XtremeSystems Forums
Reply
Old 11-19-2009, 02:32 PM   #1
aka_GK
Send a message via ICQ to aka_GK
Need help with loop planning
Hi all
Need some help planning my loop.
Here is the layout of the case
Would like to keep tubes short and good looking.
My initial plan was:
Water goes from the pump to the top of the rad inlet, then to CPU block, then MB Northbridge block, then to the reservoir side inlet, then to GPU and back to the pump.
Most likely GPU will be 2 slots lower than in the picture, reservoir can be placed anywhere - didn't drilled anything for it yet.
Pump can be turned and mounted to rad fan using UN Designs Z bracket.
In the picture rad is placed with inlet/outlet in the upper side, but can be turned upside down.
Preferred order is CPU right after the radiator, but if another order doesn't have any noticeable defference in CPU temps - it is fine.
Also I have this thing as a drain port it should be placed somewhere in the bottom too.
That's it. Thanks in advance, any advices are highly appreciated
__________________
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
aka_GK is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
