XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 01-11-2004, 12:22 AM   #1
DrDemonic
Banned
2.7gigs on air cooling
Hello everyone, i consider myself to be the sickest ocer on air. With my nf7-s and my 1700xp dl 0310 xpmw, i acheived 2.7gigs on air. I live in NYC, and its freakign cold here this 2am morning. my pc is next to my window, i have 2 huge intake and, and 1 smal lexausht and 1 big blowhole. here are hte pics, enjoy, i score 10,100 on sandra, my next step is 2.8, 2.8 , then 3.0, but i need better ram on my hands first.
DrDemonic is offline   Reply With Quote
Old 01-11-2004, 12:24 AM   #2
Maxvla
Maxvla's Avatar
Send a message via AIM to Maxvla Send a message via Yahoo to Maxvla
better do it fast before it starts to warm up again.
btw what sink/fan are you using?
__________________
A64 3200+ Newcastle 2.2ghz
Asus K8V SE Deluxe
2x512 Mushkin BH5
Tyan Tachyon G9800pro
NEC 8x DVDRW
Liteon 52x CDRW
2x160gb Maxtor 7200
Chaintech AV710
Lian Li v1000
Maxvla is offline   Reply With Quote
Old 01-11-2004, 12:26 AM   #3
DrDemonic
Banned
slk900 and smart fan II from TT
Old 01-11-2004, 12:27 AM   #4
DrDemonic
Banned
my normal setting is at 2.4 gigs, i can go to 2.5 or maybe even 2.6 on normal air temp, but ineed better ram since my mobo does not like multiples that r too high. at 2.4 my cpu temop on normal air temp is aobut 20c.
i feel lieik my thumb has frostbite, the blowhole on top my case was blowing way below freezing air, that cold air plus the 150cfm speed it exists at, prob makes a windchill of like -50c, im soaking my hand right now in a bucket of really hot water. rofl, i think im a sick addicted ocer. this chip really helps out as well, best ive seen. on normal air temps, i cna do 2.4-2.5 no problem, but ijsut pc3200 ram running 200fsb, i cant run muc hhigher then that, and my nf7-s mobo doesnt liek 200fsb with real high multiples. hopefully next week i will get real fast ram so i would be able to hit 3gigs+ on air.
Old 01-11-2004, 12:58 AM   #5
Maxvla
Maxvla's Avatar
the 947 or SP94 + 92mm tornado would probably give you a 3-4 C drop given your conditions.
Old 01-11-2004, 12:59 AM   #6
gkiing
gkiing's Avatar
argh..
I used to have an Athlon 1700+ JIUHB 0310 XPMW.. 2310mhz @ 1.6v (defualt 1.52). I sold it and upgraded to a Barton 2500+ AQZEA, which is crap in comparison, it takes 1.9v to hit that. I was getting better 3dmark scores with the tbredb. Im surprised you could manage that on air cooling. Nice job on the overclock! Get that machine folding stat!
__________________
AMD 1700+ @ 2850Mhz 1.95v (24/7 Setting) || ABIT NF7-S v2.0 ||2x256MB KHX3200 || 120GB Seagate 7200.7 SATA/80GB 7200.7 IDE|| 9800Pro || R22/R170 (Ethane) Cascade -80C Loaded
I reject your reality and substitute my own
gkiing is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
