XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 11-15-2009, 02:24 PM   #1
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
HR-01 better mounting
I've got a Q6600 with an HR-01 on it. Temps have a 10C spread now between core 0 and core 3, with 1 and 2 falling in between. How can I improve the mounting of this heatsink?
Pics show before with the stock paste, and after with ceramique and using a set of washers on the spring-loaded screws to increase pressure. Helped, but still have a temp spread.
(yes its stock but will OC it once I get the temps more even).
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline   Reply With Quote
Old 11-16-2009, 07:42 PM   #2
SparkyJJO
SparkyJJO's Avatar
OK looks like my best bet is to get the improved 1 piece mounting bracket instead of the current 3 piece thing that lets it droop.
__________________
Old 11-17-2009, 03:33 AM   #3
Mescalamba
Actually, best way would be to lap that CPU probably.. I have same issue with i7 (its simply not perfectly flat)..
__________________
i7 920 C0 - 3,4 GHz /HT on + Megashadow
3x2GB CSX 1600MHz CL8
Foxconn Bloodrage rev. 1.1 - G32
XFX HD 4770 (slight OC)
IBM 74GB 15k SAS
Seagate Barracuda 7200.11 640GB + 1TB External
Corsair HX 850W (its GOLD man!)
Auzentech X-Fi Forte 7.1 + Sennheiser 555 (595 mod)
No cam - temporary I hope. My Flickr
Mescalamba is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
