XtremeSystems Forums
Reply
Old 11-05-2009, 08:55 PM   #1
Waterlogged
I am Xtreme
Waterlogged's Avatar
Enzotech chipset & MOSFET blocks now availabe
Well, they sure took their sweet time releasing these.
Enzotech EVX-58 Waterblock - for EVGA X58 SLI
Enzotech AS-REII-SN Waterblock - for Asus Rampage II Extreme NB/SB
Enzotech AS-REII-MOS Waterblock - for Asus Rampage II Extreme Mosfet
Enzotech AS-REII-RAM Waterblock - for Asus Rampage II Extreme Ram
__________________
Waterlogged is offline   Reply With Quote
Old 11-05-2009, 09:10 PM   #2
meanmoe
beautiful blocks. Especially that EVGA X58 block.
I think that the designation RAM on the RIIE block is a misnomer though. ppc even has it in the ram section.
__________________
upgrading...
meanmoe is offline   Reply With Quote
Old 11-05-2009, 09:21 PM   #3
Utnorris
Utnorris's Avatar
Is that for the Classified or the regular SLI board? I am not sure I like the design for the REII since the ram block doesn't look to be incorporated with the other block, but rather a separate block altogether. Wish they had taken photo's of both installed.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Corsair 800D
I7 920 (3849B028)/Classified/ EVGA GTX 295/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) EK Supreme Classified (NB) EK Water Block / Typhoon III with XSPC RX360 / B*P/Koolance Compression Fittings and Quick Disconnects.
Utnorris is online now   Reply With Quote
Old 11-05-2009, 09:23 PM   #4
meanmoe
EVGA SLI X58 != Classified
__________________
upgrading...
Old 11-05-2009, 09:28 PM   #5
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
reg sli board not classified.. n gosh i just barely bought a koolance mosfet block for mine i was waiting for it freaking... grr =.=
Caoder is offline   Reply With Quote
Old 11-06-2009, 01:12 AM   #6
anubis_is_evil
anubis_is_evil's Avatar
hmm.. why the engraving is up side down..
it looks like enzotech is designing the block for motherboard in BTX position...
anubis_is_evil is offline   Reply With Quote
Old 11-06-2009, 01:43 AM   #7
Edward88
The r2e need lots of fittings . . . so a lot of tubing to . .
Thats a shame . . . it would be nice that they put some metal tubing to interconnect all the parts
Edward88 is offline   Reply With Quote
Old 11-06-2009, 02:02 AM   #8
quattro_
I am Xtreme
quattro_'s Avatar
looks cool, where is the classified block ?
__________________
rig1
q9650@4.3 ~ EK Supreme
Asus RE ~ BP chipset block
4GB OCZ PC3-14400 Reaper@1600Mhz
HD 4870x2 ~ DD waterblock
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
EVGA Classified 760 ~ EK chipset block
6GB Dominator GT@1866MHz, 7-8-7-20
HD 5870 ~ EK waterblock
quattro_ is offline   Reply With Quote
Old 11-06-2009, 04:28 AM   #9
j.almonte
EVGA x58 SLI and the Classified are NOT the same mb...
j.almonte is offline   Reply With Quote
Old 11-06-2009, 04:32 AM   #10
Metric
I am Xtreme
Metric's Avatar
Send a message via Skype™ to Metric
His '!=' means not equal to ...
__________________
X3DM&R : FLICKR : DA : MURDERBOX
Metric is offline   Reply With Quote
Old 11-06-2009, 06:27 AM   #11
meanmoe
hah... yes '!=' is not equal. where '==' is equal. I had been staring at code all day and thats how it came out.
thank you for the translation.
__________________
upgrading...
Old 11-06-2009, 08:52 AM   #12
affiliate13
affiliate13's Avatar
Send a message via MSN to affiliate13
Gah, i waited and waited for these.
Fine looking blocks, like most Enzotech stuff.
I can only guess if they were any better than the EK ones i got.
__________________
ASUS Rampage II Ex 1504
Intel i7 920 D0 3850A795
Sapphire HD5970 EK FC 1Ghz/1150Mhz 1.237v
OS Intel X25-M RAID0
Data 500GB Seagate Barracuda 7200/32Mb
OCZ Reaper 6GB/1800/C8
BeQuiet Dark Power Pro 1200w
1X 18w DDC3.2 w/XSPC Res Top
1X 18w DDC3.25 w/XSPC Res Top
1X XSPC Submersible Pump/Res w/RS120mm
HW Labs GTX480 4x120mm
TFC Monsta 6x140mm
EK Supreme LT 3/8" Feser Tubing
EK IOH/SB and Mosfet Blocks
Lian Li V2110 w/EX-34
26" Iiyama Prolite
affiliate13 is offline   Reply With Quote
Old 01-01-2010, 06:56 PM   #13
NIF
Well I just ordered one of the Enzotech EVX-58 along with the Enzotech CPU block for my rig.
Hope it,s not disappointing and hope it fits right!
__________________
i7 920 @ 3.8
EVGA X58 LE
GTX 285
HyperX 6GB DDR3 1800
PcPower & Cooling 750
Hanns-G 28"
NIF is offline   Reply With Quote
Old 01-01-2010, 07:08 PM   #14
dude_500
Anyone know if the MOSFET block will fit on Maximus Formula SE boards? BIOS flash is the only technical difference between the boards (since I'm running my maximus as a rampage bios). I like the single block approach and will probably pick one up if so.
__________________
-Q6600 G0 @3.6GHZ
-Apogee GT Block, Onboard Maximus SE NB Cooler
-X38 Asus Maximus Formula - RaMpAgEd
-4GB G-SKILL 800Mhz
-EVGA 280 GTX and EVGA 8800 GTS
-3TB RAID-0
-750 Watt Silverstone Zeus
dude_500 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
