10-28-2009, 08:53 AM
#1
Above... Cancer
why dont motherboard manufacturers...
Design a board where all of the component and power connectors come out the back of the board for aesthetics and show casing? While obviously we would need cases to work with these designs, it doesn't seem THAT difficult to do. What do you guys think?
__________________
Intel Core 2 Quad Q9450 Yorkfield @ 3.74GHz | Asus P5Q Deluxe mobo | 2x OCZ Reaper HPC 4GB (2 x 2GB) DDR2 1066 (PC2 8500) | BFG Tech GeForce 8800 GT 512MB | Western Digital VelociRaptor 300GB 10k RPM | Western Digital Caviar SE16 640GB 7200 RPM | PCP&C 750W Power Supply | LIAN LI PC-65B Black Aluminum ATX Mid Tower | Windows 7 64-bit | Dell ULTRASHARP 2408WFP 24-inch Widescreen Flat Panel Monitor
10-28-2009, 08:55 AM
#2
Not really likely, since it's probably part of the ATX standard to have the plugs on the front.
However if you are feeling brave with a soldering gun, nothing says you can't flip the connectors yourself. Wouldn't try it on an expensive board, though.
__________________
Asus P6T | TRUE Extreme Edition | i7 920 @ 3.8Ghz (19x200) | 6GB Corsair DDR3 1600Mhz |
XFX GTX285 Black Edition | 4x WD Caviar Black 640GB RAID10 Array | CoolerMaster Centurion 590 |
Corsair 620HX Modular PSU | Lots and Lots of Fans!
10-28-2009, 08:56 AM
#3
Xtreme Guru
I like the idea. The lack of cases that support this style of motherboard problem could easily be fixed with a Dremel.
10-28-2009, 08:57 AM
#4
Xtreme Guru
+1
I have seen guys solder the wires to the back of the board.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-28-2009, 09:10 AM
#5
Xtreme Mentor
with everyone making the same thing with different colors and layouts, i dont see why one wouldnt do that and charge an extra 20-30$ for a small effort. look at how much watercooling and expesive and beautiful case sales have ramped up in the last few years. hardware ascetics should be right there with them
i vote for this too
10-28-2009, 09:28 AM
#6
It's actually very difficult to de/solder motherboard connectors, due to their multiple-layer nature i.e. density of traces, especially so for some newer motherboards advertising a copper layer (for what? I don't know). Usually the heat dissipates too quickly to melt the surface-mount solder from the factory right away, and more than likely the metal will conduct heat to somewhere it shouldn't be and damage something. Regular old PCB, sure. I remember someone did that recently on a fan controller in their worklog. Multi-layer motherboard PCB, good luck.
10-28-2009, 10:10 AM
#7
Above... Cancer
Well that's why I say the manufacturers should do it. It shouldn't be that hard for them to do... who cares about standards anyway? This is obviously a suggestion for the xtreme crowd armed with dremels
__________________
10-28-2009, 10:18 AM
#8
Xtreme Guru
That would probably involve a re-tooling of the line. That would cost a ton of money for a short run. It would then lead to a bit more than a $40 dollar premium.
__________________
10-28-2009, 10:48 AM
#9
Above... Cancer
How much does a single waterblock cost? People need to think outside the box more and stop being such Xtremely negative nancy's.
__________________
10-28-2009, 10:55 AM
#10
Xtreme Guru
No one is being negative, just realistic. If it cost $100,000 to retool the line and you did a run of 500, that would be a $200 markup on the board to break even.
So that would mean an EVGA classy would then cost $600 instead of $400.
I'm not saying its a bad idea, and that I wouldn't be interested if the price was right.
__________________
10-28-2009, 01:08 PM
#11
You should take a tour around the (any) factory and it would be clear to you very soon how much hard work and recalculation it takes to justify and apply idea like that. Which in final case is just a matter of looks
However I bet if you get 10000 people to make preorders, they will listen to you.
10-28-2009, 01:36 PM
#12
Above... Cancer
I am a manufacturing engineer  I am well aware of new line costs, but I am also very aware of the need for new product development and innovation.
__________________
10-28-2009, 01:51 PM
#13
Dunno if we'll ever see them put the plugs on the back, but at the least it'd be nice if they put them on the plane of the board at the edges, kind of like how they do SATA.
__________________
10-28-2009, 01:54 PM
#14
Broken Gainestown
sorry id have to be majorly intoxicated, or majorly drugged out for me to take a soldering iron to my classy 759.
Expecially since they dont make the 759 anymore, and the 760's are not as reliable as a 759.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
10-28-2009, 03:05 PM
#15
solder the connector. i want to see that :P dont forget to rewire your psu aswell
__________________
e8500 c0 - 4275MHz - 1,344 vCore
DFI UT P45-T2RS
4x1gb D9GMH
Ati HD4870
Modded HAF 932
Watercooled:
Heatkiller v3.0 cu - D-tek Fuzion GFX 2 - PA120.1 - PA120.2 - PA120.4
10-28-2009, 07:34 PM
#16
Perhaps a roundabout solution, now that the northbridge is absorbed in the CPU, perhaps for future boards wher there are more space in the atx realstate, perhaps have a hole (big enough to thresd through the 24 Pin plug) in the PCB right next to the atx plug and a atx direction changer - simmilar to a SLI or Crossfire bridge. without the direction changer, you plug in the atx power as per normal. And with the help of the direction changer, you can have the atx plug thread through the hole in the pcb and have an invisible 24 pin power cable. Slap on some plastic over with LED lights and it will sell like hot cakes  Obviously a 90degree atx plug would be much simpler, for some reason I was researching on this and was told that it's a lot tougher to get 90 degree 24 pin plugs... I forgot why now...
Anyways just an idea, it kinda works in my head, I am not sure if what I wrote make sense.
10-28-2009, 07:43 PM
#17
Well Id buy one and everyone here at our flat would too. It's a great idea and the fact it will cost to the manufacture heaps is just a opportunity for the first one who takes it.
10-28-2009, 09:58 PM
#18
+1
Following design standards & Capital expenditure 101
10-28-2009, 10:02 PM
#19
I am Xtreme
nice dream, oops I mean idea
10-29-2009, 12:36 AM
#20
Anyone from here bought and installed this?
I am thinking some desoldering is needed, that would change the layout a little bit
10-29-2009, 02:22 AM
#21
VČ/P
You gotta have a SERIOUS set of balls on you to attempt installing one of those, I for one have peanut sized ones when it comes to that.
__________________
My Worklog: Project Raven ATCS 840
Today the guns are silent. A great tragedy has ended. We have known the bitterness of defeat and the exultation of triumph. And from both we have learned, there can be no going back. We must move forward, to preserve in peace what we've won in war." - Douglas MacArthur
10-29-2009, 02:28 AM
#22
I am Xtreme
mmmm.. i wonder if I should...
edit:
@OP: ur talking about just the power cables right? like the 20/24pin mobo & 4/8pin CPU power right? just had a look @ a mobo.. looks rather simple actually.. i'm considering
10-29-2009, 03:21 AM
#23
Can't someone give it a shot, we want pics!
__________________
Project TJ07 WeeMaan edition in progress...
i7 920 @ 4,4ghz, P6T Deluxe, Corsair Dominator 6Gb, HD5870, OCZ Vertex 60gb + Samsung F1 1tb
Heatkiller copper, EK 5870, Thermochill 120.4, DDC 3.2
10-29-2009, 03:49 AM
#24
I seem to remember someone already did try, in the worklog section some time back. ben546 or evil98, blueaqua maybe? Don't remember.
10-29-2009, 04:45 AM
#25
Like they say, talk is cheap.
The additional cost to the mb would be horrendous not to mention having to mod your case to fit the plug. And that's about the only way to get it to work is mod a case because I don't see a lot of case manufacturers putting out cases to fit something that doesn't exist right now.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
