XtremeSystems Forums
Reply
Old 11-02-2009, 06:25 PM   #1
yiannit
problem finding angle rotary compression fittings
i'm looking for 2 angle compression rotary fittings for my radiator from bitspower but all i can find is these
http://www.performance-pcs.com/catal...ducts_id=24762
http://www.performance-pcs.com/catal...ducts_id=24764
im using 3/8" ID 5/8 OD tubing
i could buy these http://www.performance-pcs.com/catal...ducts_id=24753 and add compression fittings but i would end up paying more
am i missing something here?
yiannit is offline   Reply With Quote
Old 11-02-2009, 08:22 PM   #2
Aedubber
Aedubber's Avatar
Send a message via AIM to Aedubber Send a message via MSN to Aedubber
Gary @ sidewinders has lots of compression fittings etc
__________________
Aedubber is offline   Reply With Quote
Old 11-02-2009, 08:24 PM   #3
yiannit
i looked there but they didnt have the angle rotary compression ones, maybe ill have to call
Old 11-02-2009, 08:36 PM   #4
Waterlogged
I am Xtreme
Waterlogged's Avatar
I don't think BP makes any 3/8" comp style fittings other than the straight variety. P-PC has probably the largest selection of the BP line and if they don't have it, it's likely no one does. I've seen this come up before and the last time it did (about a couple weeks ago, IIRC), I spent a bit of time a poked through the sites BP does have LC gear on and couldn't find anything like your asking for.
__________________
Waterlogged is offline   Reply With Quote
Old 11-02-2009, 09:29 PM   #5
Spawn-Inc
Spawn-Inc's Avatar
what about this?
http://www.performance-pcs.com/catal...ducts_id=25645
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 11-02-2009, 11:01 PM   #6
Utnorris
Utnorris's Avatar
I think he wants a compression fitting built in.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Corsair 800D
I7 920 (3849B028)/Classified/ EVGA GTX 295/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) EK Supreme Classified (NB) EK Water Block / Typhoon III with XSPC RX360 / B*P/Koolance Compression Fittings and Quick Disconnects.
Utnorris is online now   Reply With Quote
Old 11-03-2009, 05:31 AM   #7
millertime359
Xtreme Guru
millertime359's Avatar
Sidewinders really on carries angle fittings and comp fittings separate. They don't stock the angle comp fitting the OP is looking for.
+1 on waterlogged. If PPC doesn't have it, there is a 99% chance no one does.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 11-03-2009, 06:44 AM   #8
yiannit
k i guess i'll just by them separate thank you for the help
Old 11-03-2009, 09:29 AM   #9
Setix
Setix's Avatar
I've got 2 brand new BP 45 3/8 I.D. 5/8 O.D. Dual Rotary Compression fittings, if you want them send me a P.M. and we can set something up...
..I got them from PPCs but I ordered the wrong size...
Edit: they are 45 degree...didnt know you needed 90's until now....
__________________
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rick Cook
Setix is offline   Reply With Quote
Old 11-03-2009, 12:01 PM   #10
Spawn-Inc
Spawn-Inc's Avatar
they have some here then.
http://www.performance-pcs.com/catal...46_393_611_625
__________________
Old 11-03-2009, 03:32 PM   #11
yiannit
i've seen all those i was just trying to get angle rotary with compression fittings instead ill buy the angle ones and compression fitting separate
these http://www.sidewindercomputers.com/big1sishro90.html with http://www.sidewindercomputers.com/bi3cofifor5o.html
Old 11-03-2009, 04:23 PM   #12
triggs75
triggs75's Avatar
It will be interesting to see those two together as the compression fitting will be almost the same height as the adaptor and might not be able to tighten the fitting all the way down depending on what your putting it on.
__________________
Components;
»Obsidian 800D
»CPU: Intel Core i7 940 OC'd to 3.69
»Motherboard: Evga X58
»EVGA GeForce GTX 295
»CORSAIR DOMINATOR 6GB (3x2GB)
Water cool parts;
»RAD - EK XT360, EK XT260 & XSPC RS120
»CPU Block - Alphacool H14 Yellowstone BRB
»Koolance Northbridge/Southbridge Water Block
»Black Feeser Mosfet Block
»EK-FC295 GTX GPU Water block
»EK-Multioption RES 250
»2 x Swiftech MCP355™ Water Pump
»XSPC Dual Acrylic Top
triggs75 is offline   Reply With Quote
Old 11-03-2009, 05:07 PM   #13
Hkxyz
Hkxyz's Avatar
I am using the same 90 with a 1/2 3/4 and it fits so those should be fine. They are coming out of a swiftech Rad. It looks to have about a 1/4 inch of clearance before it would hit.
Hkxyz is offline   Reply With Quote
Old 11-03-2009, 07:36 PM   #14
yiannit
I will most likely be putting it on a HW Labs SR-1 480
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
