XtremeSystems Forums
Reply
Old 11-05-2009, 02:34 PM   #1
Barso
How is the thermochill EC6 coolant?
Can anyone rate the new thermochill EC6 coolant for me?
Is it any good?
Thanks.
Barso is offline   Reply With Quote
Old 11-05-2009, 02:56 PM   #2
Salamndar
Salamndar's Avatar
Is it any good?
Thanks.
There was a complete thread and a review about it, use the search option to find it.
Salamndar is offline   Reply With Quote
Old 11-05-2009, 03:30 PM   #3
shazza
Xtreme Fan
shazza's Avatar
It's here, in the sticky at the top on Information/Reviews...
We don't have too much else to go on at the moment, but the general consensus is, you're better off with plain distilled water and a biocide ... colored tubing can be used if you want to add some color -- with LEDs in the reservoir.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
