XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 11-06-2009, 07:44 PM   #1
jesr5
heat sink & temps
Hey I'm trying to do alittle ocing & keep temps down using air.when checking temps some programs list processor temp(which is ok mid 40's) but also list core temps(which are ocassionaly in mid 70's at full load/stress test).I got a xigmatek S963 on an E8400 on a asus P5Q.I dont think I can go with a 120mm heatsink because my apevia x-discovery case has a 80mm side window fan which blows directly on the top of the heatsink(clearance).I also have a pci slot fan under my videocard.2 80mm intake fans on front.My S963 has the slimmer sides facing front & rear.The larger sides up & down with the fan on the bottom side drawing or sucking the air into the fins(fans blows air onto heatsink).I always thought you wanted the fan blowing away from the heatsink(removing heat).Anyway my question is can I rotate my heatsink 90 degress so that the fan would face the front of my case then the fan could catch the air from the 2 front 80mm fans & push it through the fins of the S963 toward the rear exhaust(120mm).I also have shin-etsu g751 to reseat the S963.
__________________
intel E8400 @ 3500 w/xigmatek S963
asus P5Q
OCZ2FX12002G (2x1gb) @ 1248MHz
sapphire 4870 1g @ 825/1000
wd 200g + sgt 500g
antec trio 550
vista HP 32bit
jesr5 is offline   Reply With Quote
Old 11-06-2009, 10:10 PM   #2
khamo
khamo's Avatar
Always go by core temps. Consider a top down cooler like
http://www.noctua.at/main.php?show=p...s_id=18&lng=en
or
http://www.thermalright.com/new_a_pa...r_si128se.html
so the side fan will blow cold air on the geat sink.
For tower HS to keep front to back airflow, consider TR Ultima as it is shorter or even better Thermolab BADA HS
http://www.frostytech.com/articlevie...articleID=2467
good luck and have fun
__________________
LianLi PC a10, Asus Blitz formula, Q 6600 (Batch L726B447, B0, VID 1.200,) @ 3600 (450x8) Vcore bios 1.38125(stress 1.34), LLC Enbl, 4 GB Corsair PC2 6400 Pro @ 450/900 1:1,WD Raptor 150 x2 RAID 0, WD 500gb data drive, EVGA GTX 8800, Xigmatek HDT RS 1283, Enermax infinity 720W.
khamo is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
