11-25-2009, 11:04 PM
#1
DA BOX ready for pre-order !
Lan Gear DA BOX 100 is ready for pre-ordered !
http://www.lan-gear.com/orders.php
I have been following this little case since it was announced, and damn!
The top 5 features (IMO):
Dimensions: 8.6" x 11.4" x 14.6"
Compatible with long graphic cards up to 340mm long
1.5mm Aluminium Chassis, 2mm Aluminium Cover
Compatible with extra long ATX power supply (up to 7.5" with 262mm long video card)
Compatible with heatsinks as high as 190 mm
__________________
E8400 @ 425x9 1.168V
4GB D9MGH Mix (4x1GB) @ 510MHz 5-5-5-15 2.05V
HD4850 @ 730/1070
♥ BFBC2 Beta
Addicted to dog tags!
11-25-2009, 11:24 PM
#2
Really a nice box. Been following the forum for some time. To me it seems like the perfekt MicroATX enclosure.
__________________
Intel E8500 with Thermalright Ultra120eXtreme @ 3,6Ghz
Asus P5E-VM HDMI
Antec P180 Mini
11-25-2009, 11:40 PM
#3
Second that, it beats the crap out of every single competitor in every way!
__________________
HD4850 @ 730/1070
♥ BFBC2 Beta
11-26-2009, 12:02 AM
#4
Hardware addict
I'll take the P180 mini over something that's called "da box" anyday. The heat buildup will be pretty bad as well, although not quite as bad as in the Lian Li V350.
__________________
Antec P180 Mini - DFI JR X58 T3H6 - Xeon W3570 - 6GB G.Skill 1333C7 - TRUE120 lapped & modded - GTX285 - Intel X25-M (G2) & Samsung F1 640GB
11-26-2009, 12:27 AM
#5
Lian Li V351 going out when this box is comming in EU
__________________
MAIN PC: CPU: Intel Core 7 920 D0 , HK Evga SLI MCRO X58, RAM: Corsair Dominator DDR3 1600MHz 6GB, GFX: Asus 4870x2 2GB, OS HDD: Areca ARC-1231ML + 2x Intel 160GB G2 SSD , Case Lian Li PC-v351.
FILE/MEDIA Server: HK: Asus Striker Extreme , CPU: Intel Core 2 Duo E6850, Raid card: Areca ARC-1680IX-16 , NORCO RPC-4220 , OS DISK WD Scorpio Black 160gb , 4gb DDR2 , 10x WD1001FALS Raid 6
11-26-2009, 12:35 AM
#6
I agree that the name sucks, but who cares? The name means nothing. I have the P180 Mini and Im looking forward to gettin rid of it. Its a good case but its not a small case. I dont think the heat buildup is gonna be much worse than the P180 Mini. But I guess we will know when the reviews are out.
__________________
Asus P5E-VM HDMI
Antec P180 Mini
11-26-2009, 12:38 AM
#7
where do the HDDs go?
11-26-2009, 02:07 AM
#8
BakerT i see you are form DK like me  They take pre-orders from EU/DK too, but the shipping cost is 55EUR if one wants delivery around Dec 18th.
__________________
HD4850 @ 730/1070
♥ BFBC2 Beta
11-26-2009, 02:13 AM
#9
Hardware addict
Basically this is an imporoved V350.
But with only one 120mm exhaust airflow is not that great. And I doubt you can fit a fan on the side of the case, internally at least. The 180 mini has a 200mm and at least one 120mm, with the option to add more. Da box is so small it will have heat issues like the V350 as soon as you have cables going everywhere, cards installed etc.
For a non overclocked system it will be good though, and it seems that it can house a pretty big cooler so it's not that bad. But speaking from experience using anything but the P180 mini has proved to be impossible with a decent overclock.
__________________
11-26-2009, 02:26 AM
#10
Well i prefer size over extreme overclock, and at least Wolf at 4GHz should not be a problem.
I fail too see the point with the P180 Mini, it too big, i would prefer a A05 that is roughly the same size and a full size ATX mobo.
But let the reviews speak before we conclude anything.
__________________
HD4850 @ 730/1070
♥ BFBC2 Beta
11-26-2009, 03:42 AM
#11
Mini P180: 40 l
Da Box: 23 l
Comparable?
11-26-2009, 03:59 AM
#12
Xtreme Mentor
Originally Posted by Mats
Mini P180: 40 l
Da Box: 23 l
Comparable?
+1 why are people comparing a case near enough 2 times larger :/....
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
11-26-2009, 06:03 AM
#13
What's the weight on it?
edit*
Specifications Features
Type: Micro ATX desktop Compact and portable (bag available in option)
Case Material: 1.5mm Aluminium Chassis, 2mm Aluminium Cover 100% aluminum case (frame, chassis, ...)
Power Support Full ATX (Not included) Brush aluminum finish
Motherboard Compatiblity Micro ATX, Baby AT Removable motherboard tray
Side Panel Window Optional 2 x 120mm exhaust fans (pre-installed)
External 5.25" bay 1 2 x 92mm intake fans (1 pre-installed, 1 optional)
Internal 3.5" Drive Bays: 2 Compatible with heatsinks as high as 190 mm
Internal 2.5" Drive Bays: 4 Compatible with long graphic cards up to 340mm long, thus including HD5870, HD5890, HD5870X2, HD5970...
Expansion Slots: 4 Compatible with ATX power supply
140mm Fans 1 x 140mm side Fan (See Model Description) Compatible with extra long ATX power supply (up to 7.5" with 262mm long video card)
120mm Fans 2 x 120mm Rear Fan (See Model Description) Hand screws
92 mm Fans 1 x 92mm front fan ( + 1 x 92 mm side fan optional) Anti theft system
Dimensions 8.6" x 11.4" x 14.6" Compatible water cooling
Weight 7 lbs matched optical drive bezel
Available color Black (anodized)
Manufacturer Warranty 1 year
11-26-2009, 06:06 AM
#14
7lbs
__________________
HD4850 @ 730/1070
♥ BFBC2 Beta
11-26-2009, 06:13 AM
#15
Xtreme Cruncher
Cute.
Do you know if other colours will be available?
Would like maybe a yellow one.
__________________
Gunning for a Poem top 30 spot.......Slowly aiming for the No 1 Brit spot.
Xtreme DC rebel!!!
We eat pie not count Pi
#16
Looks like a great case but far too expensive for my blood.
__________________
Case- CoolerMaster HAF
PSU- Kingwin Mach1 1220watts
Mobo- EVGA 780i
CPU- Intel Q9450
CPU Cooler- CoolerMaster Hyper 48
Ram- Corsair Dominator 2gig x 2gig
GPU- GTX 260s in SLI
Sound- X-Fi Platinum
Storage- W.D 36gig Raptor, W.D 500gig
Cooling- Air 7 x 120mm, 1 x 180mm, 1 x 250mm fan(s)
OS- Windows Vista 64 bit
Keyboard- 1st Edition G15
Mouse- Razer DeathAdder(Armadillo cable management)
11-26-2009, 06:19 AM
#17
Xtreme Cruncher
"Cooling- Air 7 x 120mm, 1 x 180mm, 1 x 250mm fan(s)"
Blimey, what time is lift off?
They all quiet fans?
__________________
Xtreme DC rebel!!!
11-26-2009, 07:11 AM
#18
Originally Posted by vaio
Cute.
Somewhere in the Hardforum thread they wrote the could do any color on request at no extra charge.
__________________
HD4850 @ 730/1070
♥ BFBC2 Beta
11-26-2009, 07:31 AM
#19
Hardware addict
Comparable?
Of course, they target the same market. I'm offering an alternative because I know how it is to overclock cramped mATX builds, from experience. And obviously comparing just the "l" makes no sense. How about the width of this thing?
By the way, I find the wide design of cases like this and the V350 actually more cumbersome than a slimmer, higher case. But that's personal I guess.
__________________
11-26-2009, 07:45 AM
#20
Xtreme Cruncher
The p180 mini is only about 4" shorter than my TJ06, and probably the same compared to the original p180. My antec 300 is smaller than the p180 mini. Its the biggest mATX case I've ever seen. Something like the box is more size appropriate.
Think of the nzxt rouge.... it was 16.6" x 10.9" x 14.5". WTF. That's massive.
If you look at the GMC R-3 Corona, Its smaller than most cases period (not thinking slim itx cases) and holds a full ATX board and WILL hold a Mugen 2 inside.
While there are some improvements to me made with this design, its moving in the right direction. With i7 and very OC'able mATX boards, this is a dream for a lot of people, or at least getting there.
__________________
Server:
Q6600 @2.4ghz / P5K Deluxe / 2x2gb DDR2 800 / Raptor 150gb / Antec 300 / Cooler Master Hyper 212 Plus / 8800gts g92 Laptop: Lenovo X200
P8600 2.4ghz / 2x2gb DDR3 1066 / 160gig Hitachi (for now) Gaming Rig:
PII 945 @ 3.75ghz / MSI K9A2 Platinum / 2x2gb G.Skill DDR2 1000 / OCZ Agility 120gb / TJ06 / Mugen 2 W/ 1850rpm GT / GTX260 core216
11-26-2009, 07:48 AM
#21
Xtreme Cable Management Freak
anyone gonna water cool that sucker? would be nice to run a H50 for CPU and maybe a double installed for the GPU? anyone know if that will fit/work?
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
11-26-2009, 07:57 AM
#22
Hardware addict
Never heard of it, will check that out.
Oh yes, like I said this is an improvement over the V350 which has a similar appearance (but is slightly smaller iirc).
__________________
11-26-2009, 12:46 PM
#23
Not the same market, there is a distinct difference between µATX towers and cube cases, and it's been like this since the first cube cases showed up.
Most people who worries about the cooling capacity would go for the tower. The mini P180 is even big for being a µATX tower.
Comparing the case volume is quite common. Just check out the mini-ITX cases hysteria.
Even though some people here aren't familiar with SI units, it does give a picture of the difference in size
11-26-2009, 01:07 PM
#24
The case is too empty. Where are the designs? Mine as well just buy an aluminum box and call it "Da Box". The PSU being on the front removes any ideas for drivebay accessories as well as modding. The SG02 maybe longer, but it is atleast easier on the eyes.
11-26-2009, 01:53 PM
#25
Cute.
4 Models are available, these are, black, black, black and black.
I like this, it's nice and compact.
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
