XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 11-18-2009, 09:29 PM   #1
S1N3
S1N3's Avatar
SS Temp Monitoring I7 920 ( not holding heatload )
I just installed my SS on my 920 tonight, I'm a little worried about my temps. Currently I'm at 21x multi 210 block at 1.32v. This is known to be semi stable on water and I thought a good starting point to determine if the SS was efficient enough to handle my heatload. The SS holds at -55F at idle and -30F under load however I can see Core Temp climb from a inaccurate -6 on all cores too an average of 20c under load. I understand that Core Temp does not report correctly at sub Zero but can I rely on Core Temp at all? I've reset the mount several times and nothings changed, the tim appears to be spread evenly and the evap seems to be in direct contact.
Modded Mach 2 Oversized Condenser , Chilly 1 Evap ,
__________________
I7 920 DO @ 4.2GHz
ASUS P6T Deluxe V2
12Gig OCZ Gold Cas 8 DDR3 1600
OCZ Vertex Series 60 Gig SSD
SeaGate Barracuda 1 tb HD
SeaGate Barracuda 1.5 tb HD
BFG GTX 295
Corsair HX1000W
Cooler Master Cosmos
Vista 64bit
3x Dual 220 Rads / Swiftech XT
S1N3 is offline   Reply With Quote
Old 11-18-2009, 10:33 PM   #2
skinnee
Addicted to Pie!
skinnee's Avatar
I'm seeing similar temps reported from RealTemp on a single stage (OCZ CryoZ) with a 920 D0 at 1.35Vish.
__________________
skinnee labs test schedule:
In Testing: Too much to list.
Writing Reviews: finally getting my backlog cleaned up too.
Planned Tests: Plan, what the heck is a plan.
skinnee is offline   Reply With Quote
Old 11-18-2009, 10:42 PM   #3
S1N3
S1N3's Avatar
WOW, I think those are rated at 130watt load... I must be doing something wrong with my mount. I didn't expect such a large delta,
__________________
I7 920 DO @ 4.2GHz
ASUS P6T Deluxe V2
BFG GTX 295
Corsair HX1000W
Vista 64bit
Old 11-18-2009, 10:44 PM   #4
skinnee
Addicted to Pie!
skinnee's Avatar
I also know you can't trust Tcase and Tjunction at those temp ranges though... <shrug>
__________________
Old 11-19-2009, 05:02 AM   #5
Rasmus66
Rasmus66's Avatar
Send a message via MSN to Rasmus66
Realtemp and coretemp dont work with sub zero temps i have the same problem.
Realtemp is reporting -6 idle and the temp probe says -40 on my vapochill Ls.
__________________
Asus P6T Deluxe V2 + MSI Eclipse SLI - Intel Core I7 950 - G.Skill Trident PC3-16000 3*2 gb - 2x Sapphire HD5770 1gb - Nexus RW 1000 watt - Samsung Spinpoint F1 750 gb
Rasmus66 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
