10-28-2009, 10:44 AM
#1
Xtreme Guru
Wisdom: Knowing how little you know
It's so simple to be wise. Just think of something stupid to say and say the opposite.
- Sam Levenson
*cough*
So ... >_>
I'm planning a new rig/project.
And I need current facts on WC components, because I've been out of the loop. This is where you lot come in
First, the facts:
The Case: Custom. I'm making it out of Avionic Aluminium. I have plenty of experience working with it, so it should be easy enough. I'm ripping the Mobo plate out of my old Stacker 810, RIP old friend, your sacrifice will be appreciated for up to 30 minutes.
The Pump: My RD-30. This means, incidentally, that I care little about how restrictive blocks are, because I have some 30+ feet of head to play with.
The Tubing: a mixture of 1/2 and 5/8, same as my old loop. If you need to ask why 5/8, you've never tried to run the usual 7/16 on the intake side of an RD-30.
Now for what I need help with, to wit:
The Rad: Quite simply, I'm not even considering non-Thermochill rads.
My only question here is, 140.3 or 120.4? Keeping in mind I've been running DS14SM-12 fans on my 120.3 for years, so I'm going to be using them with a custom shroud with either of them. Size is not an issue.
The CPU Block: Something tells me a Storm designed for naked single cores is not quite optimal for a Quad under a soldered metal plate. What do I get?
The GPU block: The Piece I have right now is an EK. Should I stick with Eddy's stuff, or is there something better? I'll be running an ATI card in the new rig.
Thank for your time, peepel
__________________
Originally Posted by Bloody_Sorcerer
flowrate is for losers!
Originally Posted by MaxxxRacer
Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
10-28-2009, 10:59 AM
#2
Broken Gainestown
The ApogeeXT is the top dog.
Followed by the HK 3.0, then comes the KL-350.
All those blocks tho have a 80 dollar tag. :P
The GPU block depends on the generation. If its an old EK, i wouldnt recomend you removing it, because chances are your PCB is warped.
GPU blocks all relatively act the same, so if you had good luck with your EK, leave it.
Your question regarding rad.. i would need to know the gpu and cpu..
If your running a smithfield + HD4870X2 then hellz no....
If your running a moderately clocked Quad or a i7, then i dont see any problems with whatever gpu you throw at it.
If your running high clocks on the i7, and high clocks on the gpu... you might get a little disappointed, when watching both load values...
BTW LTNS creidiki...
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
10-28-2009, 11:03 AM
#3
sounds like you got a billion experience points...
HK is highest quality block out there
swiftech xt is **** ugly
__________________
10-28-2009, 11:06 AM
#4
I cant say that is very "wise" actually. a GTX starts outperforming it over ~1200 RPM for 25mm thick fans, and less for the 38's. (and even less than that for push/pull and/or shrouds) unless you want the really quiet kind of fans, but that makes me wonder why you wouldnt use a quieter pump as well. i personally wouldnt consider the PA's as a matter of fact, but if you like them that much more power to ya :p
that said, get the 120.4. 120mm fans are just better. while for 140mm fans the PA's are the best of all 140mm rads, its more accurate to say they're the least bad ones. 140mm fans just cant do well on rads. unless you get deltas, but in that case... -> GTX.
>CPU block
Let me recommend the HK 3.0. The swiftech XT is supposed to outperform it a little, but the block baseplates arent exactly up to spec. ive heard several people got damaged plates, with lots of bent pins. and since they're small i fear they might break off and get into the pump.
>GPU
cant go wrong with EK. equally good are koolance, and heatkillers. you could get a dangerden, but they perform the worst of the bunch and are really ugly if you ask me. besides that theyre the most expensive last time i checked.
10-28-2009, 11:43 AM
#5
Xtreme kickass
I think i've read somewhere that the 120.4 had a tad more surface area and is better suited for use with 120mm fans but with a shroud that won't matter much.
Your love for Yates might come to a halt when you've heard the Scythe Gentle Typhoon 1850RPM fans, they're worth checking out.
They give very good static pressure, good airflow, low noise and are very durable. Course they're not cheap.
For cpu blocks, Watercool heatkiller 3.0 used to be king of the hill for quad core cpu's but recently Swiftech released a new one that might be interesting.
Good luck with your new build and welcome back.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
10-28-2009, 01:23 PM
#6
Xtreme Guru
A belated hey y'all to all the people here I haven't spoken to in ages.
NaeKuh, I'm changing the GPU and everything, so *shrug* on that.
I'll be running an OC'd i7 and some top-end ATI piece, single card. I don't "do" Xfire/SLI.
ChielScape ... 1200rpm  My D14SMs are hooked to an M-Cubed controller slaved to a digital sensor sunk into a t-piece right before the rad inlet. They usually run @ 450-500rpm.
Also my RD-30 is completely silent, its sitting on a stack of soundproofing and a pad of silicon from Petra's. Its amazing what a little vibration dampening will do for you ...
Anyway, since I'm making the case myself, I'm building it with thick-ass soundproofing in mind - you won't be able to hear anything that's *inside* ... and since I run my fans in pull ... you can't hear anything at all.
Yeah shroud won't matter much, I've been making my custom ones for a while. and I'll be running 140mms regardless because I've found that I get the same temps for less noise. This is, of course, perceptual, and probably down to the lower Hz of the sound coming from a 140. Should I still check out Scythes? They used to be just overpriced rebadged Sony pieces ...
Nice to know Eddy's stuff is well-regarded, he's a top guy
I like gabe's blocks too, but I'll probably go for the EK if they're similar, purely because its easier to get replacement tops since he's also in europe.
__________________
10-28-2009, 01:37 PM
#7
Broken Gainestown
nah single gpu.... 5800 class?
i7?
You'll be fine on either rad with medium fans.
You'll only be disappointed slightly when you have both loaded, or if you were looking for low idle temps.
__________________
10-28-2009, 01:46 PM
#8
Xtreme Guru
Yeah, looking like a 5800 class + i7.
Idle temps are not terribly relevant, or I wouldn't have the fans set to spin down as coolant temp lowers. We're not big on aircon in Italy though, so if there's a better rad for load (which is like 900rpm from my fans, right now), it would be good, so long as its not too noisy a rad, because air temps get to 35c pretty easy in august. I can't seem to find reviews pointing to a large difference between the top-end 4x rads, however. Got a link?
Since the only noise that can be heard is the airflow through the rad, rad noise is an important consideration for me.
__________________
10-28-2009, 01:50 PM
#9
Broken Gainestown
my basic rule i use..
Each 120mm ~ 110W of heat source at a low noise output on the fan.
So total up your theoretical heat load, and match the # of 120 next to it.
150W ~ 120mm with 1600rpm fans.
180W ~ 120mm with 2k rpm fans.
As i said its a very big ballpark number, but it should be accurate for what i think your looking for.
creidiki can you afford the space to do push/pull? you can cheat static even more that way.
__________________
10-28-2009, 02:03 PM
#10
Xtreme Guru
Yeah, I can do push-pull easily enough.
It has to be worth it though - going from 8 to 12 fans means putting down cash for another MiniNG (not to mention 4x 140mm fans), as I'd overload the channels otherwise, as the BigNG and MiniNG only push 25W combined each when in Analogue mode.
Rads are surprisingly good sound mufflers, so I'll have to give serious consideration on whether to keep them in pull inside, and possibly having to let them spin up to the full 1400rpm at peak, or having 4 more outside. The latter may make more noise even at lower rpm, which would mean angled baffle, which means lower airflow, which means higher rpm, etc etc.
__________________
10-28-2009, 02:10 PM
#11
Broken Gainestown
yeah but 2 fans @ 900 RPMs will generate less noise then 1 @ 1400rpm. :P
on a rad you'd probably almost get the same amount of air though.
Your looking at the lower end of the sound spectrum and not the middle.
__________________
10-28-2009, 02:26 PM
#12
Xtreme Guru
They do if they're both in the open air. If the single fan is in a soundproofed case, I'm not so sure. I cant' try it out on my rig right now because of lolblownPSU, but most of what I heard when I maxed them was airflow over the rad. Which is a surprisingly loud wind noise, I may add.
And yes, I am very firmly entrenched in the very low end of the noise spectrum
Well, I have to get at least another 5 fans, or 8 if I'm going to go with the Scythes that were mentioned, so I can run a dead-loop test for noise with the Stacker as a test box. Try 3x in pull @ 1400, and 6x in push-pull @ 900-1000, and see which bothers me the least perceptually.
BTW, what are people using for additives these days? I'm still running an old school "add a couple of teaspoons of zerex" mix with Deionised.
Been debating a reservoir for extra lazyness, but its always a pain to find one that works well with an RD-30 without getting noisy vortexes. Sticking with my old sawn-off dvd spindle t-plug, unless someone knows of a nice res that won't gurgle like Charybdis when hooked up to an RD-30.
__________________
10-28-2009, 02:41 PM
#13
just 500 RPM? you may wanna get 2 120.4's then, since you seem to be going over the top anyway. or 140.3's if you pick those.
10-28-2009, 02:50 PM
#14
Xtreme Guru
The most heat I've had in that loop since I've built it was an Opteron 170 running @ 2.7GHz and an X1900XTX, so yeah, 500rpm kept it about 7c above ambient at 500rpm (idle), spinning to about 900 at load (unless !high summer!). PA120.3 with 3x D14SM-12s in pull.
Since then I've been poor so its been slower, cooler stuff
I'm drawing the line at multiple rads however.
Also, poosticks, its raining and I'm stuck in the hotel
__________________
10-28-2009, 04:36 PM
#15
Get the Swiftech XT block, best performing from tests.
10-28-2009, 05:08 PM
#16
Broken Gainestown
Straight distilled + Silver is the general consensus now.
__________________
10-28-2009, 05:17 PM
#17
Xtreme Guru
"Silver" being?
Thermally yeah, but I'm kind of turned off by all the bottom plates with bent pins.
__________________
10-28-2009, 05:21 PM
#18
Admin
Killcoil, silver tubing (PTS, Sidewinder, Jab-Tech, and maybe a few others have it), or make-your-own silver coil
Good to see you back
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
#19
Broken Gainestown
"Silver" being?
a lot of ways..
1. silver plated barbs... although i dont know how long they last, but they seem to work.
2. A killcoil:
http://www.petrastechshop.com/sikibyia.html
3. Colloidal silver additive.
http://en.wikipedia.org/wiki/Colloidal_silver
4. Silver Ingot inside Res. (classic but effective route) :P
__________________
10-28-2009, 05:30 PM
#20
Xtreme Guru
Originally Posted by Vapor
That looks good enough for me
Also, I love the warning. Petra's <3
edit: btw, what pump setting should I be looking at in your tests, for single RD-30 performance?
__________________
10-28-2009, 05:53 PM
#21
Xtreme Guru
I never noticed that warning before. That is great.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-29-2009, 06:08 AM
#22
Hardware addict
Why do you insist on one 3 or 4 x 120mm when there is also a 9 x 120 mm for example? If sound is your main concern you need surface area. Price can't be the issue because the mo-ra is not expensive (not counting 9 good fans  ).
You could incorporate the design of the mo-ra into the side of the case perhaps, because you are building it yourself. Now if you create some way to add decent airflow through the case and the rad as well, that would most definately make an interesting build.
__________________
Antec P180 Mini - DFI JR X58 T3H6 - Xeon W3570 - 6GB G.Skill 1333C7 - TRUE120 lapped & modded - GTX285 - Intel X25-M (G2) & Samsung F1 640GB
10-29-2009, 06:18 AM
#23
Xtreme Guru
The MoRa 2 performs very well, an yes, its relatively cheap, and yes, I could incorporate it into my case. However:
Balanced airflow with an internally-mounted MoRa 2 means a case with 18x120mm fans.
As much as I like the MoRa's thermal performance, I want 18 fans in my room about as much as I want to have my scrotum nailgun'd to the wall. I'm hoping to have it done with 8x140mm altogether.
__________________
10-29-2009, 06:34 AM
#24
Obsessed Member
Beauty is in the eye of the beholder.
__________________
wEeViL
Browser: Intel QX9650 (3.0GHz) @ 3.6 | Water Cooled by Swiftech | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | eVGA GTX 285 SSC | Customized Lian Li B25B | Antec Signature SG850 PSU | Windows 7 64 RTM
Gamer: Intel i7 920 (2.66) @ 4.0 | Water Cooled by Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
10-29-2009, 08:41 AM
#25
Xtreme kickass
Maybe not.
Maybe you could just do like this guy and use 4x180mm fans (or 4x each side?): http://www.xtremesystems.org/forums/...4&postcount=17
Here's the entire thread: http://www.xtremesystems.org/forums/...d.php?t=235564
How about having it nailgunned to your leg?
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
