11-19-2009, 11:55 PM
#1
Xtreme Supporter
Connecting close fittings - don't hate on my GIMP skillz!
My question is what would you all recommend for bridging the gap between the ports that are circled?
The plan is to use the mobo (EVGA x58 Classified), NB/SB/mosfet block (EVGA) and CPU block (XT) shown below. I could just use tubing, a couple fittings and just be done with it but I was thinking of being fancy and using a couple BP triple rotary angle fitting with a d-plug in between. However, I'm not sure if that's really the intended use of a d-plug or it would even fit.
And yes, the sticker on the memory slots makes the system go faster.
Thanks!
11-20-2009, 12:07 AM
#2
I'm trying to accomplish the same thing actually. Just received my D-Plug but I don't have a CPU yet so don't know if they will be the same height, the CPU and NB block that is. The distance between them is perfect for the 1 inch D-Plug at least.
Here is a pic before I got the D-Plug:
11-20-2009, 12:08 AM
#3
Xtreme Cruncher
I was able to make that bend without kinking with two Banana 45-degree fittings and some Banana compressions, using 7/16" Pro LRT - but I'm using the EK-Supreme, which I believe has the ports a little further over towards the RAM slots. I think you'd still be fine, though.
11-20-2009, 12:29 AM
#4
Xtreme Supporter
Exactly what I'm trying to pull off. Except I believe the gap for my setup is a bit larger which might pose a problem. Take a shot of what you end up going with. Oh and mail me your damn XT. I have my i7 920 but I need the block.
11-20-2009, 12:36 AM
#5
I'm waiting for a W3520 to arrive but it's taking its sweet time. I might just pick up a 920 and test the setup. I'm a little afraid that the blocks won't be the same height though. If the gap is bigger you might have a problem as the 1 inch D-Plug is the biggest there is. Will take a pic as soon as I get something done.
11-20-2009, 12:40 AM
#6
Xtreme Supporter
Well there's always extenders. I could make my own pipe out of these.
Yea, if they height is off I'm screwed.
11-20-2009, 01:32 AM
#7
Yea, those extenders could be the solution for you. I am thinking that adding a second o-ring on the 90° on the NB might lift it up a little making it possible.
Here is a pic of it laying on the there, still no CPU under there though which might lift it up even more:
11-20-2009, 01:52 AM
#8
Xtreme Supporter
Damn that looks good. It will be at least a week before I can see what sort of gap I'm dealing with.
11-20-2009, 02:17 AM
#9
Really tempting to just skip the Xeon and get a 920 so I could have it instantly but have.. to.. resist..
11-20-2009, 11:27 AM
#10
Xtreme Supporter
Why are you holding out for the Xeon?
11-20-2009, 11:40 AM
#11
Broken Gainestown
heh..
did this idea a while ago..
Dplugs are great.. however if your height is off, you will need to get it close.
You can use extenders, or the funky 90's from bits, because you can twist them sideways a bit to lower the height.
I went for an L instead of a straight path.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
11-20-2009, 02:32 PM
#12
So Naekuh, looking at your pic it is possible to adjust the length of the D-Plugs?
And to D749, I'm hoping to get a better performing chip with getting a Xeon.
11-20-2009, 03:11 PM
#13
At what point does does a slightly flattened (from the severity of the bend) piece of 1/2" tubing not only cost less and offer fewer points of failure, but actually pose less restriction?
__________________
i7 920 | Foxconn Bloodrage | GTX280 | Corsair DDR3-1600 2x3GB
11-20-2009, 03:36 PM
#14
Never, if it isn't what you want.
__________________
i7 920 BATCH 3838B079 4.2GHZ on 1.312v HT on, CFO off
FOXCONN BLOODRAGE
6G CORSAIR Dominator TR3X6G1600C8D
1x GTX 285 w/ heavily ported AquagraFX fc block
ULTRA X3 1000w
Windows 7 pro 64
SWIFTECH GTZ
2x DDC3.2 EK tops 2x PA120.3
WESTINGHOUSE LVM-37w3
Donate to XtremeSystems
11-20-2009, 03:59 PM
#15
Xtreme Supporter
11-20-2009, 04:01 PM
#16
Broken Gainestown
yes... dplugs are variable in design.
__________________
11-20-2009, 11:33 PM
#17
Ok, good to know. I squeezed mine together really hard as I was afraid it might leak otherwise
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
