhere and I cant find where your suppose to measure the vgpu..... im using a 1k vr so I have to be sure on how much voltage is being affected with each movement........ so far with teh mod I got the card up to 270 on air.....
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 02-09-2004, 07:23 PM   #8
TheDogFather
I just did mine and the card still works so it looks good. I set mine to 68.1
I still can't figure out any other mod.
TDF.
__________________
Old 02-09-2004, 07:32 PM   #9
luihed
Overkill
luihed's Avatar
Did it make much difference in your OC? What voltage are you getting with the vr set to 68ohms?
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 02-09-2004, 09:16 PM   #10
TheDogFather
I havn't got a clue where to measure the voltage either.
And my overclock seems worse if anything.
TDF.
__________________
Old 02-09-2004, 10:43 PM   #11
Nico
This is the Vgpu mod
You measure Vgpu from the back of the oictured mosfet, to gnd.
__________________
A64 3700+ @ 3105/258 1.85v VapoLS
K8NNXP 12c bios K8Npro
2 x 256 Twinx 3200LL 2-2-2-6 3.4v
Albatron 6800GT VapoPE cooled
Nico is offline   Reply With Quote
Old 02-09-2004, 10:55 PM   #12
TheDogFather
The back being the silver bit showing from behind it ?
Could these cards act differant, in as much as 68 ohm gives some people more core voltage but not others ?
Its warmer than the last time I ran the bench, but at 250/250 I get kicked out of 3dmark, where I didn't before.
TDF.
__________________
Old 02-10-2004, 01:20 AM   #13
luihed
Overkill
luihed's Avatar
Thanks Nico ..... that really helps alot.....
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 02-10-2004, 03:18 AM   #14
Nico
TDF.
Yes, and the other probe to any ground.
TDF.
If you have removed the little SMD resistor, then you'll want to wind up the resistance to around 78ohms and higher.
Glad to be of assistance
__________________
Old 02-12-2004, 10:13 PM   #15
TheDogFather
I've been adjusting the resistance tonight, got the voltage up to 2.15v but it doesnt seem to make any differance, I'm still stuck around the 250/250 mark.
I don't seem to have gained anything.
The card doesnt seem to be getting too hot.
TDF.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
