XtremeSystems Forums
Reply
Old 11-18-2009, 08:25 PM   #1
AorSith
Noob WC setup.
Hello all! I have enjoyed and learned alot from reading the posts here.
I am about to build my first wc system and wanted to run it by the pros.
Here is what I am looking at:
- Haf 932(have the case its painted not sure its the one )
- i7920
- Evga Classified
- 6 gig Corsair Domintor 2000
- ultra X4 1200 watt power supply
- 2 x xfx 5870s
- 2 x swiftech 355s
- Feser X-Changer 360
- XSPC RX240
- XSPC Dual 5.25" Bay Reservoir for Dual Laing DDC
- tygon 3/8id 1/2od
- Enzotech LUNA Rev.A cpu wb
- 2 x EK FC-5870 Radeon HD 5870 ATI Reference PCB Design - Nickel wb
- EK-FB EVGA X58 LE Full Board Northbridge/Southbridge wb
- 1ST PC CORP. FC-FC2-B Lamptron fan controller
Loop 1
-Feser X-Changer 360
-swiftech 355
-CPU waterblock
-NB/SB waterblock
Loop 2
- XSPC RX240
- swiftech 355
- 2 x gpu waterblocks
Any input would be greatly appreicated.
Does anyone know how the XSPC Dual 5.25" Bay Reservoir performs. The pumps connect directly to the resivoir which what i like for layout.
I was wanting to run the COOLER MASTER R4 2000 rpm fans. Push/Pull on both rads.
AorSith is offline   Reply With Quote
Old 11-18-2009, 08:32 PM   #2
millertime359
Xtreme Guru
millertime359's Avatar
The big change I would make is get a Swiftech XT block. Great performing block and has a great mounting mechinasm.
Next choice would be a HK3.0 CU or LT.
Check out Primochill PRO LRT, great tubing and comes in colors.
What coolant are you using?
You seem to have done your reading though. Nice list, and
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 11-18-2009, 08:37 PM   #3
AorSith
I actually orderd the Primochill PRO LRT today.
I was going to use distilled water with the primochill add in coloring.
I found a review somewhere that showed the luna.a with good reviews. Ill look into the cpu wb some more. Thanks
Old 11-18-2009, 08:42 PM   #4
millertime359
Xtreme Guru
Don't add in any dye. If you want color in the res, use LEDs. Dye likes to stain things and deposit itself where it shouldn't.
add in some silver like this.
Good luck to ya.
__________________
Old 11-18-2009, 11:23 PM   #5
AorSith
I had not done enough research yet on coolant. Thanks for the input on the dye and silver.
I took a look at your build. Has a clean professional look. I may have to go with black tubing Very nice.
Those fittings had to cost $$$ where did you get them?
Old 11-19-2009, 12:28 AM   #6
autobot
I'd run the CPU and NB on the 240 rad and the dual 5870s on the 360 rad. Those 5870s get pretty damned toasty when OCed.
__________________
- Autobot -
Intel Q9400 (3.6Ghz) / Asus P5Q Deluxe / 4GB Patriot Viper DDR2-800
Visiontek HD4870 512mb (820/975) / Creative X-Fi Titanium Fatality
WD 80GB SATA2 / Maxtor 320GB SATA2 / LG Litescribe SATA
Antec NeoHE 550
Enzotech Sapphire CPU Rev.A, Sapphire NB Rev.A / Swiftech MCP655, MicroRes, MCR320 / DangerDen Maze5GPU
autobot is offline   Reply With Quote
Old 11-19-2009, 05:58 AM   #7
millertime359
Xtreme Guru
Those are BP Compression fittings. You can find them here
The new black ones are also really cool.
CPUs are more sensitive to temps than GPUs are, so it makes sense to give them the larger rad. Watercooling GPUs will drop there temps alot anyways, so they should be just fine on the 240.
__________________
Old 11-19-2009, 11:10 AM   #8
AorSith
Thanks for the fittings link.
Im trying to decide betwen the
- 45 Degree Rotary
- 45 Degree Adapter
Can you get the adapters in securly and get them at the angle you need. It seems you could end up with leaks trying to get it to the angle you need becuse the adapter would not be as tight as you need.
Any comments on this would be very helpfull.
Ive read alot of threads in here and seen comments on both radiator sugestions. I understand that the evga classified nb gets very hot and cpu temps are more sensitive. To be honest I have been worried about gpus only getting a 240. I think ill go initially as listed. I could add a single rad in the case or add another 360 on the back if needed.
I havent researched temps i should hope to see yet.
Does anyone know what a good 5870 wc temp would be?
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
