XtremeSystems Forums
Reply
Old 11-17-2009, 03:46 AM   #1
berntserker
The ship, it is sinking! (DDC leak)
My DDC 3.25 seems to be leaking in a very strange way.
First noticed it when I had the pump mounted vertically with the nozzle up.
Water would very slowly start to build up underneath the pump and run down the side.
Drained, removed the pump, dried it out and mounted it outside the case in a loop with only a reservoir in it, and no leaks.
The pump got much hotter to the touch than previously, but no leaks whatsoever.
Changed my loop so the pump is mounted horizontally, left it running for 12 hours, just standing freely in the bottom of the case.
A small drop has formed underneath the pump, and water seems to be leaking, infrequently and in very small amounts from the center of the bottom where the pin is.
Have tried tightening and loosening screws, but the result seems to be the same.
A small, but infrequent buildup of water from the bottom (see attached illustration.)
Is there anything I can do to mend this myself, like buying a thicker o-ring or is this pump a dud?
berntserker is offline   Reply With Quote
Old 11-17-2009, 03:57 AM   #2
Eddy_EK
Xtreme Enthusiast from EK
Eddy_EK's Avatar
I'd say replace the o-ring or RMA it.
__________________
Originally Posted by creidiki
EKs are like waterblock pr0n
Eddy_EK is offline   Reply With Quote
Old 11-17-2009, 04:14 AM   #3
Tex707
All you have to do is accept it is your fault and you're gonna feel just fine
Seriously, don't even think about putting in an O-ring of a larger body diameter.
Tex707 is offline   Reply With Quote
Old 11-17-2009, 04:59 AM   #4
Sadasius
Tygon Warrior
Sadasius's Avatar
+1 with what Eddy suggested. Ignore Tex707. In fact he is going on my ignore list now.
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 11-17-2009, 09:17 AM   #5
voigts
I am Xtreme
voigts's Avatar
I would also recommend an RMA. The fact that the pump bottom is getting unusually hot is probably an indication that it needs to go bye-bye.
__________________
Latest Project Log: 1935 Zenith Radio Scratch Build
voigts is offline   Reply With Quote
Old 11-17-2009, 05:33 PM   #6
PiLsY
Technician
PiLsY's Avatar
RMA definitely, forget changing the O-Ring. Its new, it shouldn't leak .
Tex707 - trolling is taken very seriously here so i'd be careful with your posts if I were you.
PiLsY is offline   Reply With Quote
Old 11-17-2009, 07:30 PM   #7
ohms
VČ/P
ohms's Avatar
Send a message via AIM to ohms Send a message via MSN to ohms
I'd say change the O-Ring if you have one laying around before you spend the money and the downtime RMAing it if you do not have a backup pump.
As for mounting it vertically, I know quite a few people have mounted the MCP/DDCs in various different positions without having any problems so I do think its an unrelated issue.
@Tex707 i'd take PiLsY's advice.
__________________
My Worklog: Project Raven ATCS 840
Today the guns are silent. A great tragedy has ended. We have known the bitterness of defeat and the exultation of triumph. And from both we have learned, there can be no going back. We must move forward, to preserve in peace what we've won in war." - Douglas MacArthur
ohms is offline   Reply With Quote
Old 11-17-2009, 07:52 PM   #8
quattro_
I am Xtreme
quattro_'s Avatar
+1 just RMA it, but before you do can you do me a big favor and shoot a picture of the pump's PCB ?
__________________
rig1
q9650@4.3 ~ EK Supreme
Asus RE ~ BP chipset block
4GB OCZ PC3-14400 Reaper@1600Mhz
HD 4870x2 ~ DD waterblock
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
EVGA Classified 760 ~ EK chipset block
6GB Dominator GT@1866MHz, 7-8-7-20
HD 5870 ~ EK waterblock
quattro_ is offline   Reply With Quote
Old 11-17-2009, 09:41 PM   #9
Petra
I am Xtreme
Petra's Avatar
Send a message via AIM to Petra
Indeed... they tend to get quite hot if the motor has come in contact with water and shorted something, amongst other reasons.
A leak around that center pin, though, kinda suggests a bad seal around the ceramic bearing. If the water were coming from the large, circular hole in the pump's lower housing, then I'd think o-ring. The center bearing support column is hollow, though, and drilled in the volume compensating version of the DDC to allow fluid to pass through the bearing support column and out the bottom of the pump into the volume compensating diaphragm. If there happened to be a bad seal between the support column and the ceramic ball, then it could cause fluid to leak out around the pin in the bottom of the pump.
__________________
I'm doing science and I'm still alive...
Petra is offline   Reply With Quote
Old 11-18-2009, 03:47 AM   #10
Tex707
This sounds very reasonable. I am not fully aware of the details of the design, but if there's a hollow bearing support that could definitely be the point of concern.
@ all who found my previous post wrong in any way: my sincere apologies, I'm not trolling, just made a joke (even put a smiley there). Still think the same about the O-ring, though...
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
