XtremeSystems Forums
Reply
Old 11-17-2009, 01:54 PM   #1
BlaZ1n.IVXX
BlaZ1n.IVXX's Avatar
Where to put hard drives?
So I have the A77b case. I have on order a 120.3 XSPC radiator. Now I have to move two hard drives out of the fron because it will use the space. Anyone have a good solution for a place to put them? Looking for something cool or out of the norm.
__________________
Coming soon:
24/7 Gaming system: Asus P6-T rev 1 6gb Patriot 1600MHz I7 920 C0 4.2@1.4V 2x SLI EVGA GTX 280 727/1580/2408 2x Raid 0 Baracuda 400 GB 2x Raid 0 Cheetah 15k 73 Gb SAS Watercooled CPU
BlaZ1n.IVXX is offline   Reply With Quote
Old 11-17-2009, 01:56 PM   #2
DeathWalking
I'm assuming the A77b is the same thing as the PC-A77? If so, there's a HD cage in the back, at the top. Sorry that this isn't "out of the norm", but it'll work just fine.
DeathWalking is offline   Reply With Quote
Old 11-17-2009, 01:59 PM   #3
bentleya
bentleya's Avatar
Send a message via MSN to bentleya
Behind the motherbaord tray, with custom brackets?
bentleya is offline   Reply With Quote
Old 11-17-2009, 02:05 PM   #4
BlaZ1n.IVXX
Yeah it's the PC-A77 but in black. The hdd cage at the top in the rear is gone to make room for other things. I have two mounted to the side of the 5.25 tower. But no room for two more. To make things worse they are 15k sas drives. They get hot. I thought I had enough room for everything when I bought this case. I am sure I would if I wasen't dead set on putting the radiator in the front.
__________________
Coming soon:
Old 11-17-2009, 02:27 PM   #5
Mr. Morello
buy a full tower like I did over 10 years ago
I'm dating back to k6 AMD days on this baby (that's before durons LOL)..... you can see the upgraded pics if you click on my name and goto my home page!!
random thought: I laughed today when I looked at an old quake 1 box that said the game absolutely requires a math co processor and a Pentium class chip
Mr. Morello is offline   Reply With Quote
Old 11-17-2009, 05:08 PM   #6
eponymous
eponymous's Avatar
There was another guy asking about this a while back.
I suggest he do what D0BR0 did in his case and mount the hard disks on their side like this:
Hope this helps.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is online now   Reply With Quote
Old 11-18-2009, 04:12 PM   #7
pby5cat
what about the motherboard side of the 5.25 tower? Also the case is aluminum, so u could try to heatsink to the case.
__________________
Intel Q6600 L727A 3.2GHz (8*400 @ 1.35v)
Asus Maximus Formula
2X2gb Gskill DDRII-1000
2X HIS ATI HD3870 in Crossfire (835,1206)
WD 150Gb Raptor and Maxtor 250Gb DiamondMax10
2X Samsung DVD-RW DL SATA
Silverstone OP850
Thermalright Ultra 120 Xtreme (lapped)
Thermaltake Armor
thats it, and proud of it.
Heatware: pby5cat
pby5cat is offline   Reply With Quote
Old 11-18-2009, 05:11 PM   #8
shoopdawoopa
shoopdawoopa's Avatar
http://www.mountainmods.com/120mm-ha...red-p-410.html perhaps?
__________________
Whats up?
shoopdawoopa is offline   Reply With Quote
Old 11-18-2009, 08:49 PM   #9
tiro_uspsss
I am Xtreme
tiro_uspsss's Avatar
Send a message via ICQ to tiro_uspsss Send a message via MSN to tiro_uspsss Send a message via Yahoo to tiro_uspsss Send a message via Skype™ to tiro_uspsss
it is a full tower...
__________________
DNA = Design Not Accident
the awesome FOOD
thread
WANTED
heatware / ebay
tiro_uspsss is offline   Reply With Quote
Old 11-19-2009, 05:19 AM   #10
BlaZ1n.IVXX
Yeah its a full tower. I do mount two drives to one side of the 5.25 bays like the above picture. I don't know how the 15k sas drives will like it without a fan blowing on them. I guess if they die then i have a good reason to go ssd. I need to get to work on building my case so that I don't have these problems.
__________________
Coming soon:
Old 11-19-2009, 07:28 AM   #11
pwolfe
pwolfe's Avatar
I agree with shoopdawoopa, the mountainmods brackets are your best bet. They will place the drives right in front of a fan, not to mention is far more elegant than screwing them to the side of the drive bays,
pwolfe is offline   Reply With Quote
Old 11-19-2009, 11:01 AM   #12
WompireBat
WompireBat's Avatar
http://www.performance-pcs.com/catal...ducts_id=25008 - This is what I ended up doing. I have the A77 too (and love it.) The A7010 and A77 are virtually identical. If you got this panel, you would have to either drill holes for the power and reset, or do like I did and relocate them. My motivation for getting this may have been a little stronger than yours though, because I have 2 XSPC res/pumps and they occupy 4 of the front bays. Combined with top and bottom mounted rads, both of which are in push/pull configuration, I simply don't have room for a front mounted rad. I pulled the hd cage and kept one of the cross supports. I drilled holes in it and hung my 3 raptors from it. They've been running fine for about a year and without a fan directly on them.(I guess if you got the replacement top panel you wouldn't have to remove the hd cage. You're not as restricted on front space like I was.)
Another idea I'd had was running an L bar accross the case from the top supports and hanging the hds from there. Never did it though.
Hope this helps a little, and good luck.
Edit: I didn't notice right away that you were "dead set" on front mount. (too bad. personally, I think that top panel looks pretty slick)
Maybe use the gfx support bar in some way? There's just enough material on the sides that I mounted a res to it, but a hd might be too much.
WompireBat is offline   Reply With Quote
Old 11-19-2009, 11:19 AM   #13
NaeKuh
Broken Gainestown
NaeKuh's Avatar
how about using a SAS/SATA backplate?
Takes 3 spots, and fits 5 SATA drives.. for that version.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 11-19-2009, 11:56 AM   #14
BlaZ1n.IVXX
That is a nice setup. But with a dual 5.25 res and 120.3 radiator I am out of room in the front of the case.
__________________
Coming soon:
Old 11-19-2009, 01:00 PM   #15
NaeKuh
Broken Gainestown
NaeKuh's Avatar
Then you can ghetto it.
use hair rubber bands, the thick ones.
Then Tie it behind your radiator.
__________________
Old 11-19-2009, 01:17 PM   #16
BlaZ1n.IVXX
No offence but I don't think I want to rubber band 500.00 in hard drives to the radiator.
I think I am just going to mount them to the side for now. I am starting a custom built case this weekend. They should be ok untill it's built.
__________________
Coming soon:
Old 11-19-2009, 02:14 PM   #17
NaeKuh
Broken Gainestown
NaeKuh's Avatar
i dont think you understand what im talking about:
Your rad would be in front of the HD's.
The rubber band goes from one side of your bay to the other.
Use thick rubber bands, or the elastic ones you use for your hair, as those dont snap over time.
But thats how we used to ghetto style it in the front bay b4 we got spoiled by Un Designs and Bitspower.
__________________
Old 11-19-2009, 04:20 PM   #18
BlaZ1n.IVXX
OK I see what you are talking about now. The still wont work though. With the rad air box and fans I dont have any room left.
__________________
Coming soon:
Old 11-19-2009, 11:08 PM   #19
voigts
I am Xtreme
voigts's Avatar
just go ahead and build your own case already. it sounds like you need one about the size of the one Spotswood is making- http://www.xtremesystems.org/forums/...d.php?t=234852.
__________________
Latest Project Log: 1935 Zenith Radio Scratch Build
voigts is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
