XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 11-05-2009, 06:00 AM   #1
bartx
bartx's Avatar
Send a message via MSN to bartx
Phase hall of fame
I've got an idea about sticky topic - Phase hall of fame. Could we make a new topic with the best units in this section? I mean builds, which were built very clean or these, which have the best temperatures, good solutions, innovations, or worklog is just cool . This section has a lot of threads - it's really hard to spot all interesting units. Worklogs really helps when you're building your own unit, you can find out a lot of useful info.
How do you like my idea?
bartx is offline   Reply With Quote
Old 11-05-2009, 06:53 AM   #2
ruffus
ya this sounds like a good idea i would have some units to put up in this thread if we do this
ruffus is offline   Reply With Quote
Old 11-05-2009, 07:03 AM   #3
teyber
Xtreme Mentor
teyber's Avatar
http://www.xtremesystems.org/forums/...d.php?t=165728
it was updated not THAT long ago
teyber is offline   Reply With Quote
Old 11-05-2009, 07:27 AM   #4
bartx
bartx's Avatar
I know about this topic, but I think it's rather a history of this section than a database of all the best units.
Old 11-05-2009, 07:43 AM   #5
zalbard
Xtreme Mentor
zalbard's Avatar
Send a message via MSN to zalbard
Originally Posted by teyber View Post
If 2 years is not long for a forum thread then I don't even know what to say...
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Looking for Gulftown / Westmere ES
zalbard is online now   Reply With Quote
Old 11-05-2009, 10:14 AM   #6
SexyMF
Needs more time
SexyMF's Avatar
I would just add threads which have a decent amount of info and a conclusion. Clean builds are usually just the result of having money to buy everything new - which IMO doesn't reflect on skill, innovation or understanding.
SexyMF is offline   Reply With Quote
Old 11-05-2009, 10:35 AM   #7
bartx
bartx's Avatar
You have a point SexyMF, but look at this thread: http://www.xtremesystems.org/forums/...d.php?t=218389
Such a clean build and it isn't a result of having money - almost all is hand made.
Old 11-05-2009, 10:54 AM   #8
Foamy
Banned
A sticky that bundles all the worklogs woudl be cool already
and some better problem/solution guides would be cool as well.
Foamy is offline   Reply With Quote
Old 11-05-2009, 10:03 PM   #9
SexyMF
Needs more time
SexyMF's Avatar
Yes. A nice tidy build indeed, but tidy doesn't equate to performance. It's all good but I'm a function over form guy. How did it perform on a CPU - being the real test.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
