XtremeSystems Forums
Reply
Old 11-17-2009, 05:30 PM   #1
shazza
Xtreme Fan
shazza's Avatar
A question on double rads in the bottom compartment
Hey - I've got a question for you gurus. I've seen tons of work logs with two rads in the bottom compartment of cases like the TJ-07, V2000, etc. I'm working with the Black Pearl, and have lots of room.
My question has to do with performance. While my case can easily fit two rads in the bottom - even two quads if I want - what's the performance hit from one of the rads taking in warm air from the other? While it's possible to have fresh air coming into both rads, it's going to heat up the center, with no where to go.
My initial thought was one rad - maybe push/pull with GT1450s, and then GT1850s on the other side exhausting the air from the bottom compartment. Just wondering if I'd be better off with an additional rad on the exit side? I'm some time from being able to test it myself, so just wondering what the consensus is.
Thx.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is offline   Reply With Quote
Old 11-17-2009, 05:43 PM   #2
LostInRehab
Let me give you another thing to think about. Your case has a lot of vents at the bottom of the case what about having both rads vent outside the case while the vent openings passively pull air in.
LostInRehab is offline   Reply With Quote
Old 11-17-2009, 05:48 PM   #3
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
In my opinion, you have two distinct options here shazza:
1) use high CFM on the rads (push-pull-push-pull if you can ) and have the fans blowing unilaterally. The more air volume flowing through the case the less heat saturated air flowing across the fins of the second rad in the airflow series.
2) (a cool option think ) Put 4 1850rpm gt's mounted to the floor of the case blowing in then use 1450rpm gt's on each rad in push blowing out both sides. Simply put a powered air intake in the bottom and an air exhaust out each side.
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 11-17-2009, 06:23 PM   #4
shazza
Xtreme Fan
shazza's Avatar
Hmmnnn - interesting ideas. @ Lost - that's a thought, just not sure how much air I can get into the case with the current setup - only openings on the bottom of the PSU plate. Maybe if I added a fan in the front.
@ SNiiPE = Option 1 would probably work. Option 2 is difficult because of the PSU layout.
Keep the ideas coming. I'm guessing I'll just have to wait and test to know for sure what the impact is of different rad combos.
Old 11-17-2009, 06:31 PM   #5
iandh
Zombie Assassin
iandh's Avatar
If the cold air rad was looped to the CPU, and the warm air rad was looped to the GPU(s), there would probably be only minimal change in final GPU temps.
__________________
i5 750
Asus Maximus III Gene
Patriot Viper II Sector 5 DDR3-1600 4Gb
XFX 5850 1Gb
Antec NSK3480/Seasonic SS-500HT
iandh is offline   Reply With Quote
Old 11-17-2009, 07:01 PM   #6
alacheesu
I see Skinnee has posted air out temps on most (or all) his rad testing. It seems most rads use around 90% of available air capacity in a typical scenario, meaning the air/water delta on the second rad would be 1/10th of what the first rad has to work with. Consequently, it would contribute only 10% extra heat dissipation provided they're in the same loop. That's less than half of what you would get from adding a single rad taking in cool air. It doesn't seem worth it to me.
I'm assuming the air goes directly from one rad to another without mixing with cool air from somewhere. The 90% number is just what I found most reasonable going by the numbers on Skinnee's site, but it seems to differ a bit from rad to rad, heat load and fan speed.
alacheesu is offline   Reply With Quote
Old 11-17-2009, 07:55 PM   #7
LostInRehab
I was looking at the floor here.
Seems like a lot of openings for air unless you're going to cover them up but thats just a thought.
Old 11-17-2009, 08:30 PM   #8
Serpentarius
Serpentarius's Avatar
ever thought of having some air duct?
instead letting the hot air goes wherever they want (physics), why not direct them through proper channels?
besides, air is highly compressible, you can have small air duct, without risking the asthestics
plus hot air is lighter and more easily exits through the ducts
how bout this, get those old newspapers, tapes and scissors ... craft some of your 'origami' ducting shapes, tape it on the rad with fan and fire them up
Serpentarius is offline   Reply With Quote
Old 11-17-2009, 09:28 PM   #9
Sadasius
Tygon Warrior
Sadasius's Avatar
You know Serpentarius that is exactly something I was thinking about in my next build and is a very good idea. Works on exchange systems in buildings and such, why not a case.
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is online now   Reply With Quote
Old 11-17-2009, 10:15 PM   #10
Serpentarius
you can (partially) insulate the vents (assumed thin metal sheets) by using Plastidip spray for the external surface to contain and minimise the hot air losing its heat through convection on the metal sheets
it's a shame i junk out my ghetto duct years ago (build via alu drink cans)
i bet you guys never used a plastidip on the internal casing build ... plastic finishing with soundproofing .. just remember to spray a thin primer for adhesive, they tear easily with the smooth alu casing surface
Old 11-18-2009, 03:56 AM   #11
BrokenArrow
BrokenArrow's Avatar
In my research for the TJ-07 case, I came across a thread (by AndyM I think) that tested three different ways of orienting the fans.
The clear winner was having the air just pass on through the rads. Even though the second rad was getting the warm air from the first rad, it was better than the other orientations you mention by quite a bit.
BrokenArrow is offline   Reply With Quote
Old 11-18-2009, 06:09 AM   #12
shazza
Xtreme Fan
shazza's Avatar
Thanks all, for the ideas. Not quite sure where the air duct goes?
@ BrokenArrow - thx - I remembered seeing some comparisons but couldn't find them with my searching - I'll try again. (Not sure exactly what you mean by "air just passing through the rads).
Old 11-18-2009, 06:24 AM   #13
alacheesu
This post, maybe?
Old 11-18-2009, 06:29 AM   #14
ohms
VČ/P
ohms's Avatar
Send a message via AIM to ohms Send a message via MSN to ohms
+1 for Option 2 SNiiPE
__________________
My Worklog: Project Raven ATCS 840
Today the guns are silent. A great tragedy has ended. We have known the bitterness of defeat and the exultation of triumph. And from both we have learned, there can be no going back. We must move forward, to preserve in peace what we've won in war." - Douglas MacArthur
ohms is offline   Reply With Quote
Old 11-18-2009, 06:48 AM   #15
shazza
Xtreme Fan
shazza's Avatar
Thanks, alacheesu - I assume that's the post BrokenArrow was referring to, and that's the type of info I'm looking for.
It was this comment by Marci in crediki's thread that got me thinking about it:
Re: the case design - Radiator of choice as INLET... Enough fans to create higher airflow at exhaust than at inlet. Get negative pressure inside the case due to higher exhaust than inlet... will improve airflow thru any rad (effectively push/pull with a big-ass shroud). ...
But, since I have extra radiators lying around, was trying to figure out if it made any sense to add another one on the exhaust side, since the fans will be there anyway. I don't need the extreme cooling, more interested in the option to run the fans at lower speeds.
Old 11-18-2009, 09:56 AM   #16
Garrett
I am Xtreme
Garrett's Avatar
Send a message via ICQ to Garrett Send a message via MSN to Garrett
I don't mean to hijack the thread but I've been thinking about this as well shazza, in fact I like the Corsair 800D case, put 2 Quad rads in the bottom and modify the side panels so that each panel has one of these installed: http://www.scan.co.uk/Images/Products/1006758-a.jpg
I know the PSU will fit in the top of the case... get my idea?
That way you'd create a "TJ-07-like" bottom compartment that does all the watercooling for you
Install the motherboard, right next to it you have a cilinder shaped reservoir and the pump under that, and you route the tubing to the rads
fan/rad/fan/rad/fan something like that, imagine having 2 quad rads there
__________________
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
Garrett is offline   Reply With Quote
Old 11-18-2009, 11:08 AM   #17
BrokenArrow
Yes, this was the thread I was referring too. Thanks alacheesu.
Old 11-18-2009, 07:08 PM   #18
Utnorris
Utnorris's Avatar
Why not do the separate chamber and add a vent to the front of the case? Pull air in from the sides and let it exit out the back and front.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Corsair 800D
I7 920 (3849B028)/Classified/ EVGA GTX 295/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) EK Supreme Classified (NB) EK Water Block / Typhoon III with XSPC RX360 / B*P/Koolance Compression Fittings and Quick Disconnects.
Utnorris is offline   Reply With Quote
Old 11-19-2009, 05:28 PM   #19
MoMo_RT
Because I can!
MoMo_RT's Avatar
On my TJ07 I just have both radiators pulling into the center then I made sure there's enough open space above them for the exhaust to escape through the upper sections of the case. This allows the fans to keep their pressure up and it moves air through the case so you don't end up with stagnant hot air building up.
__________________
i7-920
EVGA X58 SLI Classified E760
6gb G.SKILL Perfect Storm PC3 16000 8-8-8-21
EVGA GTX-285 x2 SLI
X25-M G2 80gb
CORSAIR 850HX PSU
SilverStone TJ07
Windows 7
HK Rev3 LT / EK-FC285 x2 / EK-FB Classified / MCP355 + EK X-Top x2 / Magicool Elegant 360 / XSPC RX240 / EK 250 Res / Swiftech MCRES / PrimoFlex 3/8 tubing
MoMo_RT is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
