Originally Posted by PiLsY
Still wont be 100% though.
There are aftermarket blocks out there that are all copper. I think chilledpc.co.uk did one maybe? If not try pming duniek and see if he does a block for it.
Great board, they really screwed up with that northbridge block though.
At least they corrected it for boards following the blackops I suppose.
100%?
To solve the corrosion problem he just needs a coolant that will prevent galvanic corrosion.
If the OP wants to repair the damage, then a new block would most likely be the best option.
