I would like to swap my old good Fuzion v2 with the new wb.
Which block is the best for LGA775?
Swiftech Apogee XT or Watercool HeatKiller Rev. 3 ?
I`m going to go LGA1366 platform next year when Gulftown be on market and save new the new block for it.
__________________ Asus Maximus II Formula 2202 Bios Intel E8400 500x8@1,176V and 500x9@1,35V OCZ Blade Series PC2-9600 4GB 1200MHz/5-5-5-15/PL8/1,8V Seagate RAID0 2x Barracuda 7200.12 500Gb HIS Radeon HD3870 IceQ3 Turbo 512Mb Iiyama ProLite E1902S-B1 Black Thermaltake Xaser VI BWS Seasonic M12-700 Watts M-Audio Audiophile 192 Liquid Cooling System : D-Tek FuZion v2, Swiftech, MCW-NBMAX, ThermoChill PA120.3, Laing 12V DDC-1Plus, XSPC Laing DDC Reservoir Top Feser VS.C° Heat Carrier, Feser Base Corrosion Blocker, Arctic Cooling MX-3, 3x Scythe S-FLEX SFF21F, Scythe Kaze Master Ace 5,25''
As far as performance goes, they are pretty much equal. The XT is a degree better on Vapor's test Core I7.
I prefer the XT as it is more user friendly and includes a backplate. You will just have to send Gabe an e-mail to get your 775 backplate. The mounting plate is slotted so it works with almost any socket.
THe HK, you will have to order a 775 block and backplate, then order a 1366 mounting kit and backplate when you upgrade.
If you want bling, a HK 3.0 CU nickel plated can't be beat for bling.
You should get the 1366 backplate, then e-mail Michelle@swiftech.com for your 775 backplate. They will send it to you for free IIRC. I'm not certain if the 1156 backplate will be included, but if you need it, e-mail Michelle at Swiftech and they will send it to you.
I would wait for a plataform upgrade to change the waterblock.
It will not worth the investment on a new block.
__________________ My Lian Li PC-G70W
Q6600 @ 3.6GHz @ 1.43V - Sapphire 5870 1GB 900Mhz/1300Mhz - 4GB Gskill 1066 - Corsair P128 SSD - Asus Maximus Formula - Lian Li G70W Powdercoated
Watercooled by single loop PA120.3 + Swiftech MCR220 with San Aces H1011 - D Tek Fuzion V1 - EK NB-Max - Koolance Vid-AR587 - Swiftech 355 with XSPC Top/Res
I would go with the Heatkiller water block they also have diff mounting brackets for each socket.
__________________
Antec 1200 Case
E8500
Asus Rampage Formula
8 Gigs Mushkin 1066 Ram
2 x 500 Green WD Drives
2 x Lightscribe Dvd Burners
2 x Ati 5870 xfire
EK 5870 Water Blocks
Corsair HX 1000 Watt Pws
Heatkiller 3.0 775 Water Block
Bitspower Nb/Sb Block
2 Xspc Dual Bay Pump/Res Combo
Xfi Sound Card
Black Ice 240mm Radiator
Antec 200mm Radiator
180mm Fan
The Swiftech only needs a different backplate. The mounting bracket is slotted so it will mate up with about any socket. IIRC, the 1366 was included and the 775 and 1156 backplates could be requested if needed. They didn't cost any extra though. i would PM Gabe to be certain though.
If you perfer a HK, I would just wait till the upgrade as the bracket and backplate cost almost $30
