XtremeSystems Forums
Reply
Old 11-03-2009, 08:47 PM   #1
yiannit
mass debating on radiators/fans
this will be my first watercooling setup and i've come to the decision on these 3 different radiators
hw labs gtx480
hw labs sr1 480
or the feser xchanger 480
and fans either sflex 1900s or typhoons 1850s (only problem with thes is theyre molex connector)
any suggestions or reasons i shouldnt get this?
this will be to cool i7 920 and x2 5870s with swiftech 355
yiannit is offline   Reply With Quote
Old 11-03-2009, 08:57 PM   #2
Kibbler
Kibbler's Avatar
For those fans go with the GTX480, especially if you plan to run them at full 12V.
Others will probably say GT1850 is better in terms of noise/airflow/pressure than S-Flex and although I'm keen to agree, I have no 1st hand experience with both so cannot say for sure.
Kibbler is offline   Reply With Quote
Old 11-03-2009, 09:02 PM   #3
Hondacity
480gtx + gt1850 push pull
__________________
Hondacity is online now   Reply With Quote
Old 11-03-2009, 09:33 PM   #4
shazza
Xtreme Fan
shazza's Avatar
Agree - the GTX is a good choice for those fans ( although all the radiators will work fine).
Not sure what you mean about the fans being connectied via molex. Are the 1850 GTs different than the 1450s?
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 11-03-2009, 09:49 PM   #5
woffen
woffen's Avatar
At least my GT 1850's are all connected with a 3pin. Molex connectors are included though.
woffen is offline   Reply With Quote
Old 11-04-2009, 03:06 AM   #6
primer
Is there much diff in temps between GT 1850 57cfm and GT 1450 50cfm?
primer is offline   Reply With Quote
Old 11-04-2009, 03:26 AM   #7
zipdogso
I am Xtreme
Im sure if you can find Martins test on rads and fans all will be revealed, in a quick search I couldn't seem to find it but I sure someone will have the link.
BTW don't say the title of the OP's post too quickly...you might get a surprise double meaning ...
__________________
Upgrade your XS account with a subcription
http://www.xtremesystems.org/forums/....php?f=94&a=66
zipdogso is offline   Reply With Quote
Old 11-04-2009, 04:51 AM   #8
Sadasius
Tygon Warrior
Sadasius's Avatar
If your sensitive to sound then get the rads with the greater fin spacing. If your into performance and put fans on high or have them on a controller to have them high from time to time then the GTX is your rad. Other rads just don't touch it about a certain RPM level. I have two 240 GTX rads with the fans in my sig. I usually have the fans set on 2500 RPM but they can each go to 6000 RPM and that is at 260 CFM of air EACH. I would do that on no other rad then the GTX as it has a tighter fin density and the dual pass is over and under instead of side by side. To me it is the superior designed rad.
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 11-04-2009, 07:40 AM   #9
Ketzer7
Ketzer7's Avatar
Sadasius, which side of the GTX do you have your fans blowing on? The hot side or the cold side? Same question with fans in pull; pull from cold side or hot side?
In my head, it seemed that you would want fans to push on the cold side, so heat is going away from it, and pull on the hot side so again heat is moving away from the cold one. Is that right?
Ketzer7 is online now   Reply With Quote
Old 11-04-2009, 07:54 AM   #10
yiannit
thank you for the help
what does his mean? from the hw labs sr1
Yields up to 30% more heat exchange capacity than the Black IceŽ GTX in ultra-stealth operation mode up to 2000rpm.
i made a mistake on the gt fans they are 3 pin. and i'll be using the bigng fan controller
Old 11-04-2009, 08:02 AM   #11
Ketzer7
Ketzer7's Avatar
The SR-1 is optimized for better heat transfer at low fan RPMs by way of it's low fins per inch (FPI) specification which I believe is 9 FPI.
The GTX series of rads on the other had are optimized for high RPM speed fans with more static pressure as they have a fairly high FPI of ~20.
As a result the GTX doesn't perform as well at low fan RPM speeds because with it's high FPI it's more restrictive to airflow through it so it's not cooling the water passing through as effectively as it would be with a low FPI rad like the SR-1 which is less restrictive to airflow through it.
If you want to see tests showing the effect of this, I suggest taking a look at skinnee's site and look at the test results between several different makes of rads to get an idea of their performance:
http://www.skinneelabs.com
Old 11-04-2009, 08:18 AM   #12
Sadasius
Tygon Warrior
Sadasius's Avatar
I have them on both sides in push/pull on both rads. Let's just say I am always within 3 degrees of ambient (water temp) and I have everything on one loop with 2 pumps.
__________________
Old 11-04-2009, 10:10 AM   #13
ChielScape
they say the SR-1 will beat the GTX in all fanspeeds up to 2000 rpm, where the largest difference is 30%, that doesnt mean the 30% is at that 2000 RPM. if that 2000 rpm figure is accurate, thats where they will be roughly the same. practice shows however, that for most different rads, that point is around 1200-1500 rpm, and the SR-1 is most likely no different. that 30% is easy to believe around the 600 rpm range. and up from there the difference gets smaller untill the GTX gets the upper hand. they say that happens at 2000, i say it does at 1200-1500 with similar rads doing the same. (XSPC RX, Thermochill PA... they all lose to the GTX over 1200-1500 RPM)
ChielScape is offline   Reply With Quote
Old 11-05-2009, 12:04 PM   #14
yiannit
wen placing the fans to pull does it matter which side on the radiator the fans are?
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
