11-03-2009, 02:12 AM
#1
Tubing routing ideas needed
I had thought this would be really easy putting all together but I changed the HK 3.0 for the Swiftech XT in the last minute and didn't consider the position of the outlet on the Swiffy.
Pictures speak a thousand words:
Wish there was a fitting that could connect those 2 somehow
Yaiks, that doesn't look too good
Some random ideas, doesn't look too good
Fail, the compression fitting wont fit on the EK NB block
The reason there is no tubing attached is because I haven't received my CPU yet so the XT is just laying on the socket to illustrate the problem.
So if anyone has any good ideas, they'd be more than welcome!!??
11-03-2009, 03:12 AM
#2
In picture 2, is it possible to replace that tubing with a 45 degree fitting?
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
11-03-2009, 09:43 AM
#4
I am Xtreme
__________________
11-03-2009, 09:54 AM
#5
Originally Posted by Waterlogged
Nice! Thanks for that Waterlogged. If I only knew which one to get. And ordering one of these to Finland will probably cost me a fortune in just shipping.
11-03-2009, 10:06 AM
#6
I am Xtreme
Go back to your first setup and measure the distance between the fittings. Judging by that first pic, I'd say you'll most likely need the 1" model. Don't take my word for it because pics are a really bad way to judge scale and size.
__________________
11-03-2009, 10:09 AM
#7
Do you happen to know the sizes of the others as well? It doesn't say on the PPC page at least.
EDIT:
The distance between these two is 2,6 cm or and once inch is according to google, 2.54cm. Maybe that is close enough.
11-03-2009, 10:20 AM
#8
I am Xtreme
__________________
11-03-2009, 10:24 AM
#9
How about rotating the apogee XT 180 degrees on the cpu mount...that will increase the distance the the (NB block)?
If you did that you might have to use the "alternate configuration" of the XT to route your tubing to the inlet more easily
__________________
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rick Cook
11-03-2009, 10:29 AM
#10
That would make the inlet above the outlet, which from what I've understood could build up bubbles in the block..?
11-03-2009, 10:47 AM
#11
Only if there is air in your system, and your pressure is low. Since the ApogeeXT is a highly restrictive block, you wont have to worry about cavitation like in an HK, and the pressure in the system should keep any of that in check...
Blocks are mounted with the inlet on top all the time...
..look at the BP Mosfet cooler for the x58 classified....its usually mounted with the inlet on top...granted mosfets are not a processor
__________________
11-03-2009, 10:59 AM
#12
I know it's done, but I'd prefer not to do it. Maybe it wouldn't matter at all..
I will definitively consider it, thank you.
11-03-2009, 02:28 PM
#13
or you can try adjustable sli fittings *shrug*
11-04-2009, 06:18 AM
#14
You could use good old fashioned straight plastic barbs, and then use the larger loop of tubing like your second pic. That might not fit your system's aesthetic though.
11-04-2009, 07:45 AM
#15
Xtreme Cable Management Freak
why not just run a D-plug beteween the 2 90degree fittings? kinda like how you would for sli'ing graphics cards?
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
11-04-2009, 09:50 AM
#16
I ordered a set of these today as Caoder suggested:
http://www.chilledpc.co.uk/shop/prod...oducts_id=1066
The D-Plug I needed I couldn't find in Europe except for in Highflow.nl, but they wanted 23€ to ship a 6,50€ part so no thx. I had stuff coming from Tom anyhow so was easy adding that. Hopefully it turns out well. Otherwise I will have to search for that 1inch D-Plug again.
11-04-2009, 10:13 AM
#17
Broken Gainestown
use D-PLUGS as connectors.
did u see my pictures? LOL..
im the only one that does this..
Then again im the only one of this forum that will end up doing crazy stuff with fittings.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
11-04-2009, 12:07 PM
#18
That's really nice, but as I said, I refuse to pay 30€ for one D-Plug. It just is too much. Are those D-Plugs adjustable NaeKuh, as in length?
11-04-2009, 12:17 PM
#19
I am Xtreme
Yes, you are one of the few who displays huge dusty pictures of their rig on a regular basis...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
