XtremeSystems Forums
Reply
Old 11-17-2009, 06:35 AM   #1
Elmy
What water solution to use ?
Hi there this is my system http://www.youtube.com/watch?v=F9V9rLnrNxw and I've been running fluid xp with z7 and the first Typhon III I had cracked.... I heard that it might be the fluid causing this. So I Rma'd the first res now im getting ready to put it back together and was wondering if you guys could point me into the right direction for a pt nuke / distilled water solution. I dont know where to purchase pt nuke or whatever its called so could you post me a link also I want to turn the water a UV blue like I got it now. Also could you give the right mixture in english measurements ... i.e. one teaspoon of nuke to 3 cups of water and where to buy the right blue dye that wont gunk up the system and how much to put into the water ....
Thanks in advance :-)
Elmy is offline   Reply With Quote
Old 11-17-2009, 07:12 AM   #2
jim0ne
You could purchase PTnuke from http://www.sidewindercomputers.com/ or http://www.petrastechshop.com/
For the blue one... its one drop for every liter and the clear one is 3-4 drops per liter. I cant recommend any dye since i dont use it. Why dont you go color tubing instead?
jim0ne is offline   Reply With Quote
Old 11-17-2009, 07:34 AM   #3
Elmy
I have UV blue tubing but I want the water in the resevoir in the front of my pc to be UV blue.
Thanks for the response :-)
Anyone have any recommendations of how to safely turn the water UV blue ?
Old 11-17-2009, 07:57 AM   #4
Conumdrum
Conumdrum's Avatar
Sadly I won't recommend anything that is added to the distilled water except PHN Nuke or a piece of silver as a biocide. There is lots of colored dyes and premade colored liquids. I won't use any of them.
Best of luck!
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
XSPC 360RX and PA120.3 Rads
GTZ CPU and Tieton GPU blocks
Banchetto Tech Station
And the rest of the normal stuff
Conumdrum is offline   Reply With Quote
Old 11-17-2009, 11:55 AM   #5
NaeKuh
Broken Gainestown
NaeKuh's Avatar
wait.. fluid XP doesnt crack.
It coats til no tomorrow, but it wont crack.
IT doesnt have ethly glycol. It has something else which coats your stuff, thats why its biodegradable, and also non toxic.
But wise move on the distilled. Distilled is in its pure form is always the best. Anything you add ontop of it will hinder its performance.
Fluid XP is distilled + additives..
So you want to keep the distilled, but toss the additives.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 11-18-2009, 12:24 AM   #6
Tex707
I don't know about the die, but I could tell you something about the other stuff...I use pure distilled water and anti-algae additive for aquariums. I haven't changed then fluid for about two years now and it is still perfectly clean (at least it looks so in the reservoir). Have to mention that I have a large canister water filter in-line, though...
Tex707 is offline   Reply With Quote
Old 11-18-2009, 05:41 AM   #7
millertime359
Xtreme Guru
millertime359's Avatar
I use Distilled water and silver in my T3. As for getting your T3 to be blue, use the blue LEDs that came with it.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
