XtremeSystems Forums
Reply
Old 11-05-2009, 06:28 PM   #1
Edward88
What is the best block/s for Asus R2E??
Hi, im planning to get an r2e, so i want to wc it
What is the best cooling solution that i can use?
I have only see the bits power blocks for r2e, and the 2 mosfets blocks.
They are nice (black ones) but i would like to se another options
What do you think?
Edward88 is offline   Reply With Quote
Old 11-05-2009, 06:50 PM   #2
Boyu
Try solution from EK or Enzotech :
Enzotech:
Boyu is offline   Reply With Quote
Old 11-06-2009, 01:47 AM   #3
Edward88
Its nice, but you need a lot of fittings and tubing for the nb and de dram sector :S
I dont know why they do it that way . . .
Old 11-06-2009, 01:49 PM   #4
TechloGoblin
I am Xtreme
I just did a recent build with the R2E
I used the bitspower black freezer on the NB/SB and the eK mosfet blocks
both are performing wonderfully
TechloGoblin is offline   Reply With Quote
Old 11-06-2009, 01:58 PM   #5
Edward88
Can you post some pics??
Old 11-06-2009, 07:11 PM   #6
terente0081
Try Koolance for SB/NB & QPI and EK for mosfets.
terente0081 is offline   Reply With Quote
Old 11-06-2009, 10:09 PM   #7
knet370
knet370's Avatar
this is what i use. works well..
bitspower nb/sb/qpi block and their mosfet blocks too..
__________________
Components: Intel i7 965, Asus Rampage II Extreme, Nvidia GTX 285 SLI, Team Xtreem DDR3 1866 3x2gb, Corsair HX1000, WD Caviar Black 640gb, WD Caviar Black 1tb, Samsung 2693HW 26" LCD, Lian Li PC-A77b
Cooling: Swiftech Apogee GTZ, Bitspower Mobo Freezer & Mosfer Freezers, EK GTX 285 Acetal/Nickel, EK D5 top Rev 2, EK 150 Res, MCP655 Pump, DD/Feser 3/8-5/8 White tubing, Arctic RC Ram Heatspreaders, 3 x Yate Loon H's, 3 x Sharkoon 120mm, Scythe Kaze Master Ace, BP 3/8-5/8 Compression Fittings, Various BP Elbow/Adapter Fittings
knet370 is offline   Reply With Quote
Old 11-07-2009, 12:43 AM   #8
cx-ray
V
I've tried the Mips, EK and Bitspower blocks for the R2E.
Mips: easy to setup and works well. Kind of restrictive from the looks of it though (mosfet in/out are only ~half the diameter of G 1/4).
EK: what can I say? It looks nice, but fit isn't very good. They corrected the small mosfet block, but the larger one still has holes spaced too far apart. The NB/SB block doesn't cool everything the original one does. Not sure whether it matters, but I'm not going to let it sit there for a while to find out if something blows up
BP: nice blocks and good performance. Mount for the QPI/DRAM section is ill constructed however. There's no access to the mounting screws after you install the top block part. It's only held to the lower NB/SB section by a D-plug and a flimsy screw with a little spring. To get it to seat deep enough I had to countersink one of the screw holes under the plexy mount plate. Admittedly, it's in part due to using my own 1mm thick thermal pad there instead of the provided 0.5mm. I changed the pad thickness, because 0.5mm is quite delicate and punctures easily when you push on the QPI/DRAM block section. You do not want to risk a short there.
cx-ray is offline   Reply With Quote
Old 11-07-2009, 01:01 AM   #9
dreamaxx
dreamaxx's Avatar
I LOVE the Koolance NB+SB block it's beautiful, and I use the EK mosfet blocks because I had a few problems with the koolance blocks causing warping of the board (something that may be fixed now, not sure).
__________________
FML
dreamaxx is offline   Reply With Quote
Old 11-07-2009, 02:01 AM   #10
bundymania
bundymania's Avatar
...to mention more brands - MIPS has also a nice Set for this Board:
www.mips-computer.de
__________________
Black Bullet: Corsair Obsidian 800D Intel Core i7 920@4Ghz EVGA X58 SLI LE @MIPS Waterblock Samsung SSD PB22-J/PM800 2.5" 128GB Mushkin 6GB DDR3-2000 Kit Palit GTX 295@Bitspower Waterblock Samsung 3 x 1 TB F1 HDD Creative X-Fi Xtreme Music Cougar S700 PSU HP w2408h // Watercool Mora 2 Pro Rad. Laing DDC Ultra @Zern P12 Top Watercool Heatkiller 3.0 Chrome Edition Aqua Computer Aquaero VFD Alphacool Cyclone 200 Res.
Testmachine: Banchetto 101 Gigabyte GA-EX58 Extreme Intel Core i7 920 Sapphire Radeon HD 5850 Corsair 6GB DDR3 1600Mhz Samsung 2TB SATA F1 HDD Seasonic M12D-850 PSU
HTPC: Antec Fusion Remote Max Gigabyte GA-MA69GM-S2H AMD BE-2350 Noiseblocker Twintec Aeneon 2GB DDR2-800 Asus Radeon HD 4350 WD 2TB HDD Xilence XQ LinearPower 850W PSU Samsung LE-40M86BD Onkyo TX-NR807
Server: Thermaltake Lanbox Lite Intel E5200 @3.2Ghz ASUS P5KPL-AM Patriot DIMM Kit 2GB ATI Radeon HD 4670 @ Alphacool Waterblock Samsung F1 2TB HDD Magicool Slim Triple Rad. Innovatek PCPS Pump Corsair HX 450W PSU
Notebook 1: Samsung 17" SE11 Aura P8400 Donato - NB2: Samsung 17" E272 Aura Erohl // XBOX 360 Elite // Nintendo WII // Motorola Droid
bundymania is offline   Reply With Quote
Old 11-07-2009, 04:35 AM   #11
Edward88
Can i use the hole pcie x1 with the bp solution?
Koolance for example lets you the space for the little sound card, but if i want to use a bigger sound card im f . . .
Old 11-07-2009, 05:36 AM   #12
cx-ray
V
PCI-e cards up to about 180mm will fit.
Old 11-07-2009, 06:53 AM   #13
mjtir
Where is the Koolance Block ?
My motherboard is on the way but i can not find the koolance's motherboard block anywhere. Does anyone know what is going on ?
mjtir is offline   Reply With Quote
Old 11-07-2009, 08:52 AM   #14
bundymania
bundymania's Avatar
Do you live in the USA ? You can order direct at koolance.com
http://www.koolance.com/water-coolin...product_id=771
special discount price
__________________
Old 11-07-2009, 09:53 AM   #15
Hondacity
wow cheap price....
no water on it though but thats a good idea...i wonder if my enzo fits right thru it
__________________
Hondacity is offline   Reply With Quote
Old 11-07-2009, 11:54 AM   #16
Edward88
Anyone have the r2e with the bps blocks???
Old 11-08-2009, 07:54 AM   #17
sanhacker
I went with Koolance for the NB/SB and EK for the MOSFET's.
Working great for almost a year.
Bitspower coupling between the MOSFET's and CPU.
sanhacker is offline   Reply With Quote
Old 11-08-2009, 08:01 AM   #18
NaMcO
NaMcO's Avatar
This is pure sex, main reason why i'm gonna use these with my next build
__________________
Rampage 2 Extreme · GTX295 SLI 1792MB FTW · Core i7 920 4.2GHz · Corsair HX 850W · SupremeFX X-Fi
6GB GSKill Trident PC3-16000 · Intel SSD 80GB RAID0 & Samsung F3 1TB RAID0 · Silverstone TJ07 · Samsung 24"
NaMcO is offline   Reply With Quote
Old 11-08-2009, 12:32 PM   #19
CptDreadFlint
CptDreadFlint's Avatar
I'm currently using the BP Full block and the EK mosfets
__________________
Now Playing
black freighter: i7 920 | evga classified | mm extended ascension pedestal | 2 x 300gb vraps
dead men tell no tales build: q9770 | asus striker 2 extreme | 2x4gb ddr3 ocz reaper | 2 x gtx 280 oc2 | 2x 300gb vraps | mm ufo-cyo | pcp&c 1200W
CptDreadFlint is offline   Reply With Quote
Old 11-09-2009, 12:56 PM   #20
Feklar
Beware of the Grey Goo
Feklar's Avatar
If anyone is interested in the Enzotech blocks:
http://www.performance-pcs.com/catal...ducts_id=26693
Feklar is online now   Reply With Quote
Old 11-11-2009, 12:21 AM   #21
mjtir
My thoughts
Bitspower is the only one piece implementation right now since Koolance Full motherboard block for some reason is retired
But i agree with cx-ray . I'm not feelling comfortable with the implementation on QPI/DRAM .
Enzotech is good looking , secure in every way , but the three pieces alltogether cost 250 $ , way to expencieve for my pocket.
Ek . I own a few Ek's waterblocks and i'm very happy , but this implementation is rather poor for such a motherboard , take a look at his EVGA class. I'm disappointed.
Right now in seems ramapage II Gene would be a better choise
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
