Well ive been reading these forums for a while and drooling over various build from snipe dogg shazza and such and am going to attempt my 3rd water cooling setup (1st was thermaltake, second was secondhand swiftech/ek parts) Also bare in mind my current rig is an opteron 170 and is LOOONG in the tooth
Im due to get some serious cash shortly (depends on how long army admin takes to process it
) and ive tried to settle on the following for my replacement pc, everything must go from my current rig except my g7 mouse
Hopefully the army dont take too long, lest i change my mind with SATA3 and gulftown on the way.
dual intel 80gig g2 SSD (Striped)
Core i7 920
EVGA classified
6 gig Patriot Viper2 DDR 2000C8 (fastest available in NZ)
dual 1.5tb HD for media ( mirrored)
dual radeon 5870s
Dell 27inch monitor
Corsair 1000watt
Lian Li P80
My understanding is Cas makes more difference the clockspeed of ram now with I7? as the bandwidth is allready pretty up there being triple channel?
I dont expect to run the ram that high, just with lower timings (cas 6 1600-1700 maybe)
Im Looking at EK Full Coverage blocks for gpu and mobo, silver plated for the biocide (i can get it done for free) and possibly the new swiftech apogee xt.
or a heatkiller 3 (also Plated)
As for tubing, I like the look of Primochill ghost fittings, can 7/16 ID tubing be heated and stretched over the 1/2ID fittings?
I intend to buy a window for the case, and get the spare side worked into a shroud to hide 480mm rads externally, (so they dont stick out like dogs balls)
I want to run 2 loops, CPU and GPUs seperate, Which loop should the Northbridge go In, assuming 1 480mm rad per loop?
I also need recommendations on Pumps, Res, Rads and monitoring, I quite like the look of the Koolance RP 1000 sets, but they are expensive, any one got good or bad experiences with them to share? Also how much power can they pump into the 2 fan connectors,?
Im after Quiet so is the RX rads plus Gentle typhoons a good choice?
I cant order anything from Aquacomputers. they dont ship to new zealand, and Sidewinders is out of stock on most aquacomputers components, If I were to go Aquero for monitoring, How could i source their stuff? (imagine a silver plated copper res
Im in New Zealand so shipping may cost up to 500US (specced up a set on performance pcs) I want to do it once, do it right lest the exchange rate change along with my taste in accessories, The US dollar is so rotten and devalued I have to buy soon or ill regret it for ever, as would my credit card.
