Originally Posted by heatkiller
i using dual top for both 355's
no place for tat xspc bay type....
I know you are using the dual top. I was referring to the manifold you want to set up. If you want to try splitting the loops, might as well just do dual loops and you shouldn't have to worry at all then.
You don't have 2 open 5 1/4" bays then?
You should be fine with just the one big loop though.
