10-28-2009, 06:58 AM
#1
What Fittings are safer ?
Hi all , Iam currently using the barbs in the picture below now iam about to get a New waterblock for the 5870 and been looking at : Compression fittings from Coolance how mutch more safe are the compression fittings comparing to the barbs ? Is it worthwile to change all my watercooling setup barbs to it just for the sake of safety?
Thanks in advance.
__________________
I7 920 D0 @ 3800 1.184v
Asus P6TD V2
Asus 5870 1GB
Samsung F1 320gb Raid0
Team Elite 6GB 1333@1600
10-28-2009, 07:01 AM
#2
Obsessed Member
They can both be safe, I prefer to use 7/16 tubing on BP 1/2 fatboy silver barbs, they're a mother to get on, but they don't require clamps, and I think they look clean.
__________________
wEeViL
Browser: Intel QX9650 (3.0GHz) @ 3.6 | Water Cooled by Swiftech | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | eVGA GTX 285 SSC | Customized Lian Li B25B | Antec Signature SG850 PSU | Windows 7 64 RTM
Gamer: Intel i7 920 (2.66) @ 4.0 | Water Cooled by Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
10-28-2009, 07:41 AM
#3
No. If you use steel worm-drive hose clamps that fit, and you make sure they're tight, it's extremely unlikely that they'll leak.
BTW, I would not use 7/16" tubing without clamps no matter how hard it is to get the tubing on the barbs. I've seen a few posts over the years from people who did that and had the tubing pop right off while the pump was running.
10-28-2009, 07:50 AM
#4
Xtreme Guru
Comp fittings are not more secure than a barb is. They are more for show as the look cleaner than a worm drive clamp on a barb.
If you want a secure fitting, get 7/16" ID tube, and an fatboy 1/2 barb like this. Then use a ziptie, or some sort of hose clamp and you won't have to worry about that coming off.
+1
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-28-2009, 08:08 AM
#5
Thanks for the replys guys goin to save a few euros then , cheers for the help.
__________________
Asus P6TD V2
Asus 5870 1GB
10-28-2009, 08:33 AM
#6
I am Xtreme
+1  It's just bad juju to even bring it up.
Many of those ppl also swore that it was safe because "they pulled on the tubing and it wouldn't budge". The problem with that method of "testing" is that the wrong force is being applied. Tubing acts like a Chinese finger puzzle when pulled. . .meaning it'll get smaller the harder you pull, so of course it won't budge when pulled. When a loop gets warm, it does build up a small amount of pressure, if the tubing is pliable enough, it will give way to that pressure and expand, thereby popping the tubing off the barb.
__________________
10-28-2009, 09:48 AM
#7
What where they tugging on those puppies while the system was on? or did it just come off on it's own?
__________________
CPU: Intel Core 2 Extreme QX9650 Yorkfield
Motherboard: Foxconn Blackops X48
Memory: 4G 2x2 OCZ Reaper DDR3 1800 (PC3 14400) 8-8-8-27 1.9v
Hard Drives: 2 x W.D Raptor 150GB (OS, games, apps) RAID0
Video Card: XFX Black Edition 9800GTX @ stock frequency (760 core / 2280 memory / 1900 shader)
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Optical Drives: Nec 3550 dvd burner
OS: Gentoo GNU/Linux amd64 | Windows Vista Ultimate 64-bit
Odds/Ends: Razer Diamondback Mouse - Happy Hacking Keyboad Pro2 - RME pro audio card. FreeBSD UNIX servers and laptop when I'm not gaming!
10-28-2009, 10:01 AM
#8
I am Xtreme
No, they tugged on them before they filled the system. The tubes popped of at a later time.
Over time, as the loop heats up, so does the tubing, making it softer, thus easier to flex. With the added (albeit minor) pressure from the heated water, it's enough in some cases to pop the tubing off. The higher your water/air delta is, the easier this will happen.
__________________
10-28-2009, 10:09 AM
#9
Vinyl tubing stretches too. Pull 7/16" tubing off a barb after the system has been in use for a while, and you'll see the tubing has expanded.
10-28-2009, 10:12 AM
#10
Obsessed Member
My hoses are so tight that I have to use a knife to slice down the side to get them off, otherwise it would take and act of God to get them off. Mind you I would do use my method with the bards the OP pictued, I would only suggest using BP FATBOYS.
__________________
wEeViL
10-28-2009, 10:20 AM
#11
Xtreme Guru
Still, a ziptie would help to keep the tube popping from happening. I also don't think it would look that bad, especially with all the colored zipties out there.
__________________
10-28-2009, 10:36 AM
#12
We still recommend clamps. Most of us can't handle a loss of a mobo, GPU, or PSU due to a leak. Thus we are very cautious to the point of Xtreme. Up to you, peeps do it, it's your stuff, not my stuff.
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
XSPC 360RX and PA120.3 Rads
GTZ CPU and Tieton GPU blocks
Banchetto Tech Station
And the rest of the normal stuff
10-28-2009, 10:45 AM
#13
ive just got 7/16" masterkleer over 1/2" BP Shining silvers and it hasnt been a problem at all. its been together since June.
__________________
SYSTEM
Q6600 @ 3.6GHz - EVGA 780i - 1GBx4 GeIL EVO ONE - HIS 5850 - 1.6TB across 4 drives
Water Cooling
Swiftech Apogee GTZ - ViperJohn 780i - BitsPower 780i MOSFET coolers - DDC-3.2 - XSPC Top - Swiftech MCR320-QP - EK Multioption 150
EK 5850 block in the mail...
10-28-2009, 10:49 AM
#14
Xtreme Guru
No one is saying you can't run clampless. We are just saying it isn't the safest way.
__________________
10-28-2009, 10:51 AM
#15
I am Xtreme
Believe me when I say I've heard every "I'm good" story. Here is one such convert.
Before
After
Please note the dates on those posts, I could probably find closer dated posts if I dug around more but I think this is fine as is.
__________________
10-28-2009, 11:10 AM
#16
Compression fittings are the safest, no way around that.
but barbed fittings with metal worm-drive clamps come in a close second. just dont overtighten them, they will cut into the tubing. but do tighten them well enough.
10-28-2009, 11:49 AM
#17
As RMA manager I have never seen a leak because the fitting was a barb or compression fitting. Leaks are nearly always between the fitting and the block due to improper installation.
__________________
10-28-2009, 01:05 PM
#18
Xtreme Guru
Tbh the only place where I've ever *needed* worm-drive clamps is on the outlet side of my RD-30 - because otherwise even with the the fittings large than the tube, it'll leak like a firehose. Most other places I just use zipties.
BTW, a warning to the wise: if you tighten worm-drive clamps too much, it'll eat your tubing apart, as anyone who'se ever worked on old bikes can attest.
__________________
Originally Posted by Bloody_Sorcerer
flowrate is for losers!
Originally Posted by MaxxxRacer
Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
10-28-2009, 01:46 PM
#19
Broken Gainestown
i like koolance clamps...
Zipties are cool too with the proper tubing and barbs. :P
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
10-28-2009, 05:59 PM
#20
Obsessed Member
Before
After
The mistake he made was using a heat gun to put them on, a heat gun will permanently deform the tube and make it stay that way. I wet the inside of the tube with a little distilled water and push like heck until they start going on. This is what I prefer, I think it looks cleaner.
If putting a clamp on it makes someone feel better about it, more power to them.
__________________
wEeViL
10-28-2009, 06:09 PM
#21
Clamps are like insurance, you can certainly live without them, until something goes wrong...
10-28-2009, 06:21 PM
#22
And just like insurance, when nothing is going wrong you whinge about paying for it...
10-28-2009, 07:50 PM
#23
Broken Gainestown
LOL replying to yourself...
Now ive seen everything...
__________________
10-28-2009, 08:24 PM
#24
I am Xtreme
Where does it say he used a heat gun? I'm 95% certain he uses the boiled water method.
__________________
10-29-2009, 02:36 AM
#25
+1
NaeKuh showed me these and I was sold straight away. I bought 30 from PPCS ans have never looked back.
Pros (vs wormdrive):
+ They're just as secure
+ They look great
+ They're much easier to install and take off
+ They save time and effort
+ You can never over-tighten them and thus damage your tubing/barbs
I personally didn't like the look of just the tubing and barbs on their own. I had to put the clamps on the finish them aesthetically.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
