XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 11-26-2009, 10:06 PM   #1
miahallen
World Champion - IRONMODS
miahallen's Avatar
USB 3.0 finally tested
http://www.xtremesystems.org/forums/...08#post4128308
__________________
THE POST COUNTER IS NOT AN INTELIGENCE METER!
Ross: "Gautam or Vince? I think if we just wave an open thermos of LN2 under their noses, they'll go into a trance and we can extract whatever information we need without having to resort to force LOL"
Gautam: "I remember when Mark started doing DI I thought he was psycho and that it was a dangerous, reckless cooling method that had no future."
www.ironmods.com
Heat
miahallen is offline   Reply With Quote
Old 11-27-2009, 12:29 AM   #2
Bodkin
Xtreme Lurker
Bodkin's Avatar
Cheers for the review! Looks like you put in a lot of effort, and I found it very informative
__________________
CPU: i7 920 d0 4.20ghz
Mobo: Asus Rampage 2 Gene
GPU: HIS 5870 + EK 5870 Acetal
Sound: Xfi gamer + Logitech Z5500
Storage: Intel X-25M g2 160GB + 2x1TB f1
Case: Corsair Obsidion 800D
PSU: Corsair HX850
Cooling: Swiftech XT, MCW-NBMAX, MCP355, ThermoChill PA120.3 (15mm)
Screens: Dell U2410
Bodkin is offline   Reply With Quote
Old 11-27-2009, 12:53 AM   #3
miahallen
miahallen's Avatar
Cheers
__________________
www.ironmods.com
Heat
Old 11-27-2009, 11:49 AM   #4
FlawleZ
FlawleZ's Avatar
Send a message via AIM to FlawleZ
Great review and testing mia. I too was anxious to see some real world performance numbers for USB3 and while the performance doesn't seem to be as strong as I was hoping for, it still shows promise that with some further refinements to drivers and potential chipset interfaces that USB3 should mature well. As you said, hopefully more manufacturers will make an effort to supply this technology to the consumer sooner than later.
__________________
Phenom II 720 BE @ 3525Mhz
MSI 790FX-GD70
4GB OCZ Reaper 1333 DDR3 CAS6 6-6-6-16
Sapphire Vapor X HD 4890 1GB
WD VelociRaptor 150GB
WD Caviar Black 640GB
Mad Dog X-Connect 600W
Thermaltake Shark
FlawleZ is offline   Reply With Quote
Old 11-27-2009, 01:01 PM   #5
highoctane
I am Xtreme
Looks like allot of work went into the testing!!!
usb3.0 can't get here fast enough, ext 2tb drive plus usb2.0 is like getting waterboarded!!!!
__________________
Work Rig: Asus x58 P6T Deluxe, i7 920 20x200 1.425v HT on, BIX2/GTZ/D5
3x2048 GSkill pi Black DDR3 1600, ECS 9600GT
PCPower & Cooling Silencer 750, CM Stacker 810
Game Rig: Asus x58 P6T, i7 920 20x180 1.275v HT on, TRU120
3x2048 GSkill DDR3 1333 7-7-7-18, MSI GTX260 OCv2
PCPower & Cooling Silencer 750, CM Stacker 830
AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
2x1gb Ballistix DDR2 800, PowerColor 4850
Corsair VX450
highoctane is offline   Reply With Quote
Old 11-27-2009, 02:21 PM   #6
Computurd
Computurd's Avatar
i think it would be unfair to judge the usb 3.0 spec according to running it on a p55 board. this board was not designed for it. when there is an actual chipset that it is not hacked onto, you will see great results.
__________________
"Lurking" Since 1977
Computurd is offline   Reply With Quote
Old 11-27-2009, 03:26 PM   #7
miahallen
miahallen's Avatar
That's what the "Turbo" results represent, they bypass the P55 chipset completely, and interface directly with the CPU via the PCIe bus
Having said that, I do think this technology will continue to mature and improve over then next year or two, this is still the "beta" IMHO
__________________
www.ironmods.com
Heat
Old 11-28-2009, 08:57 AM   #8
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
good read! bump
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 11-28-2009, 10:27 AM   #9
benko
benko's Avatar
Send a message via MSN to benko
Excellent read, well done miahallen
__________________
Q6600@4.0GHz,500gb hard (7200.12, single platter),4GB Mushkin ram@1100 cl5, corsair520w hx(modular), ATi 4870 1GB oc840/950(3800)
benko is offline   Reply With Quote
Old 11-29-2009, 07:05 AM   #10
miahallen
miahallen's Avatar
Thanks again guys
__________________
www.ironmods.com
Heat
Old 11-29-2009, 07:14 AM   #11
Hardass
One of the First.
Hardass's Avatar
Good review.
__________________
HEATWARE
Team 32
Hardass is offline   Reply With Quote
Old 11-29-2009, 07:57 PM   #12
saaya
Xtreme X.I.P.
saaya's Avatar
wow, hardass you're still around!
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
