I current have an Antec 300 but I am tired of the noise it puts out. Thus I am looking to replace it with a simple yet good preforming air cooled case. I don't care about fans as I intend to replace them with new fans. Cable management is a must! Also try to stay away from full towers.
__________________
Desktop:
Antec 300
Foxcon A7AD-S 790GX
8GB Gskill PC-1066@5/5/5/12
PII X940 BE @3.6GHZ
Sunbeam Core Contact
2x 640GB in Raid 0+1
4870 512MB@800/1000
Vista Business 64bit W/ SP1
I just got an Antec P183 and I love it. With all 4 fans running at ~1300 RPMS (and the CPU Fan @ ~1600) it is still quiet and cool; My Q9550 @ 4GHz idles between 37-40*C
I posted some pics in the AIR COOLED GALLERY thread, check them out.
It's a beautiful case, I love the black and white colour scheme. It's supposed to be a very quiet case. But sadly it's not on the New Zealand market yet.
i think the antec 300 is a pretty poorly built case (so many points where things can vibrate causing an annoying noise its mind boggling). the very minimum in cable management didnt please me either. i would go with a lancool k-56 or lancool k-58. theyre relatively cheap, much better cable management, has anti vibration mechanisms built in, and a simple and clean layout. would have easily bought one of those over the antec 300 if they were out when i built my system. instead i get to admire my buddys
have u tried reworking the fans there are way to many in the case normally, try pulling the front fans, then if its still bad get a good fan for the top/back and if its still its your hard drives or gpu with a bad profile so get a good 5.25" bay for them
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
Its the front fans for sure. But my current fans are nearly silent in open-air. They are a few years old, but are Silverstone 7 blade sleeve bearing fans.
__________________
Desktop:
Antec 300
Foxcon A7AD-S 790GX
PII X940 BE @3.6GHZ
4870 512MB@800/1000
I have been looking at these. Need to find a few decent reviews on them.
__________________
Desktop:
Antec 300
Foxcon A7AD-S 790GX
PII X940 BE @3.6GHZ
4870 512MB@800/1000
silverstone fans suck and make alot of noise, u dont even need fans in the front there will be negative pressure if u remove them and it will force air into the case from the vent holes and open fan slots
__________________
they will be fine, HDDs need to be from 35-50c (HDD are mechanical they need proper lube), they should be fine without a fan on them. if u are concerned get a yate slow to put over them. or boot to a non raid install and set the controller to ahci or ide mode and do non destructive read tests on them and see how hot the get in smart i will bet that they dont go over 40-43c with no fan in front of them if u have the pack 2 fans used.
u could also replace them with some slow-mid yates or if u really want no noise the scyth gentle typhoon and u want a fan in front of the drives for peace of mind
__________________
