XtremeSystems Forums
Reply
Old 11-03-2009, 03:29 PM   #1
wolven
I am Xtreme
Swiftech Komodo for gtx285 & sli
Simple yet silly question:
Looking at my next "upgrade" for computer, and at a 3-sli setup with the swiftech gpu blocks, but their diagram isnt showing how the sli is connected for seperate loop. From what I can tell, it looks like they are just butting the 2 plugs against each other, and slapping a tube over them?, or am I missing something?
My other question would be this: can a single swiftech inline 355 put enough pressure / circulation on 3 of said card with no problems, or am I going to need a major pump upgrade? (I'm also switching up to an i7, but i know a 120x3 swiftech will cover that cooling with 6 fans doing push/pull :P ).
wolven is offline   Reply With Quote
Old 11-03-2009, 03:49 PM   #2
creidiki
Xtreme Guru
creidiki's Avatar
Send a message via AIM to creidiki Send a message via MSN to creidiki Send a message via Yahoo to creidiki
GPU blocks aren't very restrictive right now, and the DDCs have a lot of head, but 3 GPU blocks with something like an XT on the CPU may be pushing your luck a little.
Unless of course I misunderstood, and you're running separate loops, in which case no issue at all. Personally I wouldn't put 3x modern GPUs and an i7 on a single triple, but there you go. I'm not a big fan of multiple rads or multiple loops, but that's a lot of heat, bra.
__________________
Originally Posted by Bloody_Sorcerer
flowrate is for losers!
Originally Posted by MaxxxRacer
Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
creidiki is offline   Reply With Quote
Old 11-03-2009, 03:54 PM   #3
Hondacity
i tried tripple sli and an i7 thats overclocked...its not fun with gpu's folding and the cpu crunching...with one quad rad...
but if you're into gaming..a quad rad is sufficient...other apps need better cooling...
__________________
Hondacity is online now   Reply With Quote
Old 11-03-2009, 04:52 PM   #4
wolven
I am Xtreme
I'm using 1 loop for cpu ( and maybe memory if i ever get that board ), and one for gpu.
Old 11-03-2009, 09:30 PM   #5
creidiki
Xtreme Guru
creidiki's Avatar
A triple will serve for the GPUs then, though for 3x SLi I'd try to squeeze a 120x4 in there. And a single DDC+ should be ample, if you stay in the usual low-restriction stuff (swiftech, ek, etc).
__________________
Old 11-04-2009, 02:13 PM   #6
wolven
I am Xtreme
I guess I should have quantified this a bit more haha..
There will be no 'squeezing' involved.. its a MM ascension extra long.... If I was feeling excessively silly, I could put 4 more 120x3's in the top, and at least 1 more on the back
Anyone know at what point you stop getting improvement in graphics using multiple videocards? I may just stick with 2 video cards that are high end and the i7 unless theres a major benefit from 3.
Old 11-04-2009, 02:56 PM   #7
seamadan
Anandtech.com did a pretty good article on 3 way GPU systems: http://www.anandtech.com/video/showdoc.aspx?i=3518
The upshot is you get under a 50% increase in performance over 2 GPU setups and about 140% over single cards at the most- that's using SLI, Crossfire didn't scale as well under most of their tests. Also, unless you're using 2560x1600 resolution, or higher, it's pretty pointless, as all the games were handled well at lower resolutions by 2-way, and this was when the GTX285 was top of the heap. It would probably be worth it to check out the full article, even if it's a little dated at this point.
seamadan is offline   Reply With Quote
Old 11-04-2009, 08:22 PM   #8
wolven
I am Xtreme
Thanks for the reply. I'll prolly be going with 2 of whatever the newest and greatest is when i go to order in the next month.. I figure that + new mb + new i7 + water blocks will cover my moneyz for awhil hehe
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
