XtremeSystems Forums
Reply
Old 11-19-2009, 12:32 PM   #1
Odai
Temperatures are very high
hello,
I recently finished building a core i7 watercooled system. I have the following WC loop components:
-TFC 360 radiator (+ 6 GELID wing 12 fans)
-Primochill ICE coolant
-7/16" ID tubing
-Apogee GTZ block
-Swiftech MCW-NB MAX block
-Laing D5 pump
-Arctic cooling MX-3 TIM
I have my hardware (asus rampage ii extreme and i7 920 D0) at the following settings:
CPU vcore - 1.35V
CPU PLL - 1.82V
CPU VTT - 1.25V
HT - disabled
Base clock - 211MHz
CPU clock - 4431MHz
However, despite the voltages being relatively low, the CPU being a D0 revision chip, and hyper threading disabled, I get temperatures of 71C on the hottest core running intel burn test.
Have I made some sort of a mistake with my loop? How is it I have such high temperatures? I've made sure the orientation of the blocks are correct, and the TIM is spread properly.
I have had problems with the block during the build process. I basically have a few faint stains on the base (see http://www.xtremesystems.org/forums/...d.php?t=237988). Could these be affecting the performance, causing the high temps?
Thanks for any advice,
Odai.
Odai is offline   Reply With Quote
Old 11-19-2009, 12:51 PM   #2
jim0ne
The few stains on your block would not effect the temps. I have a similar set up to you (r2e, i7 d0 @ 4.2 w/HT on @ 1.35v) and i load around 70c. The temps seem fine to me.
jim0ne is offline   Reply With Quote
Old 11-19-2009, 01:01 PM   #3
bentleya
bentleya's Avatar
Send a message via MSN to bentleya
Remount the block, it may not be making enough contact, You may also have to much TIM.
bentleya is offline   Reply With Quote
Old 11-19-2009, 01:06 PM   #4
NaeKuh
Broken Gainestown
NaeKuh's Avatar
Originally Posted by Odai View Post
CPU vcore - 1.35V
CPU PLL - 1.82V
CPU VTT - 1.25V
HT - disabled
Base clock - 211MHz
CPU clock - 4431MHz
You are clocked @ 4.4ghz, with 1.35vcore, and your whinning about 71C?
You want colder temps? How about changing your ambients, or going on sub ambient.
There is NOTHING wrong with your system at that clock, and its probably better then 1/3rd of the people who post here.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 11-19-2009, 05:33 PM   #5
PiLsY
Technician
PiLsY's Avatar
Those temps are damn good man, nothing to worry about there. I'm @ 4.6ghz 1.42v and IBT gets me to 88c.
Its my opinion that these chips are fine generating huge temps in IBT and Linx. I never see over 65c in gaming despite what IBT can heat it to.
PiLsY is offline   Reply With Quote
Old 11-19-2009, 06:15 PM   #6
InCredible
im at 4.4 with ht tho and 1.4v and load at 88c as well(with 4870x2 in the loop on a mcr320 with 3 1600rpm fans)
InCredible is online now   Reply With Quote
Old 11-19-2009, 06:16 PM   #7
Boulard83
Boulard83's Avatar
Seems ok for the volts+speed.
__________________
• Le Québécois •
Asus P6TD Deluxe ** tweeking OC **
920 D0 @ 4.0ghz (21x191) @ 1.2815v bios
3x2gb Gskill Trident @ 1528mhz 7-7-7-21 1.54v
Asus HD5870 @ 950/1250 1.175v
MCP655 + TFC Xchanger 360 + GTZ
CM Cosmos S - G15 - DeathAdder
PC P&C 750w
Boulard83 is offline   Reply With Quote
Old 11-19-2009, 06:44 PM   #8
Hondacity
that cpu is awful! what batch is it?
__________________
Hondacity is online now   Reply With Quote
Old 11-20-2009, 06:24 PM   #9
Daddyjaxx
I am Xtreme
Daddyjaxx's Avatar
With HT disabled, that seems about right. Just so you don't think it's you. This is mine with HT on. About the same speed and volts:
http://img27.imageshack.us/img27/2884/1102094419.jpg
__________________
i920 210x21 (4.4GHz) @ 1.36
eVGA X58 SLI LE
BFG 275 GTX OC
3 x 2 GB OCZ Gold DDR3 1600 @ 1600
850W Corsair
80 GC Intel X25, 2 x 1.5 TB Seagate
Apogee GTZ, MCW60, D5, 2 x MCR320, Micro Res, 6 Yate Loon High push/pull on each rad
HAF 932
Daddyjaxx is offline   Reply With Quote
Old 11-20-2009, 09:25 PM   #10
Burninator
Send a message via AIM to Burninator
Nothing to worry about with those temps... I'm running 4.2ghz, 1.29v, HT on and load in the mid 70s
Burninator is offline   Reply With Quote
Old 11-22-2009, 11:05 AM   #11
Odai
Thanks for all your advice guys.
Really?
I have no idea what batch it is, how can I check? I still have the box somewhere...
Old 11-22-2009, 01:27 PM   #12
InCredible
he was being sarcastic..and yes on the box theres a sticker with all the info/bar codes..bottom left hand side of it says FPO/Batch #...
Old 11-22-2009, 01:59 PM   #13
millertime359
Xtreme Guru
millertime359's Avatar
Yep, relax. You are just fine.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 11-22-2009, 03:26 PM   #14
Odai
Can't find the box right now, will have a look tommorow for you.
Incidentally, I made a mistake with those voltages. Turns out they were only that high because I had the PLL voltage at 1.85V. Once I had determined everything was stable, I lowered the vcore. This gave me instability, so I put it back. If had lowered the PLL first, I would have realised that it was what was causing the instability, so I would have been able to lower the vcore much further. I'll never touch the PLL setting again.
I'm at 4.5x on those same temps and voltages, testing now. Hoping to get to 4.6 before I hit intel's max of 1.375 for the vcore.
Old 11-22-2009, 07:27 PM   #15
Odai
Pfffft. I had to make some major bumps in vcore when passing 215MHz bclck.
I've managed to get it stable in IBT at 219MHz @1.4V, but after 10 seconds of OCCT I get a BSOD.
Any ideas?
Also, am I pushing it with this vcore? Would 1.4-1.45V be safe for a 24/7 OC?
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
