XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 11-25-2009, 05:07 PM   #1
Lucky_n00b
nobody
Lucky_n00b's Avatar
Some 2D test with X2 550BE and Gigabyte MA770T-UD3P
Hi everyone,
This is one of my attempt on Hwbot Country Cup 2009 3rd Stage with my friend Coldest, desperately trying to catch up with the 955BE/965BE's (and FAIL miserably LOL )
This is the rig
AMD Phenom II X2 550BE
Gigabyte MA770T-UD3P, F5D BIOS * Thx Mr. Benny from Gigabyte Indonesia *
G.Skill PerfectStorm 2200C8 2x2GB
MSI GT240
Enermax Revo85+ 1050W
CoolerMaster Test Bench v1.0 * Thx CoolerMaster TW *
CPU WoodPot v1.0
15L of LN2
* For anyone that's curious, 'Daerah Berbahaya' sign there means 'Dangerous Zone' *
Insulating (OK, I admit that I overdid it a little )
Insulating - backside
The pouring start
Too bad I've only got a small 15L LN2 Dewar, so it's really time limited, as this is the 1st time I put LN2 on my X2 550BE. So I just do a 'quick-and-dirty' run with it, tried to get as much clock as possible, without considering the efficiency.
This is the best SuperPI 32M I got :
http://hwbot.org/result.do?resultId=924965
The system has already became very unstable at the moment, look at the CPU-Z memory tab(it showed 600MB, not 4096MB)
also The efficiency was a bit 'off',
- NB Freq probably can be pushed more
- RAM Frequency and Timing still can be tweaked
- Maybe the CPU still have 50Mhz-75Mhz more?
- OS not too optimized, no wazza at all.
Too bad LN2 Run out when I tried to maximize all the other settings, so 11m47.xxx s is my last result.
This is a quick 1M run by my friend Coldest, before running 32M
http://hwbot.org/result.do?resultId=925014
Well then, that's it for now,
I'll try harder next time when I got my 965BE
Regards,
EDIT : i got some videos for this run, I'll post it here when I'm done uploading it
__________________
I'm Just Lucky !
Originally Posted by Lucky_n00b,2004
"The ONLY thing that LIMITS my overclocking is not my cooling, nor my hardware...but ME . That's why I call myself a n00b. "
Originally Posted by Lucky_n00b,2009
I bought my Graphic Cards to play 3DMarks, not Games
Lucky_n00b is offline   Reply With Quote
Old 11-25-2009, 05:14 PM   #2
chew*
No rest for the weary
chew*'s Avatar
If you didn't do it technically the 600 MB ram helped you
Maxmem 600 is a commonly used as a tweak for 32m runs.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is offline   Reply With Quote
Old 11-25-2009, 05:25 PM   #3
Lucky_n00b
nobody
Lucky_n00b's Avatar
I did do my Maxmem, Mr. Chew( I set it at 600, and I always do that before 32M run )
But what I don't understand, all this time even if I set my maxmem to 600, the CPU-Z Memory tab will still show 4096MB.
Please take a look at my other runs
This is done right before I do the 6Ghz run, (without restart) and same MaxMem settings, the CPU-Z Memory Tab showed 4096MB, not 600MB.
__________________
I'm Just Lucky !
Old 11-26-2009, 07:34 AM   #4
aslanwas
aslanwas's Avatar
nice first try, mate, waiting for 965
__________________
C2Q q6600 3.3GHZ @ 1,184V
4,5GHZ@ 1,52V ( 9* 500 )
aslanwas is offline   Reply With Quote
Old 11-26-2009, 08:43 AM   #5
ryba
Champion
ryba's Avatar
Disable SPD in CPU-z, then you will see 600MB there SuperPI showing you correct value of maxmem what you have.
__________________
C2D E8400 E0 @ 4GHz : DFI LANParty X48 UT T3R : Mushkin Black Ascent 2x1GB DDR3 : BFG GTX260 : Corsair HX520W
ryba is offline   Reply With Quote
Old 11-26-2009, 10:13 AM   #6
Vivi
take me to the manbar
Vivi's Avatar
Send a message via MSN to Vivi Send a message via Skype™ to Vivi
hahah love the pick's alva!
very glad you'r ln2'ing now :P.
LOVE THE PANTS
keep up the awesomeness !
__________________
Vivi is offline   Reply With Quote
Old 11-26-2009, 11:37 AM   #7
Lucky_n00b
nobody
Lucky_n00b's Avatar
Thanks m8
Thanks for the explanation Ryba , it explains everything
LOVE THE PANTS
Hi there my bro,
Well, thanks to Ekky that I got this 15L Dewar(I bought this from him)
It's not much, just barely enough for 2.5-3 hours of full-pot CPU Benching(AMD), but it's still better than nothing..
I'm waiting for my next 50L Dewar, it probably arrives next month,
and after that, I will try to catch up with U in Hwbot with my 5970's
__________________
I'm Just Lucky !
Old 11-26-2009, 12:04 PM   #8
Billy-The-Kid
God job! I will be watching you!!!
__________________
Billy-The-Kid is offline   Reply With Quote
Old 11-26-2009, 08:50 PM   #9
Solid Snake
Solid Snake's Avatar
Send a message via MSN to Solid Snake
great score man.
Your GIGABYTE Mother Board Rulzz
__________________
"We Overclock and Crunch you to the Ground" - DDTUNG
Solid Snake is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
