XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 11-15-2009, 12:33 PM   #1
vaio
Xtreme Cruncher
vaio's Avatar
Send a message via MSN to vaio
Thermal paste with Megahalems any good?
Can't find my Arctic Silver, grrrr.
Is the thermal paste that ships with this 'sink adequate or should I hold off til I can restock the AS?
__________________
Gunning for a Poem top 30 spot.......Slowly aiming for the No 1 Brit spot.
Xtreme DC rebel!!!
We eat pie not count Pi
vaio is offline   Reply With Quote
Old 11-15-2009, 12:39 PM   #2
žile
It is better for sure,but not that better you should think about it much since it will not make any substantial difference whatsoever.Much more important thing is whether the contact surface is flat for example.
žile is offline   Reply With Quote
Old 11-15-2009, 01:36 PM   #3
shaolin95
shaolin95's Avatar
You may want to read this:
http://benchmarkreviews.com/index.ph...=150&Itemid=62
All in all, the most important thing to me is the application.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 11-15-2009, 01:36 PM   #4
Mescalamba
Quite good, not sure if its better than AS, probably around same. Try MX3 if you want.. thats good too (currently on mine).
Edit: Reviews says that its much better than AS.
__________________
i7 920 C0 - 3,4 GHz /HT on + Megashadow
3x2GB CSX 1600MHz CL8
Foxconn Bloodrage rev. 1.1 - G32
XFX HD 4770 (slight OC)
IBM 74GB 15k SAS
Seagate Barracuda 7200.11 640GB + 1TB External
Corsair HX 850W (its GOLD man!)
Auzentech X-Fi Forte 7.1 + Sennheiser 555 (595 mod)
No cam - temporary I hope. My Flickr
Mescalamba is offline   Reply With Quote
Old 11-15-2009, 01:49 PM   #5
Kimi
Kimi's Avatar
Send a message via Skype™ to Kimi
Yep, it's very good. Much better then AS 5.
__________________
Intel Core 2 Duo E8400 E0 + Prolimatech Mega Shadow
DFI LanParty DK P45 T2RS Plus
Kingston HyperX 4GB DDR2 Low-Latency Kit
HIS ATi HD4870 512MB
1.6 TB HDD space
Xigmatek 650W Modular
Lian Li Armorsuit
Kimi is offline   Reply With Quote
Old 11-15-2009, 02:01 PM   #6
shaolin95
shaolin95's Avatar
I disagree.
AS5 is one of the top ones and the difference between the top ones is so small that it is more than likely an issue with application making the difference than actual performance.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 11-15-2009, 02:18 PM   #7
Kimi
Kimi's Avatar
That difference is about 4 degrees. I don't think that's negligible.
__________________
1.6 TB HDD space
Lian Li Armorsuit
Old 11-16-2009, 12:56 PM   #8
Mescalamba
I guess that by Liquid Pro they mean actuall paste not Liquid pads (they don´t work at all).
__________________
IBM 74GB 15k SAS
Old 11-16-2009, 01:58 PM   #9
zsamz_
Xtreme Guru
zsamz_'s Avatar
Originally Posted by shaolin95 View Post
I disagree.
if you tried 1c7 or mx3 you would trash your as5
__________________
evga p55-ftw+i7 860 @4.1+megahalems
rampage extremeII 920 Batch# 3849B018 4.4@1.38v
gigabut p55-ud4p died after 4 days
e8600@ 510x9 1.38v +thermalright 120X
rampage extreme500x9 1.34v
dominator 1800 cas7
hyperx 2k cas8
northq blackmagic 850
p35c-ds3r bios suks
gigabut x38-d6q dead thank god
ballistix 8500 1240mhz@2.02v 5++sets of d9 downsizin
zsamz_ is offline   Reply With Quote
Old 11-16-2009, 02:00 PM   #10
zalbard
Xtreme Mentor
zalbard's Avatar
Send a message via MSN to zalbard
On a side note, I thought the difference between MX-2 and MX-3 was only 1 C...
And that Indigo Xtreme was better than liquid metal stuff... Hrm.
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Looking for Gulftown / Westmere ES
zalbard is offline   Reply With Quote
Old 11-16-2009, 03:19 PM   #11
poparamiro
Liquid pro is still the best interface material, but hard to clean, you can observe here prints of paste even after lapping.
Indigo Extreme also is a very good tim.
I prefer PK-1, is a good performer and easy to apply.
Diferences between the various paste depends on some important factors:
- pressure of retention sistem
- TDP
- surface planeity (thickness of paste layer)
- cooling sistem used
poparamiro is offline   Reply With Quote
Old 11-16-2009, 03:43 PM   #12
shaolin95
shaolin95's Avatar
And why would I do that when AS5 is just as good as those? Now if you think you are putting frosting on a cake and get bad results don't go blaming the TIM
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 11-17-2009, 02:36 PM   #13
jim0ne
You cant say AS5 is a bad TIM. It still adequate enough to do the job and some people are not concern with that 4c difference. I use both MX-3 and AS5. I usually would grab the MX-3 since it cools better and it is non conductive.
jim0ne is offline   Reply With Quote
Old 11-22-2009, 11:03 PM   #14
funny
I ordered GC-Extreme from newegg to replace the original MX-2 on my Q9650 CPU and 4870 GPU last week.
4 CPU cores full load temperature dropped around 3C and GPU Full load Temperature dropped around 4C!!!~
But this TIM is a little pricey.....
I would try MX-3.
funny is offline   Reply With Quote
Old 11-22-2009, 11:18 PM   #15
zanzabar
I am Xtreme
zanzabar's Avatar
as5 isnt as good as the newer aluminum powder based stuff or liquid metal, i would not use liquid metal oe diamond stuff personally as they are destructive but IMO if u still have as5 use it but once u are out get the better stuff. i dislike as5 since its a pain to use compared to mx-2 and as5 is capacitive. dont go spewing crap that as5 is just as good as others though its not high end anymore and arctic silver even has a new paste since they know that as5 isnt in the top range anymore and so its not worth the price
im not sure on the posted chart though as tuniq and AC use the same tims and just change it with their prefix
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is offline   Reply With Quote
Old 11-29-2009, 10:13 AM   #16
shaolin95
shaolin95's Avatar
I am sure that benchmark reviews is also spewing crap right? Maybe you, master oh wise one, have done better testings than they did... and if you are concerned about it been conductive then learn how to apply it....this aint frosting on a cake ...
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
