XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Chilled Liquid Cooling
Reply
Old 11-19-2009, 02:18 AM   #1
Tetrafluorometh
How to get colder?
I've a Challenge Portable Air Conditioner 12000 BTU. The lowest it goes via the controls is 16c. How can i make the unit go colder? Directly wire the compressor, condenser fan togther so there is no controler?
Tetrafluorometh is offline   Reply With Quote
Old 11-19-2009, 08:25 AM   #2
Sam__
Sam__'s Avatar
exactly that. make it so its on all the time.
__________________
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
"I think there is a world market for maybe five computers."
- Thomas Watson, chairman of IBM, 1943
Heat
Sam__ is offline   Reply With Quote
Old 11-19-2009, 01:43 PM   #3
Tetrafluorometh
So directly to the compressor and condenser fan. Remove any power to the controls and the evap fan?
Old 11-19-2009, 02:21 PM   #4
HDCHOPPER
If you do this take pic and make a simple guide plz !
I have a small indoor A/C unit I have been wanting to mod....
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
HDCHOPPER is offline   Reply With Quote
Old 11-19-2009, 03:34 PM   #5
Tetrafluorometh
Okay no problem. I think it will be this weekend, sunday when i have time to play with it
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
