XtremeSystems Forums
Reply
Old 11-03-2009, 01:17 AM   #1
ohms
VČ/P
ohms's Avatar
Send a message via AIM to ohms Send a message via MSN to ohms
Bitspower Water Tank 150 question
I purchased one of these recently for my upcoming build and I was wondering which of the holes is the inlet and outlet?
Also, I know for sure that the top is a fillport but my question is why is there an Anti-Cyclone adapter where the fillport would connect?
__________________
My Worklog: Project Raven ATCS 840
Today the guns are silent. A great tragedy has ended. We have known the bitterness of defeat and the exultation of triumph. And from both we have learned, there can be no going back. We must move forward, to preserve in peace what we've won in war." - Douglas MacArthur
ohms is offline   Reply With Quote
Old 11-03-2009, 02:04 AM   #2
aoch88
aoch88's Avatar
The inlet/outlet is up to you It would depends on how you configure it.
__________________
Intel Inside
aoch88 is offline   Reply With Quote
Old 11-03-2009, 02:17 AM   #3
ohms
VČ/P
ohms's Avatar
Ummm, I've been toying with the top being my inlet using a Koolance 4-way nozzle body
Left - return from blocks
Right - capped
Top - fillport with Koolance Ball Valve
Bottom - where the metal tube is, fluid into the loop
My thought on connecting the valve to the top section of the 4-way nozzle body is to prevent back flow up into the fillport tubing.
__________________
Old 12-23-2009, 02:30 PM   #4
bbross
Hello !
Could someone provide me with some additional explanation ? I'm building my first watercooling setup and I am facing the same question...
Should the inlet be the whole with the inner tube ? Or should this be the outlet ? Why ?
I've found no definite answer on that matter...
Thanks guys !
bbross is offline   Reply With Quote
Old 12-25-2009, 09:50 AM   #5
bbross
Hello guys,
Isn't there anyone to provide me with detailed information about the bitspower reservoir ?
I understand it might seem like a dumb question but still... i'd be glad to get a clear answer :-)
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
