XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 11-18-2009, 11:19 AM   #1
ultralo1
ultralo1's Avatar
Commercial -150C
Here are some pics of a commercial -150C. This is a 7 cubic foot chest used for the long term preservation of tissue and cellular samples. It is also a first for me. The gas blend is propriatary so the company only sells the premixed blend at $2500 per charge. They gaurd the exact blend very well and dont ilke to discuss it at all with us non company employee types. With a little guidance from Mytech, I have developed a blend that works in these units.
Now onto the pics.
The unit
The prize
Side view showing Buffer tanks, expansion tank, LPCI, Pressure dump control and solenoid, Comp, Condensor.
Top controller is LPCI, The bottom is the dump controller
Expansion and buffer tanks
Close up of comp compartment
Comp model tag
Another comp area
The oil seperators in parallel. They found that in series did not seperate as well. Parallel allows the flow rate to decrease enough to seperate very efficently.
The design temp is for -150C max. I am running -153C max. The high side is 260psi and the low is 28psi. This system will be put into service as a rental unit for my customers.
__________________
Quoted from SoddemFX:
"I frankly have no idea what you are trying to do. I have received more comprehensible correspondence from Mr Obuwonga Mwahahu, who i believe wishes to give me a 10% share of his $12M fortune held in the royal bank of Nigeria."
ultralo1 is offline   Reply With Quote
Old 11-18-2009, 11:36 AM   #2
DonNiger
DonNiger's Avatar
Just put your PC into the cabinet ....
DonNiger is offline   Reply With Quote
Old 11-18-2009, 11:42 AM   #3
sdumper
-100c club
sdumper's Avatar
Very nice work!!!
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is online now   Reply With Quote
Old 11-18-2009, 12:03 PM   #4
Patrickclouds
Patrickclouds's Avatar
Send a message via ICQ to Patrickclouds
yeah great unit.
gases are? argon, r50, r14, r23, r404, r134a?
that won´t hold the load of a computer
ah here is the datasheet of such a cryogenic freezer i have found on my computer
http://members.extremecooling.de/pat...n.%20Daten.pdf
Patrickclouds is offline   Reply With Quote
Old 11-18-2009, 01:36 PM   #5
ultralo1
ultralo1's Avatar
R600, R507, R508b, R14, argon
Same unit
__________________
Old 11-18-2009, 01:45 PM   #6
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
Looks good, assuming the huge tank is the expansion tank.
4 ton scroll as well? Looks like the one I just bought off the bay'. (Same series but 1.75 Ton)
Wish condensers like that were easy to get as well!
Any pics of the heat exchanger stack or was it all foamed?
And of course, you didn't feel the r600 would allow sufficienct oil removal? That's a hell of a lot of oil separation.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 11-18-2009, 02:33 PM   #7
ruffus
i have a compressor just like that as well. this is a autocascade right if so then i now know what i will be doing with my scroll compressors as i do have a couple of them and we not going to do anything with them as i was told that they were no good for what we do with them as they don't like LBP's something about oil problems just can't remember who told me this
ruffus is offline   Reply With Quote
Old 11-18-2009, 02:37 PM   #8
n00b 0f l337
I am Xtreme
They're more stringent to there ratings. The LBP ones are good for LBP and not much else, and same for MBP and HBP.
The hard part though is definitly a big enough condenser, luckily the high boiling point refrigerant or auxillary condenser helps dump an incredible amount of heat (like how a 2nd stage in a cascade needs only a small desuperheater), and allows you to get away with alot less.
Something tells me though that I'll get a 5" x 12" plate heat exchanger or similar of massiveness
__________________
NoL: gom gom gom
Old 11-18-2009, 06:38 PM   #9
George_o/c
George_o/c's Avatar
Send a message via MSN to George_o/c Send a message via Yahoo to George_o/c Send a message via Skype™ to George_o/c
Holy , that looks badass !
George_o/c is offline   Reply With Quote
Old 11-19-2009, 04:29 AM   #10
Patrickclouds
is it an autocascade? with copperpipe heat exchangers? did you use phaseseps to seperate gas from liquid?
or works it like a mixed gas joule thomsen circuitwithout phaseseps?
Old 11-19-2009, 08:16 AM   #11
SAE
XS-Fanb0i N-side
SAE's Avatar
Send a message via ICQ to SAE Send a message via Skype™ to SAE
From that datasheet: Autocascade, compressor Copeland 3.5HP
__________________
Xtremesystems.org
i7-950 * Duniek + DT rty singlestage comin' (long wait since september ) * EVGA X58 Classified * 6Gig Corsair DomGT 2000C7 * XFX GTX 285 XXX * Intel 80Gig G2 + OCZ Vertex 30GB * Corsair HX1000 * Dimastech Easy V2.5 * Swiftech MCW60, MCP355 Dual Setup@Watercool Top, PA120.3 w/Triebwerk, EK Res250, DD 16/10 w/Feser fittings...
Athlon XP in summer 2004@12.5x261-265MHz 11-2-2-2-2.0 w/DFI Lanparty B No.1 AXP 3.25-3.3GHz+ phase cooled, 3.2GHz folding stable
No.1 HexusPifast Athlon XP: 43.92sec @12.5x263MHz 11-2-2-2-2.0 w/DFI Lanparty B
No.1 Superpi 1M Athlon XP: 30s @12.5x265MHz 11-2-2-2-2.0 w/DFI Lanparty B
SAE is offline   Reply With Quote
Old 11-19-2009, 08:35 AM   #12
sdumper
-100c club
sdumper's Avatar
Hey ultra can you show some picts of the phase separator?
__________________
Old 11-19-2009, 12:50 PM   #13
HDCHOPPER
Jeezzz O petes thats beautiful
thanks for the gas mixture !
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
HDCHOPPER is offline   Reply With Quote
Old 11-21-2009, 04:59 AM   #14
ultralo1
ultralo1's Avatar
The 600 is used as a refrigerant in this case. there is about 20 Oz in there. The total factory charge weight is 90 ounces of the mix.
It is an Autocascade. The heat exchanger is basically a shell and tube like Mytech did in his window unit conversion. There are phase seps in it.
I wish I could. I have only seen the stack once and that was at the manufacturers school, no pics allowed. From memory they are just like what you guys build. The big ones are made from piping and caps, the inlet comes in from the side at an angle to get the incomeing mix to swirl and help seperate, the top has some copper wool in it and the bottom feeds out to a cap tube. They final phase sep is nothing more than a 5/16 tee.
__________________
Old 11-21-2009, 05:10 AM   #15
quintus
quintus's Avatar
Got something similar at my university, maybe a double autocascade, there were 2 compressors if i remember well and a lot of freons.
Ultralo1 when i will have pics of it can i post them here?
regards,
q
quintus is offline   Reply With Quote
Old 11-21-2009, 06:22 AM   #16
ultralo1
ultralo1's Avatar
Sanyo makes a -150 semi autocascade. They have two comps. The first stage is a hermetic the runs a high boilin point refrigerant. The second stage is the auto cascade section the runs the mix of low bioling point refrgerants. Maybe thats what you have seen.
__________________
Old 11-21-2009, 09:15 AM   #17
quintus
quintus's Avatar
You might be right, from what i can remember there where 2 or 3 freons per each stage. Will keep you up to date
Old 11-21-2009, 11:01 AM   #18
n00b 0f l337
I am Xtreme
How'd you "harvest" the r600?
I can't seem to find more then lighter and stove bottles, but nothing big, and nothing with an access I can really get into. I've been using a puncture tap and I don't like it.
__________________
NoL: gom gom gom
Old 11-21-2009, 07:14 PM   #19
ultralo1
ultralo1's Avatar
I had to buy a 30 pound cylinder for another project. I had to adapt a fitting for it to use my gauges on. I think I bought the 600 from National welders.
__________________
Old 11-21-2009, 07:29 PM   #20
wdrzal
I am Xtreme
wdrzal's Avatar
Hey congrats to you Ultralo1,& Mytech not only for the the temps but more impressive is 28 psig. Compressors won't survive @ 26hg vacuum long but @ 28 psig they might.
Ultralo1 at least you didn't use -150c and LONG term preservation in the same sentence. kidding
I would put those in different paragraphs in the warranty. not kidding
I think a scroll is a good choice for compressor type, especially since they fixed the problems with the early model scrolls.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 11-21-2009, 07:30 PM   #21
n00b 0f l337
I am Xtreme
Airgas. Cool.
Will give them a bite. I hate tapping these small suckers.
__________________
NoL: gom gom gom
Old 11-21-2009, 07:44 PM   #22
n00b 0f l337
I am Xtreme
Last q, buffer tank was the small one or the hugeee one?
__________________
NoL: gom gom gom
Old 11-23-2009, 12:15 AM   #23
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
Looking great. My next adventure will certainly be 2-stage auto-cascade, aiming at -100°C idle, can't wait to start it!
tiborrr is offline   Reply With Quote
Old 11-25-2009, 10:42 AM   #24
mytekcontrols
mytekcontrols's Avatar
Hey Britt glad to see that you got it working ok
With a little guidance from Mytek, I have developed a blend that works in these units.
Actually you did all the heavy lifting so to speak, and it looks like you can now enjoy the rewards of your hard labor (like saving $2,500 a pop, and now having your own charge to sell for these units).
Very nice looking unit. And it looks like your compressor suction cooling is doing very well. I would imagine that the compressor is quite comfortable, and as Walt pointed out, a 28 psi suction (what was the discharge?) should increase the longevity considerably over a standard cascade.
Edit: Opps just saw that the discharge pressure was 260 psi. A little over 6 to 1 compressor ratio. That compressor is going to live a good long life.
__________________
Michael St. Pierre
  • Worked 15 years for Polycold Systems
  • Now Self-Employed
  • Manufacture Heat Load Controllers
  • Also do contract service work on Polycold units
mytekcontrols is offline   Reply With Quote
Old 11-25-2009, 11:01 AM   #25
K404
Xtreme Mentor
K404's Avatar
If this is for sample storage, is it safe to say the unit is tuned for very low heatloads?
Not take away from the achievement of offering -150 on demand
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
K404 is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
