11-02-2009, 07:18 PM
#1
VČ/P
Help: Sleeving wires
After you guys get the sleeving kits what do you use to shrink the end wraps? Are you guys using heat guns?
__________________
My Worklog: Project Raven ATCS 840
Today the guns are silent. A great tragedy has ended. We have known the bitterness of defeat and the exultation of triumph. And from both we have learned, there can be no going back. We must move forward, to preserve in peace what we've won in war." - Douglas MacArthur
11-02-2009, 07:20 PM
#2
I use a pocket blow torch. I'm very careful with it to avoid melting the sleeving or staining the heat shrink.
__________________
Please note: I am not here to provide any kind of official NCIX support on these forums.
For faster (and official) service please contact me at Linus@ncix.com, or please contact our customer care team at wvvw.NCIX.com (Canada) or wvvw.NCIXUS.com (America)
Heatware: http://heatware.com/eval.php?id=25647
11-02-2009, 07:21 PM
#3
Xtreme Guru
I just use a lighter. Heat gun works too.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
11-02-2009, 07:24 PM
#4
Xtreme Fan
A hair dryer works well. You can also use a lighter for black heatshrink, but it's easy to burn it, so not what I'd recommend.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
11-02-2009, 07:26 PM
#5
VČ/P
hrmmm... hair dryer it is if i'm too poor to buy a heatgun
Thanks for the fast responses.
__________________
11-02-2009, 07:27 PM
#6
i was using a candle.. baaaaddd idea.. tends to burn the heatshrink (red small from mdpcx...) switched to heat gun borrowed from a friend works perfect and fast
11-02-2009, 08:58 PM
#7
My friend has a torch with a heat-gun end. It worked great for me.
__________________
The parts:
| MSI 790FX-GD70 | Phenom II 965 140W | Sapphire HD 5870 | 2x2 GB G.Skill Ripjaw DDR3 1600 7-7-7-21 | 3 x 250 GB SATA HDDs | 1 x 1 TB WD MyBook External | Corsair Obsidian 800D |
The cooling:
| PrimoChill Typhoon III Bay Reservoir/Pump | MCR320 | 3x120mm 1450 RPM Scythe GentleTyphoon | HeatKiller REV3.0 LT | EK HD 5870 FC Nickle | ThermoChill PA120.2 | 2x120mm 1900 RPM Scythe S-Flex |
11-02-2009, 10:53 PM
#8
I use a lighter to melt the ends and heatgun to shrink. My heatgun has 300C and 600C settings, but 300C is more than enough.
Tryed hairdryer - shrinks slow and sometimes not completely.
__________________
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
11-02-2009, 11:03 PM
#9
yea.. heat gun for ends are bad.. the whole sleeve tends to fray like crazy xD... i used my candle to melt the ends and the heat gun to shrink it.. one other issue i ran into the the candle when heatshrinking was that the heatshrink would occasionally seem to create folds... so it looked kinda bad :/
11-02-2009, 11:56 PM
#10
I used a hair dryer which worked fine. Next time i might try and find a heat gun though, the hair dryer seemed to not always completely shrink the heatshrink, as aka_GK mentioned.
__________________
twwen2 convo:
Brenton(switch8): "what's the assignment like? Is it hard or just big?"
Tom(twwen2): "both long and hard"
Tom(twwen2): "omg that sounded so dodgy! LOL"
[Project Switch Box] My Build Log.
11-03-2009, 03:17 AM
#11
Heat guns are the only method I can recommend. It's far too easy to burn it with candles, soldering irons and lighters and you never get an even shrink with any of those.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
11-03-2009, 06:09 AM
#13
Heat gun would be the perfect tool. My hair dryer don't seems to have enough heat.
11-03-2009, 06:21 AM
#14
You could also put your hand on the back of your hair dryer to get the hair dryer to heat up more. This stops the air going through from the back end.
11-03-2009, 09:00 AM
#15
I guess it is not nice for the hairdryer
__________________
11-03-2009, 09:26 AM
#16
Like many others, I use a hair dryer...my wife has a fancy high heat ceramic something or other...
it works well for me
__________________
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rick Cook
11-03-2009, 02:54 PM
#17
Same.
Mine tends to blow cool air after a minute or so when it is set to HOT and HIGH.
Piece of crap.
__________________
Rig:
Intel Xeon W3520 @ 4.1GHz (1.20V) | Gigabyte GA-EX58-UD4P | OCZ Platinum 6GB PC3-12800 (7-7-7-24) | XFX HD 5870 | 2x Intel 80GB G2 SSD RAID 0 | X-Fi Titanium Fatality | Corsair HX850 | CoolerMaster ATCS 840 (Black) | Westinghouse L2410NM / LG L246WP-BN | HP 2335 → Nintendo Wii
Cooling:
HEATKILLER LT CPU Waterblock | Laing DDC-3.2 w/ XSPC Reservoir Top | XSPC RX 480 w/ Scythe Gentle Typhoons
Backup Rig:
Intel Xeon X3440 @ 3.4GHz (1.20V) | eVGA P55 SLI | G.Skill PIS 4GB PC3-17600 (8-10-10-28) | Asus 8800 GS Top | Corsair HX620 | Thermaltake Element G | IBM 21" CRT (1600x1200 @ 100 Hz)
11-04-2009, 10:05 AM
#18
I am Xtreme
I too use a lighter. So far it has worked well enough for me.
11-04-2009, 10:17 AM
#19
Broken Gainestown
ur suposed to continuously rotate it at about 4 inches, and not leave it in 1 spot the entire time.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
11-04-2009, 11:26 AM
#20
I use a lighter to
11-04-2009, 11:54 AM
#21
+1.
__________________
Hardware
11-04-2009, 12:47 PM
#22
MDPC
lighter for black shrinks that are not tooooo big +1 :d
__________________
11-04-2009, 04:06 PM
#23
hair dryer
__________________
Core i7 920 D0 Batch#3845B260 200x21 1.30V HT, 24/7 full stable
DFI LP UT X58-T3eH8
G.SKILL Trident 6GB F3-16000CL9T-6GBTD 1600MHz 7-7-7-19 1.60V
GTX285@vMOD
2xVelociRaptor WD1500HLFS RAID0 / Hitachi P7K500 500Gb
Audigy 4 (SB0610), LiteOn LH-20A1S, Logitech G15, Razer Copperhead
Cool Master Real Power Pro 850W (RS-850-EMBA)
Watercooling:
[Swiftech MCP355 + XSPC Laing DDC Reservoir] -> [XSPC RX360 + 3 x GentleTyphoon AP-15] -> [Apogee XT] -> [MCW30] -> [EK-UT x48] -> [MCW60rev2 + MC14]
PrimoFlex Pro LRT Black 7/16 x 5/8 + BP Fat Boy 1/2
11-04-2009, 04:19 PM
#24
for me, candle does the trick, even the birthday left over one.
__________________
i7 920(3.811G, ), Intel DX58SO, Nvidia 260, Crucial Triple Kit 1600, Areca ARC-1231ML,
MCP655-B, Heatkiller 3.0, SilverCoil, distill, EK RES 250,
Norprene 1/2ID, 8x Silenx iXtrema Pro 120mm.
AS5, Case intake: 21; Case output: 23.
No load: Coolant: 25, Core: 35
Case intake: 22, Case output: 24.
Prime 95: Coolant 28, Core: 57
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
