XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-27-2009, 01:23 AM   #1
Bootup05
Xtreme Cruncher
Bootup05's Avatar
Hot Q6700 under TRUE
Hey guys.
Just stuck a Q6700 in my system for gaming benefits (E5200 was a bottlneck)
Load temps hit around 70c Priming after an hour, should I be concerned?
Im at 1.375v.
I have one single Enermax fan on there, 70CFM @ 18dB.
Stock Crappy Akasa paste.
__________________________________________________ ___________
If I'm going to have to sort this out:
I'm gonna pick up some AS5 / shin etsu, some good dual fans.
What would you guys recommend for a TRUE?
I've heard one guy say go for the highest CFM fans you can. Another saying something about static pressure and the dimensions between the heatsink wafers. I know a lot of people use Noctua's on TRUE's...
I've been eyeing up the Scythe Kaze Jyuni 1900RPM's on ChilledPC.
110CFM @ 37dB. Not cocerned about noise.
What fans are recommended?
I'm also looking to pick up a lapping kit from ChilledPC, Will lap the true first, then the cpu after if it needs it.
Recomendations?
__________________
Q6700 @ 3.66GHz. - Gigabyte UD3P - 6GB PC2-6400 - Asus 4890 @ 950/4500 - Tagan 600w - 320 + 160GB - 26 + 22" Widescreen's - Acoustic Energy Aego M's - Logitech MX3200 - TRUE + 2 x 70CFM 120's
Bootup05 is offline   Reply With Quote
Old 10-27-2009, 01:26 AM   #2
Kain665
What is your ambient temp? My Q9550 hits 65c under 1.32v with an ambient of 23c...
__________________
Q9550 4ghz (475x8.5) 1.32v load (Megahalem Push/Pull)
Asus P5Q - Deluxe (m2102) 1.40v NB
4gb Crucial Ballistix Red (6-6-6-18 @ 1140mhz, 9.3gb/s read)
BFG GTX275 720/1475/1269 (1.18v, higher for benches.)
OCZ SXS 600w
Lian Li PC-7 (Small, Old 80mm version )
Kain665 is offline   Reply With Quote
Old 10-27-2009, 01:36 AM   #3
Bootup05
Xtreme Cruncher
Bootup05's Avatar
Sorry forgot to add that.
Ambient right now is 22.7c, usually between 19 & 22c.
Right now, idling the chips at..
35,35,42,43, does the differnence in temperature between the cores mean anything?
I haven't had any 'heat issues' with any other chip, so I know my true's pretty good, is this just the fact that it draws a lot of power, 105W TDP, or that i've got a bad/ concave/ whatever ihs?
I haven't actually tested it yet with a razorblade.. But Gaming wise im pretty much at 60. & 61 is Intel's thermal specification apparently.
__________________
Old 10-27-2009, 04:47 AM   #4
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
temps are fine lap + pressure mod for good gains your true not making good contact as it should
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Old 10-27-2009, 04:51 AM   #5
Bootup05
Xtreme Cruncher
Bootup05's Avatar
Okay, cheers. While I'll do that I've got to pick up some new fans anyway cos I only have one now! The other broke lol. + Thermal goo.
Could someone reccomend fans?
Got a link to the pressure mod? I've been contemplating doing that for a while, right now I can twist the heatsink round whilst its 'clamped' down
__________________
Old 10-27-2009, 07:30 AM   #6
iTravis
iTravis's Avatar
Send a message via Yahoo to iTravis
FYI my QX9650 on a TRUE with a Cooler Master R4/Scythe Ultra Kaze 2000rpm push pull hit 86-85-75-72 at full load but this is at 1.46V. I think your temps are okay, just get a nice set of fans and a good thermal paste. You obviously have the right choice with the Shin Etsu there, however you might consider the Indigo Xtreme as it's the best thermal solution out there. As for fans if noise ain't a big deal to you then you might as well end up with the Delta, San Ace fans, other choice would be 2 Ultra Kaze 3000rpm fans. For best noise/performance: Enermax Magma, Scythe Gentle Typhoon, S-Flex or the CM R4 like me
__________________
1st Rig
CPU: Core i7 920 @ 4.2Ghz Mobo: eVGA X58 Classified CPU Cooler: Prolimatech Mega Shadow
GPU: Diamond HD4870X2 RAM: 3x2GB Corsair Dominator DDR3 1600 PSU: Corsair HX850W
Sound card: AuzenTech X-Fi Forte 7.1 HDD: OCZ Agility 120GB SSD OS: Windows 7 Ultimate x64
Display:
30" Dell UltraSharp 3007WFP-HC Speakers: Logitech Z-5500
2nd Rig
CPU: QX9650 @ 4.0Ghz Mobo: Asus Maximus Formula SE CPU Cooler: Thermalright Ultra 120 Xtreme
GPU: eVGA GTX 295 Co-op FTW RAM: 2x2GB G.Skill DDR2 1066 PSU: Corsair HX650W
Sound card: X-fi XtremeMusic HDD: 2TB OS: Windows XP
Display: 24" Dell UltraSharp 2407WFP Speakers: Logitech Z-5300
iTravis is offline   Reply With Quote
Old 10-29-2009, 01:53 PM   #7
panheimer
I think your true has a uneven base, or is not correctly setted. Temp difference of 8° C. between cores seems a little high to me, also your delta T° from idle to load seems a little high.
I've got a q6700 with 1.45 v. inside a CM Cosmos 1000 (VERY bad airflow). With T amb of 25-26° C, my idle temps are 43-46° C. reaching 68° C while priming, so i think your temps must be lower than mine. Without the side panel temps drops by 5-7° C.
Ah, i've lapped my true and i've got 2 x scythe sflex 1300 rpm.
__________________
Asus Rampage Formula / Q6700 G0 + TRUE / 4 x OCZ 9200 FleXLC / BFG 8800 Ultra OC / X-Fi XtremeGamer
Enermax Galaxy 1000 DXX / CM Stacker / Dell 2707 / Logitech G15 + G9 + Z5500
panheimer is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
