XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 11-25-2009, 05:39 PM   #1
Katanai
Katanai's Avatar
ASUS P6X58D Premium motherboard now available
"Eager to get in all the USB 3.0 hard drives, SSD drives and... other hard drives cropping up these days? Then you're in luck, as ASUS' brand new, USB 3.0-ready P6X58D Premium motherboard is now finally available to order. Of course, being an early adopter doesn't come cheap, and this particular motherboard will run you a hefty $309.99 from Newegg. That will get you a board that runs with the best of 'em, however, including support for a Core i7 processor, room for up to 24GB of RAM, three PCI-Express 2.0 slots, a pair of 6Gb/s SATA interfaces, four plain old USB 2.0 ports and, most importantly, two for USB 3.0. Setting up a rig? Feel free to let us know how it works out in comments."
LINK
newegg
They changed the heatsink on this. I love it! It looks much more clean and professional. Guess what I'm buying next week? Can't wait to see how it ocs...
__________________
Alden Whitman. How do you rank yourself among writers (living) and of the immediate past?
Vladimir Nabokov. I often think there should exist a special typographical sign for a smile—some sort of concave mark, a supine round bracket, which I would now like to trace in reply to your question.
Nabokov V. Strong Opinions. April 1969 interview. : ) ©
Katanai is offline   Reply With Quote
Old 11-25-2009, 05:50 PM   #2
Russian
Russian's Avatar
Looks like a nice board.
__________________
Originally Posted by FUGGER View Post
I am magical.
Russian is online now   Reply With Quote
Old 11-25-2009, 05:58 PM   #3
Ozzfest05
Ozzfest05's Avatar
I think the first p6t failed enough to turn most away until some people start posting reviews, not benching, and for a 24/7 power house why not more sata ports? those other two should be beside the othe 90 degree sata ports.
Good 8 Pin placement though I like to see something logical and cmos battery is in a good place too so thumbs on that.
__________________
Case: CM HAF
PSU: Corsair HX1000W
mobo: Rampage Extreme!
CPU:E8600 @ 4.4ghz 1.23 volts (Batch Q820aA405)
RAM: G Skill 1600 mhz DDR3 @ 7-7-7-18-1T stock OC'ed to 1960 mhz 8-8-8-26-1T
Graphics:4870x2
Cooling:H20 Apogee Gtz+Black Ice Tripple Rad
OS: XP 32
Bench Rig
Case: Antec 1200
Mobo: DFI LP DK P45 T2rs+
Ram: OCZ 800 mhz @1100+
CPU:E8500
PSU: Ultra 700w
CPU Cooling: Single Stage
Video Card: 9800gtx
Ozzfest05 is offline   Reply With Quote
Old 11-25-2009, 06:14 PM   #4
Chrono Detector
Chrono Detector's Avatar
Looks alright, but why did ASUS put the extra 2 SATA ports facing vertically instead of horizontally like the others? Other than that it looks nice, colour scheme isn't too bad.
__________________
PC1:
PC2:
Chrono Detector is offline   Reply With Quote
Old 11-26-2009, 12:24 AM   #5
Katanai
Katanai's Avatar
Why not? If you're gonna use more than 6 Drives it will be almost impossible to keep it 100% clean so it doesn't really matter if the other 2 will show some cables...
__________________
Old 11-26-2009, 12:27 AM   #6
affiliate13
affiliate13's Avatar
Send a message via MSN to affiliate13
I wonder who will be 1st with waterblocks for this?
__________________
ASUS Rampage II Ex 1504
Intel i7 920 D0 3850A795
Sapphire HD5970 EK FC 1Ghz/1150Mhz 1.237v
OS Intel X25-M RAID0
Data 500GB Seagate Barracuda 7200/32Mb
OCZ Reaper 6GB/1800/C8
BeQuiet Dark Power Pro 1200w
1X 18w DDC3.2 w/XSPC Res Top
1X 18w DDC3.25 w/XSPC Res Top
1X XSPC Submersible Pump/Res w/RS120mm
HW Labs GTX480 4x120mm
TFC Monsta 6x140mm
EK Supreme LT 3/8" Feser Tubing
EK IOH/SB and Mosfet Blocks
Lian Li V2110 w/EX-34
26" Iiyama Prolite
affiliate13 is offline   Reply With Quote
Old 11-26-2009, 01:09 AM   #7
HKPolice
HKPolice's Avatar
I wonder how the PCIe lanes are split between the onboard chips.
X58 has 36 lanes, 32 are used for the 3x 16x Slots, so the remaining 4 are split between: 1x PCIe, 2x Marvell Gigabit NIC, 1x Marvell SATA3 chip, 1x USB3 chip.
Unless both Marvell NICs are sharing 1 lane, I don't see how they could all fit.
HKPolice is online now   Reply With Quote
Old 11-26-2009, 01:15 AM   #8
Kondik
The Power of Dreams
Kondik's Avatar
Good point. No NF200, no nothing. Maybe it will switch the PCIE to 8-8-8 aka 24 when more than 1 card is installed.
__________________
|I kinda sold the whole PC by mistake. a PDA is all that i Have Left|
Kondik is offline   Reply With Quote
Old 11-26-2009, 01:18 AM   #9
K404
Xtreme Mentor
K404's Avatar
Dont like the PCI-E placement, assuming same colour= full speed
WHY ARE COMPANIES STILL RELEASING.....AFTER 5 YEARS..... SLI+CF BOARD WITH SINGLE SLOT SPACING FOR 2-WAY SETUPS?
Should ONLY have to compromise for 3+4 way
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
K404 is offline   Reply With Quote
Old 11-26-2009, 08:15 AM   #10
sholvaco
The bolded ones are hooked via SB lanes (PCIe 1.1, six of them).
Pretty board, but they fubared the PCIe x16 slot spacing for me compared to the current P6T deluxe (which can still run dual graphics and raid). I say leave the triple VGA stuff for enthusiast boards and provide some breathing space for setups that aren't going to be run on a bench.
sholvaco is offline   Reply With Quote
Old 11-27-2009, 02:20 PM   #11
Think
Think's Avatar
Question
This board is no where to be found on the Asus website.
__________________
Asus P6T
Saphire 5870
OCZ RAM OCZ3G1600LV6GK
Enermax Evolution 850W
I7 920
Think is offline   Reply With Quote
Old 11-27-2009, 02:46 PM   #12
sholvaco
http://www.asus.com/product.aspx?P_I...ukj&templete=2
You sure?
Old 11-27-2009, 04:53 PM   #13
IronWarrior
IronWarrior's Avatar
Nice looking board, shame it only has 3 PCI-E x16 slots.
__________________
IronWarrior is offline   Reply With Quote
Old 11-27-2009, 04:55 PM   #14
Gen
Xtreme Cruncher
Gen's Avatar
the point their making is that it would still look cleaner and it would, all sata cables in 1 spot and you can zip tie them together, etc.
most newer cases come with motherboard cutouts near the areas where a normal mobo would have the sata ports, in those cases you would have to run the cables in a different way or up to where the other sata cables are. even if there were cutouts near the bottom in some pc cases it would still clean up the bottom of the mobo making it look 'cleaner' and tricking your eye into seeing less sables especially when bunched up.
really with so many mobo choices people can be really picky if they like.
Gen is offline   Reply With Quote
Old 12-01-2009, 07:58 PM   #15
Oupavoc
Oupavoc's Avatar
IIRC those are SAS ports.
__________________
My System: Case: CoolerMaster ATCS 840, Cpu: Intel Core i7 D0, Motherboard: Asus Rampage II Extreme, GPU: Visiontek 4870X2, Memory: 6GB Corsair Dominator, Hard Drive: WD Caviar Black 640GB Raid 0 2TB Storage, PSU: Corsair HX1000W, CPU Heatsink: Custom H2O, Sound Card: Asus Xonar Essence STX, Display: Samsung 24" 2493HM, Speakers: Logitech Z-5500, OS: Windows 7 RC
Oupavoc is offline   Reply With Quote
Old 12-01-2009, 08:27 PM   #16
Zigosity
Zigosity's Avatar
They're labeled SATA on the PCB.
That being said, I don't particularly care that they're over there on their own, since I'd never use that many anyway. Huzzah for storage servers. This looks like a really neat board!
__________________
Asus P5Q3 Dlx || Q9450 @ 3.6GHz || OCz DDR3 ReaperX 2x2Gb 1333 6-5-5-20
2x Sapphire HD4850 CrossfireX || WD VelociRaptor 300GB || Antec Quattro 1kW PSU
Cooling:
D-Tek FuZion v2 || Swiftech MCR320 || MCP355 w\ XSPC Res Top || Scythe S-Flexes || Indigo Xtreme TIM (Amazing stuff, this...)
Zigosity is offline   Reply With Quote
Old 12-01-2009, 08:39 PM   #17
zanzabar
I am Xtreme
zanzabar's Avatar
that was on the original board were thats were the sas were, this one has usb3 and sata6. so the blue are 6xich10r the white are 2x marvel sata6
as for slots the usb and sata6 are on the same chip and they are speced for 1x pci-e 2.0 so i doubt that things will be working as the speed that they are meant to using sata6 or more than 1 usb3 port
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is offline   Reply With Quote
Old 12-02-2009, 07:33 AM   #18
Katanai
Katanai's Avatar
I don't think so man. The 3 PCIE slots work in either 16/8/8 or 16/16/1 plus the 1x PCIE so that leaves at least 2 PCIE lanes for SATA 6GB and USB 3.0. I think they should work more or less at their intended speed. The thing is though this still isn't available here. ( I'm starting to loose my patience, maybe I will get the gigabyte UD7 board.
__________________
Old 12-26-2009, 10:25 AM   #19
dook43
Hmm.. this looks like it fixes all of the problems with the R2E. Anyone willing to trade?
dook43 is offline   Reply With Quote
Old 12-29-2009, 07:50 AM   #20
miftahbanjar
miftahbanjar's Avatar
Send a message via Yahoo to miftahbanjar
a nice board from asus
__________________
Asus P6T Deluxe, Intel i7 920 D0-SLBEJ, Prolimatech Megahalems + SmartCaseFanBlueLed 120 Thermaltake,
OCZ Blade Triple PC16000 6Gb, MSI R4890 T2D1G-OC, WD Caviar Black 1TB + Seagate 7200-250gb,
HX850 Corsair, BenQ G2410HD, Pioneer DVR-217
miftahbanjar.com
miftahbanjar is offline   Reply With Quote
Old 12-29-2009, 08:18 AM   #21
highoctane
I am Xtreme
I like it, if I where going to buy an x58 today that just might be the one!
__________________
Work Rig: Asus x58 P6T Deluxe, i7 920 20x200 1.425v HT on, BIX2/GTZ/D5
3x2048 GSkill pi Black DDR3 1600, ECS 9600GT
PCPower & Cooling Silencer 750, CM Stacker 810
Game Rig: Asus x58 P6T, i7 920 20x180 1.275v HT on, TRU120
3x2048 GSkill DDR3 1333 7-7-7-18, MSI GTX260 OCv2
PCPower & Cooling Silencer 750, CM Stacker 830
AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
2x1gb Ballistix DDR2 800, PowerColor 4850
Corsair VX450
highoctane is offline   Reply With Quote
Old 12-29-2009, 08:21 AM   #22
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
looks nice, the sticker below the nb heatsink looks lame imo, but besides that... looks great!
power and reset buttons are in a bad spot though, and no onboard buzzer is a bit weird... so no beep codes... and theres no debug led either... so how are people going to know whats wrong, in case theres a problem? and only one bios chip? that sucks for an extreme board...
those things should be connected via the sb, not x58 ioh.
its most likely
16
16/8
0/8
and they used the extra ioh links for the usb3 controller...
everything else is connected to the sb i think
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 01-02-2010, 04:13 PM   #23
tripgood
tripgood's Avatar
Picked one of these up a week ago and I like it. Of course it doesn't have the features of high end x58's but it is easy to work with and I got it to try out new storage systems, not for benching. One thing I like is that you can set the lane configurations in the bios for the pciex16 slots. With 3 devices installed, you can choose x16, x16, x1 or x16, x8, x8. Very helpful feature.
__________________
tripgood
Big hardware pile
tripgood is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
